Question about Hotpoint Refrigerators
Hooked the water up to the ice maker and the water keeps puring out.. what do we do?
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 67 Answers
Where is it pouring out? Can you tell?
Here are some common problems:
1- Filter not installed or not tight
2- Loose fitting or cracked water line
3- stuck valve on ice maker
rlet me know where it's leaking..and a make and model number and I can help more.
Posted on Sep 06, 2010
What tells the pure advantage ice maker on the electrolux m/n ew23bcp71is0 to call for water the water valve is good the tube is not frozen and the icemakr will cycle and harvest when forced to fill m
The ice maker itself calls for the water after the harvest cycle and if it is not filling then you will need to replace the ice maker since there are no serviceable part on the unit. Here is the ice maker to order.
Dec 09, 2012 | Refrigerators
Ice maker not putting out water just hooked up ice maker kit
Are you getting ice? It seems like my brand-new electrolux does not produce cold water unless it is producing ice as well. We had to adjust the auger in the ice tray to start getting ice ... seems like our water is now getting colder.
Jul 05, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice maker water inlet keeps running
Replace the water inlet valve. It's on the back where the water supply hooks.You can turn the water off usually under the sink.
Dec 10, 2009 | Roper Refrigerators
Ice maker
If there is not other problem it will start to work after there is water in the ice mold and it freezes. It will then dump and refill with water.
You can Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
Sep 02, 2009 | Refrigerators
Ice-maker problem
if the water runs constantly when you turn the water on its your valve but if it does it periodacally it probably your icemaker
Apr 29, 2009 | Maytag MSD2756G Side by Side Refrigerator
I Have a FRS22ZRGD1 Double door fridge freezer combo , the ice does not get any water . I have water to door to fill glass. I replaced water filter a pure souce type. I replaced solinoid valve still no...
For all of you having problem of not getting any water to ice maker the water line running from solinoid valve to ice maker , mine was plugged solid with ice- try blowing through it once you have line removed from solinoid valve. I know they say you can removed the ice with a blow dryer but I tried that the ice was too far down to melt it .I took the line loose from the back of the fridge and un attached retaining screw and pulled plastic insert through cavity of fridge and ran hot water through it. Now it works fine.
Apr 17, 2009 | Frigidaire FRS26ZSG
No water getting to water filter or ice maker
the refrigerator has a duel water valve, one for the ice-maker and one for the water dispenser (if equipped). the valve that the ice-maker relies on may be bad, or it could be the ice-maker itself.
another thing that could cause it would be the temperatures in the freezer. the ice-maker will not call for water until it reaches under 15 degrees. also check the water tube behind the ice-maker to make sure it is not frozen, blocking more water from entering. the water does not go to the ice-maker or thru the filter unless the ice-maker turns on the water valve.
Jun 28, 2008 | Refrigerators
HOOK UP OF ICE MAKER TO THE WATER LINE
The ice maker is not making any ice, or water or crush ice. The wheel that crushes the ice will not spin. Please help
Apr 22, 2008 | Refrigerators
Refrigerators Logo
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
