Question about Dishwashers
Whirlpool dishwasher lock light is on
  • 135 Answers
Means the control panel is locked. You need to hold down a button usually with a little lock picture for 5 - 10 seconds to unlock it.
Posted on May 13, 2008
Dishwasher WHIRLPOOL DU930PWPQ2 stays locked and doesn't start. Even when i push on "heated dry" during 5 seconds. What can i do ? Some one gets an answer ? Thank you
washer Will Not Turn On - How To Fix ...
removeandreplace.com/2014/.../dishwasher-will-not-turn-on-how-to-fix/
Oct 6, 2014 - If your dishwasher won't turn on or start, here are a few things to check yourself ... Frigidaire, Kenmore, Whirlpool, and Bosch) work the same way. ... This door switch is also sometimes called a door lock or door interlock switch. ... All the lights light up on my dishwasher but the thing doesn't turn on at all.
Troubleshooting Why the Dishwasher Won't Start ... - YouTube
? 3:58
https://www.youtube.com/watch?v=8ZrtcdtmyEk
Jun 20, 2012 - Uploaded by PartSelect
In this video you'll learn what happens when the dishwasher won'tstart. ... Here are a few things you should check if yourdishwasher won't start: ... Replacing the Thermal Fuse & Harness (Whirlpool #675813) - Duration: 6:01.
Whirlpool Dishwasher DU930PWPQ2 Troubleshooting ...
Jan 14, 2016 | Whirlpool Dishwashers
I have a whirlpool gold dishwasher. The controls locked light is on and I can not get it to shut off. I can not run the dishwasher
In reading the manual, it shows the following:
To turn on Lock, press and hold Control Lock for at least
3seconds.
To turn off Lock, press and hold Control Lock for at least
3seconds.
Jun 07, 2015 | Whirlpool Dishwashers
Key sign on whirlpool dishwasher
I have a GU2200XTSQ2. Lock light was on, pushing and holding the Heated Dry button turned it off. Not sure why it came on in the first place.
Dec 17, 2012 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool Gold quiet washplus dishwasher Red Light staying on--control locked Cannot get it to run, no buttons will do anything
Which model dishwasher do you have? The Control Lock is a feature that keeps a child from starting the dishwasher when it shouldn't run. The Cancel button will work but not the Start button.
On the DU920QWD, to toggle the Control Lock off, press and hold Air Dry for 5 or more seconds. (Holding it again will turn on the lock.) Most dishwashers will have a the Control Lock key labeled with text in a small font for how to enable the Lock. The direct link to the DU920QWDB4 manual is https://www.whirlpool.com/digitalassets/MLPDF/Use%20and%20Care%20Guide%20-%203376817.pdf .
For other Whirlpool dishwashers, the Control Lock sequence will be listed in the manual. You can get a PDF of many Whirlpool appliance manuals from http://www.whirlpool.com/owners-center/owners-center-homepage.content.html . Enter the model number (from the rim inside the unit) and click on the right arrow.
I hope this helps.
Sep 08, 2011 | Whirlpool Dishwashers
My daughter has a Whirlpool series 930 dishwasher and it is locked? How do I unlock it?
This just happened to me recently on my Whirlpool. My dishwasher indicates that the "Air Dry" button will lock it out if held in for 5 seconds. To unlock it, hold this button in for another 5 seconds or until the lock out light goes out. Hope this helps.
Aug 10, 2009 | Whirlpool DU930PWS Built-in Dishwasher
I have a Whirlpool Dishwasher and it is locked and I don't know how to unlock it
I have a Whirlpool dishwasher & locked mine by pushing the "Air Dry" button for about 5 seconds. To unlock it, I pushed it in again another 5 seconds and the unlock light went out & it worked fine. Whatever button you locked it with originally (if you know), should unlock it when held in again.
Jul 16, 2009 | Whirlpool Dishwashers
Dishwasher locked key has been activated.
To turn on Lock:
Press and hold Heat Dry for at least 4 seconds. The Locked light
glows. If you press any pad while your dishwasher is locked, the
light flashes 3 times.
To turn off Lock:
Press and hold Heat Dry for at least 4 seconds. The Control Lock
light turns off.
Dec 18, 2008 | Whirlpool Dishwashers
Control Lock light on, won't go off.
i need your correct model number to help refer to you owners manuel how to come off control lock press and hold turns it on not off
Dec 30, 2007 | Whirlpool 24 in. DU930PWP Built-in...
DISHWASHER LOCK
I too had the same problem,,and tried it again,,,and it worked for me,,i pushed the button next to the lock light it blinked and i kept holding in the dry button and the lock went off,,,,good luck
Aug 15, 2007 | Whirlpool GU2400XTP Built-in Dishwasher
Dishwashers Logo
152 people viewed this question
Top Dishwashers Experts
