Question about LG 47LE5400 47 in. TV
Real cinema option is grayed out and i can't turn it on or off
Tell me please the projector, for home viewing ?
https://www.bestadvisor.com/home-theater-projectors
If you want to turn your room into a real cinema, a home theater projector is what you need. We have reviewed 5 best home theater projectors for you, so you can choose the one you like the most.
Apr 06, 2017 | The Office Equipment & Supplies
Does anybody knows why on a Video Capture Pin the "flip horizontally" option appears grayed out? I have two computers and one has it enabled while on the other one is disabled? BTW im using...
Check if you are using the same driver version for the camera on both pc's.Or to be sure , you can simply download the latest drivers from the link below and reinstall the driver on the pc that has the option greyed out
http://www.microsoft.com/hardware/download/download.aspx?category=ICE
Mar 10, 2011 | Microsoft LifeCam Cinema Web Cam
The picture is not full screen it has a gray bar on each side of the screen
go to quick menu select the picture size you will a selection native,wide,4:3,super live,cinema. try to choose it might help thanks need feed back
Oct 15, 2010 | Televison & Video
Why did my picture become big so I can not see the sideline information
Press the RATIO button repeatedly to select the desired picture format. You can also adjust Aspect Ratio in the OPTION menu.
  1. Set By Program. Selects the proper picture proportion to match the source’s image. (4:3 → 4:3, 16:9 → 16:9)
  2. 4:3. Choose 4:3 when you want to view a picture with an original 4:3 aspect ratio, with gray bars appearing at both the left and right sides.
  3. 16:9. Choose 16:9 when you want to adjust the picture horizontally, in a linear proportion to fill the entire screen.
  4. Horizon. Choose Horizon when you want to adjust the picture in a non-linear proportion, that is, more enlarged at both sides, to create a panorama view.
  5. Zoom 1. Choose Zoom 1 when you want to view the picture without any alteration. However, the top and bottom portions of the picture will be cropped.
  6. Zoom 2. Choose Zoom 2 when you want the picture to be altered, both horizontally extended and vertically cropped. The picture taking a halfway trade off between alteration and screen coverage.
  7. Cinema Zoom. Choose Cinema Zoom when you want to enlarge the picture in correct proportion. Note: When enlarging or reducing the picture, the image may become distorted. You can adjust the enlarge proportion of Cinema Zoom using D / E button. The adjustment range is 1~16.
Oct 18, 2009 | LG 42LC2D 42 in. LCD HDTV
Connecting ps3 to home cinema
For sound use the Digital Coax in, if the PS3 has digital out. Most HiFi home cinema systems have HDMI with all channels audio through HDMI. Check cinema settings to configure input for hdmi audio, also check PS3 audio output setting options to include all supported audio type by your receiver. It's not just a plug and play. Both systems need to gor through a user setup process to make sure they sync and play well with each other.
Jul 24, 2009 | Audio Players & Recorders
22" Apple Cinema Display doesn't power on
This may be an issue with the display detecting the wrong video format or is using an unsupported resolution for this Apple Cinema Display 22"
Procedure:
• Make sure your Mac is turned off.
• Once your Mac is shutdown, you will need to perform what is called a PRAM reset (Parameter RAM)
• Locate the following keys on the keyboard: Command, Option, P, and R. You will need to hold these keys down simultaneously .
• Turn on the computer.
• Press and hold the Command-Option-P-R keys. You must press this key combination before the gray screen appears.
• Now, hold the keys down until the computer restarts and you hear the start up sound for the third time.
• Release the keys and allow the Mac to start up.
If that does not help here is additional support reference from Apple regarding its LCD displays:
Apple Support Link:
Power Light Flash Issues
Let me know if this helps!
Regards,
-Mactechtrainer
Jul 02, 2009 | Apple 22" Cinema Display Monitor
Shutter won't open when turned on. Screen is gray & alarm sounds
It sounds as if when the camera was dropped it impacted the image processing chip inside of the camera thus why the LCD screen appears gray in color. You may want to call Olympus and discuss repair options. Their telephone number is 800-622-6372 option 2 and then option 3.
Nov 19, 2008 | Olympus Stylus 1010 Digital Camera
Apple 20" display black screen
I've read that aftermarket DVI cable adapters don't work well with this set-up. You might try the Apple DVI to ADC adapter. It's expensive but I see them on eBay or craigslist from time to time at less than half the normal $99 cost.
Aug 26, 2008 | Apple 20" Flat-Panel TFT LCD Cinema...
Trying to install a new 50
a good way to go is to connect the home cinema kit staight to the tv though phono leads, see if your tv has a phono in and out this must not be a av socket. you should then connect it in to your cinema kit so what ever you watch comes though ur cinema system
hope this helps
Feb 09, 2008 | Televison & Video
Home cinema/Viera link problem
Turn everything off and disconnect from mains.
Wait a few minutes.
Disconnect HDMI cable.
Turn on TV and DVD.
Connect cable.
If this does not work use a cable of different spec.
I had the same problem and now mine works .
Good luck.
T.P.
Oct 06, 2007 | Panasonic VIERA TH-65PV500 65 in. Plasma...
LG 47LE5400 47 in. TV Logo
1,300 people viewed this question
Computer Repairing
Computer Repairing
