Question about HP DeskJet 1280 InkJet Printer
Carriage jam problem/1280 printer - HP DeskJet 1280 InkJet Printer
  • 1,218 Answers
If you are getting a 'carriage jam' error as soon as you turn on your printer with no tasks in progress, then check for any piece of paper stuck in the carriage. Remove the paper carefully. If the paper tears, part of it might remain inside the paper path and damage the product.
Follow the steps for fix HP Printer Carriage Jam
  • Turn off the printer and open it to see where the paper is stuck.
  • Manually move the carriage toward the opposite side.
  • Check the paper path and remove any piece of paper or any other object that is stuck in the path.
  • Reconnect the power cord and turn on the printer.
http://www.fixya.com/support/t6088190-hp_7400_displays
Posted on Sep 23, 2010
I stupidly put a new black in cartridge into my epson 1280 printer......backwards.....!!! Now, of course, it won't print Black....AND I can't figure out how to get it out to reverse it. I've pushed the...
Turn on your printer, as soon as the carriage moves out of it's resting position quickly unplugged the printer, the carriage should stop in a postion that you could move it freely by hand. Just position it by hand where you can remove the cartridge and put it back correctly. When your done just gently push the carriage back to it's resting position then put the plug in and turn it on.
Mar 02, 2011 | Epson Stylus Photo 1280 InkJet Printer
On my HP 1280 Deskjet A3 printer, while printing paper getting stuck in the middle. I have serviced it recently.
printer hardware problem.its for formatting board problem.it is located on carriage assymbly.replace the board.problem will solve.
Jan 09, 2011 | HP DeskJet 1280 InkJet Printer
What is a carriage jam
here are some solutions for your carriage jam error.
1. Clear any jam...remove loose paper.
2.Clear the jam from the back of the printer
turn off the printer...remove the rear access door..
pull the paper out of the roller and return the rear access door.
3. Clear the paper jam from the front of the printer..while printer is on..open the carriage access door..
disconnect the power cable from the back.. remove the paper output tray.
look inside the product..check for torn papers..gently pull out the paper fromthe roller...return the paper output tray and the carriage access door. plugthe power corn and turn on..
4. Make sure the carriages move freely...while the printer is on.. open the carriageaccess door.
disconnect the power cord from the back..remove the paper output tray...lookinside if the carriage is stuck and if there is no papers or object that restrictthe carriage to move..return the output tray.. return the carriage accessdoor...
And lastly after doing this steps try to reset the printer and try to print..
To reset the printer....press the power button to turn on theprinter..disconnect the power cord from the product..disconnect the power cordfrom the wall outlet.. wait for 15 seconds.. plug the power cord to the wallsocket....plug the power cord at the back of the printer.. press the power onof the printer.. try to print the test page...
http://www.fixya.com/support/t6088190-hp_7400_displayshttp://www.fixya.com/support/t6088190-hp_7400_displays
Good luck! hope this solve the problem
Much appreciated if you rate this help.. thanks
May 10, 2010 | Office Equipment & Supplies
Its stop printing and the LED power light green and orange at the center blink, like there is a paper jam.
Feb 11, 2010 | HP DeskJet 1280 InkJet Printer
Printer stops and blinks carriage jam error
DIP YOUR FINGER INTO SOME SEWING MACHINE OIL AND GENTLY RUBB IT ONTO THE SILVER SLIDE BAR. DO NOT LET OIL GET ONTO ANY OTHER PARTS
Feb 02, 2010 | HP DeskJet 1280 InkJet Printer
How to clean carriage jam?
tools are recommended when cleaning a toner cartridge: A mask which will filter out any toxic particles in the toner, a can of compressed air to blow out any toner remaining in the cartridge, and cotton swabs/alcohol to wipe the toner cartridge. After this try printing most cases carriage jam will not happen unless there is physical damage.
Jan 26, 2010 | HP DeskJet 1280 InkJet Printer
Carriage jam
Usually when the printer displays a carriage jam error the carriage assembly is jamming along the carrige path.
There may be something in the carriage path or the carriage shaft may need lubricating.
Check the area where the carriage is has stoped. There might be an obstruction visible.
Jan 04, 2009 | HP Officejet J5780 All-In-One InkJet...
Epson 1280 ink carriage making noise and not printing
hello there. try re-seating the cartridge. Take it out, then put it back in.
Nov 28, 2008 | Epson Stylus Photo 1280 InkJet Printer
Epson 1280 Solid red mainteance light
Hi-
Is iot on the position where you can install the ink cartridge? try turning it off and unplug it from power supply then after 10mins replug and turn it back on. keep me posted, but if it will do the same thing chances are there is something wrong with the belts on it, better have it fix or have it check. Thanks for using fixya!!
Jun 26, 2008 | Epson Stylus Photo 1280 InkJet Printer
Epson 1280 Printer breakdown
it is the wasted ink pad, they are full.
to have your printer work again
press and hold the ink and paper button while turning on the printer, wait for 5 seconds then release the button and press the paper button for at least 10 sec.
if done correctly , you will see the carriage start moving
Jan 20, 2008 | Epson Stylus Photo 1280 InkJet Printer
HP DeskJet 1280 InkJet Printer Logo
294 people viewed this question
Seeker5211
Seeker5211
