FixYa.com
Tags:
JVC AV-48WP30 48 in. Rear Projection Television
JVC AV-48WP30 started displaying vertical lines...
posted by Dennis024 on May 13, 2008
Recently, my JVC AV-48WP30 started displaying vertical lines every inch or so from the top to the bottom of the screen.
They're very, very narrow (about a "pixel" wide, if you will) and affect every input on the unit, including the DVI, component, TV (RF), and S-video inputs.
They "modulate", in that they change color, slightly, and intensity, almost like an amplifier or transistor is "clipping". Mostly, they appear white on dark backgrounds and vice versa, and the lines are not solid top-to bottom, but rather like some pixels are on and off in each line. They do not shift side to side at all, and always run full top to bottom.
They do _not_ appear on the onscreen menus, however, only on the tv signals.
I have _no_ idea what could be wrong, however, and no idea as to where to start looking. Any help would be most appreciated.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on May 23, 2008
Not Rated (0)
Guest
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
Sounds like a hyer-board problem.
Was this solution helpful? Show your Appreciation by rating it:
Can you Help with these Projection Televisions problems?
JVC AV-48WP30 48 in. Rear Projection...
Screen went black
I was watching TV, then the... Answer This...
JVC Big Screen: Screen Bowed...
The screen is bowed top and... Answer This...
HORIZONTAL LINES ON TOP OF THE...
shows greenish horizontal lines... Answer This...
problem with your tv
I am having the same problem... Answer This...
JVC AV-48WP30 / convergence
I changed the ic's and the ohms... Answer This...
Repair Service
Find Projection TV Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
