Question about LG WM3431 Front Load Washer / Dryer
My washiong machine is an LG washer/dryer its coming up with message LE each time i start a cycle, the wheel will not turn. I have halfed the load, turned off and on tried different cycles put still does not work???
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. LE' error message indicates the control board has detected that the motor is either not turning, or has locked up for some reason. Monitoring the motor is the job of the Hall Effect sensor board which constantly determines the direction and speed of the motor and feeds that information back to the control board. If there is a problem between what the motor should be doing and what the hall effect sensor says the motor is doing, the 'LE' will be displayed and the cycle will be stopped. The hall sensor is rather easy to replace, and is covered by a seven year part warranty (in US). It only takes around half hour to replace it with a new one. Take the back cover off. Take the big nut off and remove the motor rotor. Remove the bolts holding the motor windings. Remove the electric plug on the sensor and unclip it from the motor winding. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Sep 07, 2010
My front loader washing machine suddenly stop working at there is an LE sign
LG, the electronics and appliances conglomerate, manufactures a variety of high-efficiency washing machines. Whether you have a front- or top-loading model, your LG washer is equipped with an error-monitoring system. When the LE code appears in your display, it indicates a problem with the motor. The problem can be related to several different issues. In order to clear the error, determine which issue is at hand.
New Installation The LE error code may appear in an LG washer's display if installation issues exist. It indicates a miscommunication between the wash motor and the control panel. In most cases, you can simply reset the washer to solve the problem. Unplug your washer before pressing and holding the Start/Pause button for approximately five seconds. Plug it back in and set the washer to a rinse-spin cycle to see if the code has cleared. If the code reappears in the display, contact LG at the phone number in your owner's manual for assistance.
Thermal Overload Protection Your washer may display the LE code if the thermal overload protection circuit in the motor has been tripped. The feature is designed to prevent the motor from overheating and causing permanent damage to the washer. To clear the error code, the motor must cool down. Allow the washer to sit for approximately half an hour before restarting the cycle. If the code reappears, the motor may have an issue that requires a service call. Unplug your washer and contact LG.
Excessive Suds If your washer detects excessive soap suds in the drum, the LE error code can appear. Typically, excessive sudsing occurs when you use too much high-efficiency detergent or a detergent that's not specifically high-efficiency detergent. Always follow the guidelines in your owner's manual and on the detergent label to determine what type of detergent, and how much, to use. To get rid of soap suds in the drum and clear the code, unplug your washer and let it sit for a half hour so the suds can dissolve. Plug the washing machine back in and turn it on, hitting the Spin Speed button and selecting "No Spin." Press the Start/Pause button to turn on a drain only cycle. When the cycle is completed, remove the load from the tub. Start a rinse-spin cycle to clear away any residue. You may need to repeat the cycle to remove all of the suds.
Load Issues The LE error code can appear in an LG washer's display due to certain load conditions. If you are washing a large load, don't choose a gentle cycle like Delicates, Hand Wash, Perm Press or Wool/Silk. Reserve them for smaller loads. To reset the washer, unplug it and press the Start/Pause button for five seconds before plugging it back in. The LE code can indicate that the washer has been overloaded; large loads and bulky items can strain the motor. Remove a few items from the washer to reduce the load size and restart the cycle. If the code appears again, let the washer sit for a half-hour so the motor has time to cool down before you restart the cycle.
Feb 28, 2015 | Washing Machines
My LG Washer stops running and blinks LE. It load the washer, but the wash cycle do not start.The machine will empty the water
Hi
Thanks
Rylee
Aug 29, 2010 | LG WM-1832C Front Load Washer
LG washer dryer combination machine model WM3677HW doesn't spin, LE comes up.
Hi
Thanks
Rylee
Aug 25, 2010 | LG WM-3677HW Front Load Washer / Dryer
Le comes up and stops cycle
LE code stands for locked motor error. When this error code appears in your front load washer it indicates a fault in the motor unit.
1 . Check the connections to the Coil/Stator at the rear of the unit possibly it should be something like a broken wire.
2 . Coil/Stator Assembly will be defective preventing the drive to operate.You should go for a replacement of that assembly.
Thank you !!
Jun 28, 2010 | LG WM3677HW 3.7 cu.ft. Front Load Washer...
LG WASHER WM1832CW HAS LE ERROR MESSAGE
error LE Overload in motor.unplug for 1 hour plug back in. motors going bad or over loaded with stuff.
Jan 15, 2009 | LG WM-2277HW Front Load Washer
LG washing machine problem.
LE is a locked motor error
make sure that all your connections are secured
Dec 29, 2008 | LG WM3677HW 3.7 cu.ft. Front Load Washer...
No or infrequent spin and LE message
We cleaned our filter and unblocked a pipe at the back of the machine and found that it worked
May 30, 2008 | LG WD-3243RHD Front Load Washer / Dryer
Lg wd-3243rhd front load washer and dryer combo "le" error message
LE error code means the motor sensor has failed.  The motor sensor is located in the back of unit inside the motor.  You will need to order a replacement motor sensor from LG.  You will need a 17 mm and 10 mm socket tools to do this job.
Mar 17, 2008 | LG WD-3243RHD Front Load Washer / Dryer
Open Questions:
How to resolve "PF" power failure on an lg WM3431HW Hello, I have an LG WM3431HW which is a combo washer/dryer. It is around 4-5 years old. It was working fine, then recently after completing the washing cycle and after a few minutes after the start of the dryer cycle. The dryer cycle shuts off without error (power to unit still on). We opened up the top and cleaned out all the lint caked on within the dryer duct and made sure lint trap off drain pump in front was cleaned. We started again and received a DHE error. We confirmed the dryer element was heating up fine. We also tested continuity to through the dryer thermostats and it had continuity. Also confirmed appropriate voltage over dryer element. We then took dryer duct fan off, turned it upside down and re-connected to make sure it was turning properly. It seemed to start and stop and it was also very hot so we thought there was a problem with the fan so we replaced the fan, and to be safe, also replaced the thermostat. Once that was done, a few seconds after the unit goes into the dry cycle, the cycle stops and shows a "PF" power failure error. We checked all connections we can find but everything looks connected correctly. We eye-balled the power board to see if there was any burn spots or anything else noticeable but nothing. We also eyeballed the power filter for the same but nothing looked out of the ordinary. The heating element was hot and confirmed the dryer fan duct was revolving, albeit for a short time. It seems that there is something tested after the heating element is started and the fan revolving, that is not working and which is telling the unit to shut off or "power failure". We had also unhooked the dryer thermistor to see if anything looked unusual but looked fine and re-connected. What else can I check and what part is likely to be at fault ? Since the wash cycle runs fine, I am hoping the power board is fine. Thanks
Jul 16, 2014 | LG WM3431 Front Load Washer / Dryer
Additional details: Questions with more than 25 words are more likely to be answered well. 0 chars Your Question Preview No product selected LG WM3431 Front Load Washer / Dryer How to resolve "PF" power failure on an lg WM3431HW Hello, I have an LG WM3431HW which is a combo washer/dryer. It is around 4-5 years old. It was working fine, then recently after completing the washing cycle and after a few minutes after the start of the dryer cycle. The dryer cycle shuts off without error (power to unit still on). We opened up the top and cleaned out all the lint caked on within the dryer duct and made sure lint trap off drain pump in front was cleaned. We started again and received a DHE error. We confirmed the dryer element was heating up fine. We also tested continuity to through the dryer thermostats and it had continuity. Also confirmed appropriate voltage over dryer element. We then took dryer duct fan off, turned it upside down and re-connected to make sure it was turning properly. It seemed to start and stop and it was also very hot so we thought there was a problem with the fan so we replaced the fan, and to be safe, also replaced the thermostat. Once that was done, a few seconds after the unit goes into the dry cycle, the cycle stops and shows a "PF" power failure error. We checked all connections we can find but everything looks connected correctly. We eye-balled the power board to see if there was any burn spots or anything else noticeable but nothing. We also eyeballed the power filter for the same but nothing looked out of the ordinary. The heating element was hot and confirmed the dryer fan duct was revolving, albeit for a short time. It seems that there is something tested after the heating element is started and the fan revolving, that is not working and which is telling the unit to shut off or "power failure". We had also unhooked the dryer thermistor to see if anything looked unusual but looked fine and re-connected. What else can I check and what part is likely to be at fault ? Since the wash cycle runs fine, I am hoping the power board is fine. Thanks
See all LG WM3431 Front Load Washer / Dryer Questions
LG WM3431 Front Load Washer / Dryer Logo
59 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
