Question about Texas Instruments TI-84 Plus Silver Edition Graphic Calculator
The graph won't download onto my computer to print.
  • Texas Instru... Master
  • 8,068 Answers
Connect Calculator to computer with a TI Silverlink cable or direct USB cable. Run TI Connect. In TI connect Main screen click the ScreenCapture button and wait for the calculator to be recognized and its screen captured.
Save it as jpeg. You will be able to print it with any picture software.
Posted on Sep 10, 2010
Trying to download apps but it won't register the fact that my calculator is connected
Use the TI USB Silver cable or a standard USB to Mini USB. The calculator shipped with one or both cables.
Before it can be recognized you must install the drivers. Download TI connect and install it on the computer before connecting the calculator. If you use the Graph link (black cable) you need to have a serial port on the computer.
COM3 is serial communication port. On newer computers (laptops) that port is no longer available.
Feb 03, 2012 | Texas Instruments TI-84 Plus Calculator
Graphing doesnt show
Depending on the function you are drawing, it is possible that the graph is out of range of the windows dimensions. Try Zooming out to see a bigger portion of the plane. If you know where the function intercepts one of the axes, you might want to center the graph around that point.
Jan 16, 2012 | Texas Instruments TI-84 Plus Calculator
I want to upload photo graphs onto my computer
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as iPhoto and Windows Photo Gallery.
Oct 26, 2011 | Panasonic Lumix DMC-FX8 Digital Camera
How do I send my graph from my 84 plus silver edition to my computer?
  1. Install the TI Connect software on the computer.
  2. Connect the calculator to the computer using the Silver Link cable or the USB direct cable.
  3. Run the TI Connect software and let it recognize the Calculator.
  4. Once this is done, create the graph on the calculator, and click the screen capture button in TI Connect.
  5. Save image in jpeg format.
  6. Send it to the printer to print or insert it in a text document which you then print.
Dec 15, 2010 | Texas Instruments TI-84 Plus Silver...
How can I print graphs?
  1. Create your graph on calculator.
  2. Connect the calculator to the computer using one of the two methods: SilverLink Cable of the USB Direct Cable.
  3. On the computer RUN the TIConnect Software.
  4. In main window, find the TIScreenCapture icon (it is afflicted with a Camera and a curve graphed)
  5. Click the TIScreenCapture and
  6. save the image in jpeg or png format (bmp format file are too big)
  7. You will be able to print it from the computer using an image editing software,
  8. or insert it into a word document and then print the document.
Apr 17, 2010 | Texas Instruments TI-84 Plus Calculator
How to print a graph off of my ti84 plus calculator? i downloaded ti connect, but nothing happens when i click on ti screen capture
You say TIConnect is installed. Ok. Prepare you cable, and your calculator. Draw the graph you want to capture to the computer. Connect the cable to the calculator and connect the other end of the cable to the computer port (Serial port, or USB port). Make sure the calculator is still ON.
Run TIConnect. In the main window click the button TIDeviceInfo. This will launch the communication program between the calculator and the compouter. In the Select TI device the softaware must fin the calculator. If it does not you, will not be able to capture the screen.
Hope it helps.
Nov 24, 2009 | Texas Instruments TI-84 Plus Calculator
Printing off graphs from a calculator
Yes you can transfer everything on you YI92/TI92PLus to your computer.
To connect it you need TIConnect software, and a USB TI Silvercable.
Once the software is installed, you can communicate with your calculator (capture anything on your TI screen as an image to your computer, install applications, transfer programs and so on).
Run TI connect on your calculator.
Draw the graph on your TI 92.
Connect the calculator to the computer.
Click Screen Capture in the TI Connect software window,
It will be store it in your user directory (My Documents ->My TI data)
Hope it helps
Jan 29, 2009 | Texas Instruments TI-92 Plus Calculator
How do I get my Kodak Easy Share Printer #7330 to print pictured from my Compaq computer?
first install the printer onto the computer, downloading the drivers or using printer disk.
If your printer is already installed on your computer and working you do not need to install it , skip this step.
Then download pictures onto computer, using USB cable.
open downloaded picture by double clicking with left mouse button.
Once you open the picture with picture viewer open file menu and chose print, or click the small printer sign.
If you use oprint preview iit may be easier for you to change printer settings to print the pictures.
Sep 03, 2008 | Computers & Internet
TI-85 manual
I have the original TI-85 Graphics Calculator Guidebook (quite thick), but I no longer own the calculator. You are welcome to have it, since I was just about to throw it away. If you want it, please e-mail me at: srairigh@iserv.net within the next week, as I'd like to get it off my desk. Thanks! -- Sandy
Aug 13, 2008 | Texas Instruments TI-85 Calculator
Texas Instruments TI-84 Plus Silver Edition Graphic Calculator Logo
150 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
