Question about HP Pavilion a1220n (A1220NED904AA) PC Desktop
I have an HP Pavillion a1220n. The partition in the hard drive has been corrupted. I have no OS left and no boot disk. How do I fix this problem?
  • HP Master
  • 1,183 Answers
The recovery cds are available on the link below
http://www.hprecoverycd.com/
Thanks
Proton
Posted on Sep 06, 2010
  • Mandeep  Singh
    Mandeep Singh Sep 06, 2010
    Additional information on how to repair your computer
    http://h10025.www1.hp.com/ewfrf/wc/docum...
    Thanks for using fixya
    Proton
    if the solution helped you fix the problem, please accept the bid.
I got mac g4 just got face and ? on it, any have idea what going on it
Typically this is operating system corruption or a failed hard drive. If you can boot to your install media (CD, USB, or recovery partition) try a clean install. You could also try third party software solutions like Disk Warrior or Drive Genius (they supply bootable media) to fix the OS issues or check the disk for failures / corruption
Oct 16, 2012 | Apple iMac G4 Desktop
Memory wipe wd3200bevt
Download MiniTool Partition Wizard Bootable CD 7.1 from Here.
Or Download Directly by Clicking here
This CD allows you to boot computer directly into MiniTool Partition Wizard to manage partitions without any limitations. You can rebuild MBR, Partition Recovery, Move/Resize Partition, Merge Partition, Change Cluster Size, Copy Partition, Create Partition, Delete Partition, Format Partition, Convert File System, Hide/Unhide Partition, Explore Partition and much more.
Burn ISO file onto a CD using any CD/DVD Burner software.
Set the CD-Drive to 1st boot device in BIOS.
Insert it into drive and reboot the system.
You will get Partition Wizard Boot Disc Menu.
What to expect from this bootable CD
Step 1: Choose boot disk
Step 2: Choose screen resolution
Step 3: Manage your partition
How Delete All Partitions?
  • There are two ways to start this function:
    1) Click on Disk in the top menu, click Delete All Partitions from the drop down menu.
    2) Click Delete All Partition under Disk Operations in the Action Panel.
  • Delete All Partitions will delete all the partitions in the present chosen disks.
    Note: May cause Windows to not start properly when used on partitions containing the boot partition or system partition.
For more information check the website Link
Hope this will be useful for you.
Best Regards
Nandu
Apr 04, 2012 | Western Digital (WD3200BEVT) 320 GB SATA...
I have a hp pavillion dv4 2126 tx laptop with windows 7 os. i need to load fedora or ubunto for the same. i want to know how to do it without disturbing windows os and my files.
First you will need to partition the hard drive. This can be done from within Windows 7 using the Disk Management utility. You may access this by right clicking on "Computer" and going to manage. You will then click on disk management to the left in the navigation pane. From there you will see a listing of your hard disks and their existing partitions (if any). You now need to right click on the partition you would like to shrink in order to make space for your Linux install. The minimum recommended amount is 15GB, but if you have more to spare, I highly recommend utilizing it.
Once the partition is shrunk you will have some unallocated space that the Linux install can take advantage of. You now simply need to boot from your Linux install CD and choose this unallocated space as the install point.
There is a video and an article I will reference that should help as well.
Lifehacker Article
YouTube video on how to partition your hard drive in Windows 7.
Mar 15, 2011 | Computers & Internet
I have a compaq laptop about 8 months when i turn it on it has a black screen says soft hard disk error 1 (301) what does that mean? how do i fix it?
a softdisk error 301 means the hard drive is failing it is common on hp and compaq laptops ( hp owns compaq) unfortunately you are screwed to say the leas the hard drive is failingt. BUT you can save your data by hooking up an external hd and running ubuntu live cd to boot and copy any files you need from your hard drive over. you can download ubuntu from ubuntu.com and download and burn the live cd then you will need to set via ur bios when you boot i think its f2 or del key to get into the bios then go to boot order and select cd dvd drive to boot b4 cd then boot into the ubuntu disk and copy your files.
Mar 14, 2011 | Computers & Internet
Turn computer on and it say disk boot failure
Possible that the hard disk /memory is faulty as it is most likely that the hard disk main partition drive is corrupt or damaged. If the set is able to boot up then you can get the drive partitioned and the OS reinstalled.
Recommend that you take option to confirm the fault before coming to a decision.
Dec 13, 2010 | Computers & Internet
Laptop wont boot...it wont load past the very first boot screen where it asks you to hit f12 for boot menu and f2 for system utilities it have the windows vista OS...is there a problem with the hard drive?...
Windows is corrupt...reload Win OS....if possible re-install Windows in a different partition say D: or E: etc (if u have more than 1 partition) and then once done let it boot from that and let Win load....take a full backup of all of your critical data to a USB pen drive....then reload Win CD in the Cd drive, switch off and switch on PC let it boot from CD and delete all partition on HD, format the disk fully and repartition the disk and load Win in C:
pls leave a feedback
Mar 03, 2010 | Toshiba Satellite A135-S4467 Notebook
Hp pavillion zv6000 no disks need full restore...
Yes, the recovery partition is 100% true, and I've actually used it to repair a lot of systems, simply because it saves you time, stress and energy.
It is always on a smaller partition on your hard disk, and it is also hidden, so you wont see it.
To use the recovery partiton, you have first of all take note that you must backup ALL your documents first, because the use of the recovery partition will Actually format your harddrives and restore your system back to the factory settings, i.e the way you bought it.
Now, provided your own recovery partition is still intact and not yet corrupt, this is how to use it.
When you power up your system, Keep tapping the F11 key, i.e the F11 function key.
This will invoke the command that boots up your recovery parttion and lets your system boot from it.
Thereafter, you can just follow the on-screen instructions to complete the recovery, and again PLEASE remember to backup ALL your necessary documents first.
Hope this helps you out.
Goodluck
Jul 10, 2009 | HP Pavilion ZV5000, ZV6000, ZX5000 Series...
HP restore wizard after reinstallation Vista on c partition
sounds like you've got a virus corrupting the c:drive. You may have to reformat the whole hard drive, if C:is the boot drive reguardless whether the D: drive works or not you will ahve to reformat the boot drive to run the computer.
Apr 03, 2009 | HP Computers & Internet
When starting my DV4000 - the screen is dark other than a cursor in the left corner.
That error indicates a hard drive problem. You probably have to replace the hard drive.
Nov 23, 2007 | HP Pavilion dv4000 Notebook
HP Pavilion a1220n (A1220NED904AA) PC Desktop Logo
132 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
