Question about Vacuums
Stiches are loose and ball up on bottom side - Vacuums
    Brigadier General:
  • 3,006 Answers
Then your top thread tension is far too loose in relation to the bobbin thread.
First, check that the bobbin thread (the lower thread) pulls out with a little bit of tension. If it's hard to pull out then you have loaded the bobbin incorrectly or have a faulty bobbin case. If the bobbin thread seems fine then check that you have correctly run the top thread and have set the tension correctly. As you haven't stated a make and model it's impossible to give you more detailed instructions though.
Posted on Sep 06, 2010
Dyson Ball DC24 brush turns but is loose and makes a very loud noise. Brush seems to be hitting sides of vacume.
You need a new brush and end cap. The brush and end cap can wear or break in time as they are made of plastic. Spares available on Dyson web site.
May 21, 2012 | Dyson Ball DC24 Bagless Upright Vacuum
Dyson Animal filter in ball comes loose and pops up and catches on frame and ball will not rotate.
I'm sorry to hear you're having difficulties with your DC25's filter. I'd encourage you to contact us directly so we can resolve this for you - you can call us free on 0800 298 0298 (UK), or 1-866-693-9766 (US).
Best wishes,
Jack
Dyson Online Customer Support
http://www.dyson.com/
Jan 12, 2012 | Vacuums
Filter in the ball on my DC25 keeps coming loose and keeps the ball from spinning any ideas
My Dyson DC25 keeps blowing off the filter within the ball. It then stops the ball from rotating freely.
Jan 14, 2011 | Dyson DC25 All Floors Bagless Upright...
Stiches are loose in the bottom side of the cloth,if i change the bobbin case....will it help? I can understand that tension of thread is the problem.....but don't know what to do
the case the bobbin goes into has a little spring on its side .. the spring has one or two screws. one screw adjusts tension on the spring .. the bobbin thread goes under that spring when it is properly threaded .. if the screw is loose or missing then replace the screw or tighten it a little so that thread pulled thru the bobbin case spring has a bit of drag .. if its too loose then you can tighten the screw a bit more ... if you tighten it too much then it will pull the top thread thru to the bottom .. if your adjustment screw or spring is missing then you can replace the bobbin holder .. the new one should have the spring in place and be properly tightened .. . often the adjustment screw is just loose or the thread is not positioned correctly in the bobbin case slot. .
Jun 21, 2010 | Vacuums
Dyson ball not picking up properly and very noisy
Is the beater brush spinning? Is the sole plate that is removable and covers the bottom side of the beater brush housing installed properly such that there are no gaps between it and the housing? Is the hose that connects the beater brush housing to the canister connected or have any holes in it?
May 26, 2010 | Dyson DC15 All Floors - The Ball Bagless...
Bought clearance item Sunday just found out the brush bar was motorized it turms only when i move the vacum back and fourth it should turn on its own right ? I have very little suction from the bottom the...
This appears to be a loose connection. The below post was answered by highntools a while ago. It probably is related to you problem. That is why moving it back and forth makes it go on.
I have finally fixed my sister's dyson dc 15 beater bar problem. It was just 2 tiny broken wires connect to circuit board lead to the beater bar. The wires broke where they go through the black rubber gommet. You need a torx screwdriver tx 15 to remove 2 plastic covers to access the wires. When looking at the front of the vacuum, the gray covers located on the right side of the vacuum. 1 big cover with a black rubber gasket and other small gray cover is on the rotating ball area.
There have been several people who reported loose or burnt wires to be the culprit for the brush bar not working. The DC15 does not use a belt, but a motor that is control by the circuit board. And I really believe that in your instance, the problem is a loose wire between the circuit board and the brush motor.
Mar 09, 2010 | Dyson DC15 All Floors - The Ball Bagless...
Beater brushes don't work, what to do? They only work when the canister is in about an 85 degree up position.
Jul 12, 2009 | Dyson DC15 All Floors - The Ball Bagless...
Vacuums Logo
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
