Trying to connect my canon Pixma MX340 to a mac book running OSX 10.6.4. I have an Actiontec PK5000. I press the WPS button, but they fail to connect within 10 minutes, I am following the instructions to the letter...
  • 19,396 Answers
Hi.
The WPS button wifi auto configuration does not always work, in fact it fails most of the time, depending to router and network configuration.
Before connecting the printer , ensure that configuration Mac, router and network is complete, and that the Mac is connected to the network.
Before connecting the printer ensure that you have the printer software, if you do not have the software, download if from Canon website.
Install the printer as suggested in the document below. You will need to follow the steps in software setup. At a point you need to connect the printer to Mac using an Ethernet cable. Then enter access point, remove cable and configure printer wirelessly.
Here configuration instructions.
Here config. for additional computer (if required).
Posted on Sep 06, 2010
Where is wps button?
About 49,500 results (0.39 seconds) Search Results
    What is WPS and how do I use it to set up the printer on the ...
    https://support.usa.canon.com/kb/index?page=content&id...
    Jan 15, 2016 - Use the , , and keys to select WLAN setup , then press the OK button. The printer will search for Access Points / Routers. If a WPS-compatible ...
    where is the WPS button? - Canon Community
    community.usa.canon.com/t5/Printer...Support/...WPS-button/td.../8893
    Dec 27, 2012 - Hello dmlarsen. The WPS button is not on the printer. This button would be located on your router itself. If your router does not have a clearly ...
    How to perform the wireless LAN setup using WPS connection
    support-th.canon-asia.com/contents/TH/EN/8200685600.html
    Dec 10, 2009 - Press and hold the WPS button on the access point (for about 5 ... If the Printer Connection screen appears instead of the screen above, the ... images for Printers & Copiers Where is wps button
Jan 23, 2016 | Office Equipment & Supplies
My iphone 5s cannot find my cannon mx452 printer
Please try the following steps to connect the unit to your Wi-Fi router:
1. Press the Setup button on the printer.
2. Use the arrow keys to select Drive Settings and press OK.
3. Select LAN Settings and press OK.
4. Choose Wireless LAN Setup and press OK.
5. If a WPS prompt appears, press the STOP button.
6. Select Standard Setup and press OK.
7. Select your Access Point and press OK. When entering the passphrase, use the Tone or Star (*) key to change character modes.
Once this has been done, insert the CD for the unit into your Windows or Mac OSX computer and perform the installation.
May 18, 2014 | Canon Pixma MX452
Connectng pixma mx340 wifi to my tablet
You should have no problems as long as the tablet can see the printer's signals. If you need to you may also use a USB cable to connect them. But generally you should have no issues in connecting a tablet to a wireless printer.
Mar 17, 2014 | Canon PIXMA MX340 Wireless Office...
Wps button
The front of your Actiontec modem has a button and light for Wi-Fi Protected Setup (WPS). If that button was pressed or the WPS process was started, that button may light up or blink.
Aug 16, 2013 | D-Link DIR-625 (790069292637) Wireless...
My Cannon MX340 is reading "Check Ink, U140, Col" after I changed the ink. I've taken the cartridges out & back in several times??
you will have to press and hold the Resume button for at least 10 seconds.
If that dose not work press and hold for at least 10 seconds the OK button.
It will by pass the ink level counter and you will be able to use your printer.
Jun 05, 2011 | Canon PIXMA MX340 Wireless Office...
I cannot install my new pixma mx340 setup driver on mac os x 10.6.6. Get Installation failure message. Was successfull installing on 10.4
With 10.6, you just need to plug in the printer and the Mac will download the right drivers automatically.
If that fails, download and install the Canon drivers manually from here: http://support.apple.com/kb/DL899
Mar 25, 2011 | Canon PIXMA MX340 Wireless Office...
Trying to make iphone print off the web to canon mx340
Canon MX340 is not supported by Airprint. http://support.apple.com/kb/ht4356
Alternately, you can purchase and install Printopia on a Mac to make the Mac act as an AirPrint hub, or go to this website:
http://jaxov.com/2010/11/how-to-enable-airprint-service-on-windows/
to make a PC an AirPrint hub.
Mar 21, 2011 | Canon PIXMA MX340 Wireless Office...
How do I get my Canon PIXMA 340 to print with my MAc running OSX 10.4.1? It works perfectly well with my other Mac running Snow Leopard. I thought I downloaded the drivers for 10.4 but when I try to...
Make sure that these is how the installation went through(provided that the installer is already downloaded to your computer:
  1. Double-click the file to mount the Disk Image.
  2. Double-click the mounted Disk Image.
  3. Double-click the .pkg file in the folder. Installation starts automatically.
Moving forward when adding a printer and the Ok button is grayed-out is that there are no other pop-out window or tick box that hasn't been ticked yet.
Jan 17, 2011 | Canon PIXMA MX340 Wireless Office...
Failed Wireless Setup/could not create new port
Check this link for wireless setup:
http://downloads.canon.com/MP620/Intro_to_MP620_Setup_Guide.htm
There are Vista 64 drivers on the CD that came with the printer, but if you want to download, you should download the network drivers if you are installing the printer to work on a wireless local area network (LAN).
Jun 23, 2009 | Canon PIXMA MP600 all-In-One InkJet...
366 people viewed this question
jasbo
jasbo
