Question about Xerox DocuColor 12 Printer
System fault 9-363 i tried everything i know, please help
  • cyfish May 14, 2008
    i was in the middle of printing a job(2000 copies total).
    after 1540 copies, suddenly printer stopped with system fault message code 9-363 "turn off & turn on".
    when i turn it back on, everything seems fine until last revolution.
    after warm-up period, printer started turn & stop - system fault message appear.
    i did for complete reset - pulled power code off for 2 hours & switch on - but printer showing same message after the warm-up.
    President:
  • 2,712 Answers
Hello cyfish.
This error is due to defective/malfunctioning rotary sensor. It couls also be that the rotary system did not reach the home position due to some obstruction. See if you can find anything that may obstruct the path, like debris or a torn piece of paper.
To replace/fix the sensor would involve removing the back cover and the rotary power board. If you are not familiar with these procedures, the best in my opinion would be to call a Xerox technician or other competent professional to take a look.
This would probably be in your best interest and avoid any malfunction in the near future.
You can contact Xerox HERE.
Hope that helps!
Posted on May 14, 2008
  • 3,037 Answers
The problem occurs because of the trickle development system in the machine, making extended lengths of black and white copies / prints does not allow the black developer housing to purge itself of excess waste Toner (Dry Ink) and Developer. There are two solutions for the problem:
  • Make 1,000 copies / prints of a black and white job, then make 150 copies / prints of full color. Continue making 1,000 copies / prints of the black and white job, then 150 full color, and so on, until the entire black and white job is complete.
  • Make extended jobs in groups of 100 by making 100 copies / prints of the black and white job, then allowing the machine to cycle down (return to 'Ready') and making the next 100 copies / prints. Continue in this pattern until the entire black and white job is complete.
If it won't even let you print, may I suggest calling 1-800-821-2797 as they will have knowledge of handling this exact problem. Please let me know what they find. Most likely you will have to replace a part in the housing.
  • Benjamin Patri
    Benjamin Patri May 19, 2008
    What is the current situation with this problem? If it is working again, please give me some feedback by rating my solution otherwise let me know if you need further help.
    Have a Great Day!
    Genius:
  • 1,142 Answers
Error 9-363 is the developer housing rotary system did not reach home position. Try to hard reset the machine leave it unplugged and turn it back on after 2hrs and then see what happens.
Update me for the same.
Posted on May 13, 2008
  • 4 more comments
  • Maanita Chadha
    Maanita Chadha May 13, 2008
    Check the fuse too the fuse may have gone
  • Maanita Chadha
    Please provide the make and model of the machine.
  • Maanita Chadha
    May i know the the product in details so that it can help me resolving the issue is a more prompt manner
  • Maanita Chadha
    THE MOST RELEVANT INFORMATION IS HERE
    http://www.support.xerox.com/SRVS/CGI-BI...
    THIS WILL HELP AND RESOLVE YOU ISSUE FOR SURE
    DONT FORGET TO RATE FIXYA
    THANKS
  • Maanita Chadha
  • Maanita Chadha
    1. Power OFF the machine.
    2. Wait 30 seconds.
    3. Power ON the machine.
    The 'Please Wait' message appears on the display. It will take
    approximately 8 minutes for the copier / printer to reach a 'Ready'
    condition.
    CAUTION: The Fuser Roll remains in a cammed-up position if
    power to the copier is interrupted while the copier is in use. The
    Fuser Roll will not be released from its position until the power is
    restored, the Power Switch is in the On position, and the Start button
    is pressed again. If the Fuser Roll remains in the cammed-up position
    for a prolonged period of time, copy quality defects will occur. To
    prevent damage to the Fuser Roll, switch the Power On as soon as
    possible after the power is restored, and make a copy of a document. If
    the machine is a DC 12LP send a print job from a workstation to prevent
    damage to the Fuser Roll.
  • 298 Answers
You can try this, try to clean the dev rotary sensor. open the upper right hand cover then there are two assy's to be removed also for you to access the rotary sensor located inboard side. this sensor senses the home position of rotary developer. to removed this sensor, you have to open the rear cover, then rotary pwb. some 9-363 code is due to busted fuse in the rotary pwb. Or could also be a fault with the fuses.
I have a 'paper jam error' displayed on my HP PhotoSmart 2575 printer screen which I cannot clear, even after removing the paper and pressing OK. In addition, I have reloaded software and this has been...
A few things to check would be to open your printer and make sure there are no little ripped pieces of paper in the system which could be causing it to keep faulting. Also try unplugging it while its powered on and let it sit for 8-10 minutes and see if that doesn't reset it. Hope this helps let me know if more trouble shooting is necessary.
Jul 12, 2009 | HP Photosmart 2575 All-In-One InkJet...
Have lexmark 5070 printer getting error msg saying ccomputer not communicating with printer tried unplugging everything usb, printer
It seems there is a possibility of a problem with the printer itself, or perhaps the cartridges. You should first self-test the printer. Since we are unsure where the problem exists, we must do eliminative troubleshooting to rule out parts of the printing system. The self-test allows us to rule out software and the cable by testing the hardware by itself. Please note that this is not a "fix," but rather a diagnostic test to determine if your hardware is at fault.
Please disconnect and then reconnect the power supply on the printer and make sure it makes a setup noise when the cable is reattached. Will the printer perform a form feed with paper loaded when the purple/silver button is pressed?
Next, I'd like you to attempt this printer self-test by following the steps given below:
1. Press the "Settings" button on the printer.
2. Press the checkmark button when you see "Maintenance" on the display. 3. Press the right or left arrow key until you see "Print Test Page," then press the checkmark button.
The self-test should at least print out a set of either black or color bars, if not both (if you have a printer with both color and black installed simultaneously). Should this test fail, try it again without cartridges installed. If the self-test still fails to take paper in and make sounds like the carrier is moving across the paper, this is a hardware issue, and the printer will require service. If the self-test completes without any cartridges installed, run the self-test again with only the color cartridge installed. (If you have both black and color cartridges, after this test, run the test again with just the black cartridge installed.) If you find that either cartridge causes the self-test to fail, please let us know.
If the self-test prints, but has lines or smudges or other print quality issues, let us know. This includes any print quality issues, we need to know if the problems you have with your black or color are based in the printer, or communications with your computer, or the computer's software.
If the self-test prints your test bar(s) clearly, the printer hardware is not at fault. The issue may be a communication problem, or perhaps a software conflict.
However, please let us know the windows operating system installed on the computer.(Windows XP / 2K / NT, Windows Vista, Mac)
Apr 19, 2009 | Lexmark X4270 All-In-One InkJet Printer
When printing message says x2650 cannot communicate with computer
Next, try this printer self-test by following the steps given below:
1. Please turn OFF the printer.
2. Press and hold the "Color copy" button.
3. Now, turn ON the printer.
4. Once you see "0" on the display, release the "Color copy" button.
5. Press the Up arrow button until "2"appears on the display.
6. Press the "Black copy" button to start the self test. Once the page has printed, the printer will stop printing.
The self-test should at least print out a set of either black or color bars, if not both (if you have a printer with both color and black installed simultaneously). Should this test fail, try it again without cartridges installed. If the self-test still fails to take paper in and make sounds like the carrier is moving across the paper, this is a hardware issue, and the printer will require service. If the self-test completes without any cartridges installed, run the self-test again with the color cartridge installed by itself. (If you have both black and color cartridges, after this test, run the test again with just the black cartridge installed.) If you find that either cartridge causes the self-test to fail, please let us know.
However, please let me know the windows operating system installed on the computer. This information is required for us to troubleshoot the issue further.
Please let us know the name and version of the operating system (Windows XP / 2K / NT, Windows Vista, Mac) that you are using on your computer. This information is important for us to troubleshoot the issue further.
Apr 13, 2009 | Lexmark X2650 All-In-One InkJet Printer
Printer
You can download your driver from Lexmark HERE. Just make sure to select Windows XP as the Operating System in the drop down box.
Oct 23, 2008 | Lexmark Color JetPrinter Z23 InkJet
Xerox docucolor system fault problem
hi please chek and tell what error code showes in your display.. some error codes showing in ur display, pls check it that.
Aug 25, 2008 | Xerox DocuColor 12 Printer
Canon CP 220- HELP
http://www.usa.canon.com/consumer/controller?act=SupportDetailAct&fcategoryid=259&modelid=10073 Here is site for your printer. Try unplugging (from the wall and computer)the printer for a few minutes let it clear out the memory etc. Or even download and install the latest drivers. Let me know what happens. Good Luck, Tim
Mar 01, 2007 | Canon CP-220 Thermal Photo Printer
Xerox DocuColor 12 Printer Logo
218 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Whit
Whit
Level 1 Expert
iteminconline
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
