Question about Dell Latitude D610 Notebook
My computer is flashing 4 red then 1 green light over and over. It won't charge either.
  • 3,940 Answers
Here ya go
http://www.fixya.com/support/r3696096-dell_portable_battery_led_flashes_orange
Posted on Sep 06, 2010
I have a brand new Ryobi kit put battery in the charger the red light goes on and the green light flashers on and off is this charging or should the green light go off until battery is charged.
When the battery is charged the green will be steady on and the red will go off. Flashing green is an indication that it is charging.
hope this helps?
Jan 19, 2016 | Ryobi 18v Combo Kit P845 4-tools/...
Should the power light be green or red, when I turn camera on it shows a green light then turns red
Red light indicates that the camera is out of charged., Try to charged your battery for 3-4 hrs if you encounter flashing red on a fully charged battery you need to call kodak 1 800 235 6325 ext 12
You can charged you camera using 5V AC Adaptor or a USB cable taht attached into the computer
Nov 16, 2009 | Kodak EASYSHARE M1063 Digital Camera
Battery indicator?
Hi there.
Sounds like the battery could be faulty.
The diagnostic procedures from the Dell User Guide are as follows:
Total Power Failure When Using a Battery
If an AC adapter is not connected to your computer, the computer's power source
is a battery. If the battery indicator flashes amber or is a steady amber, the
battery needs to be charged. If the battery is flashing green and amber, the
battery may be defective. To troubleshoot this problem, use the following
procedure.
1. Turn off the computer and peripherals, and disconnect them from AC power.
2. Reseat each installed battery by removing it and then replacing it.
3. Turn on the computer. Does the green power indicator light up?
Allow one minute for the computer to initialize its components before checking
for signs of power.
Yes. Continue to step 4.
No. Use the AC adapter to connect your computer to AC power. If the computer
operates normally when using AC power, go to step 7. If the computer does not
boot when using the AC adapter, see the previous subsection, "Total Power
Failure When Using the AC Adapter."
4. Does the battery indicator flash amber or show a a steady amber light?
Yes. The battery needs to be charged. Go step 5.
No. Go to step 7.
5. Connect the computer to AC power, and fully charge the battery.
For instructions, see the topic titled "Charging the Battery" in the online
System User's Guide.
6. As the battery charges, does the green battery indicator light up?
Yes. Go to step 9.
No. Go to step 7.
7. Is the battery indicator flashing green and amber?
Yes. Your computer may be in a hot environment. Charging the battery in this
condition may affect the life span of the battery. Continue to step 8.
No. The problem is resolved.
8. Disconnect the computer from AC power. Is the the battery indicator still
flashing amber?
Yes. You may have a defective battery. Continue to step 9.
9. Remove the battery, and press its test button. Is the uppermost indicator in
the charge gauge of the battery flashing?
Yes. You have a defective battery. Continue to step 9.
10. If a spare battery is available, fully charge it, and then install it in the
computer.
11. Turn on the computer. Is the power indicator off?
Yes. Your original battery is defective.
Good luck
Jun 01, 2009 | Dell Latitude D600 Notebook
Cant turn it on
1. Charge it 4-7hrs
2. When ready, it must be light up either Green or Red when you PRESS IN on the Up/Dn Volume button
3. Press and hold the Answer button (on microphone boom) for 2-3secs, then Push IN and UP on the Up/Down Vol button'Light should flash Red/Green/Red/Green.....
4. Go to Phone, Enable Bluetoth and tell it to FIND new adapter/Devices
5. When it 'finds' M2500, punch in 4-zeroes (0000) and hit enter/Dial and it should connect
6. When connected, the 2500 will flash BLUE
Thats it!
If it will not charge up (light either RED or Green) the charger is bad, or the M2500 Battery is gone.
I opened mine up and will (!) replace it eventually, but it is consisted of 2 tiny batteries, about 1/4 as long and same diameter as a AAA connected together. They measure 1.3v each, but I think this is SUPPOSED to measure 2.4v. T Open, you have to use force and pry it apart starting at the charger socket end. Go slow and it wont break.
Apr 30, 2009 | Cell Phones
Kyocera Ecosys FS 920
There are actually some certain meaning on the red light and green light showing different information to user. The summaries are:
1) Green On, Red Off = Printer Ready.
2) Green Fast-Flashing, Red Fast-Flashing = Printer warm up.
3) Green Fast-Flashing, Red Off = Printer off-line.
4) Green Slow-Flashing, Red Off = Processing Data.
5) Green Off, Red On = Cover Opened, Toner Empty or Developer Unit / Drum unit missing.
6) Green Off, Red Fast-Flashing = Paper Jam or waiting for jam reset.
7) Green Off, Red Slow-Flashing = Paper Empty or Paper tray is not inserted.
8) Green Off, Red Off = Printer power is off.
9) Green Very-Slow-Flashing, Red Off = Printer in sleep mode.
10) Green (any condition above), Red Slow-Flashing = Toner low or paper empty.
So what is your printer condition? Better know what is going on your printer so can solve the problem.
YBC (/\)
Mar 24, 2009 | Kyocera FS-920 Laser Printer
I have a M2500 wireles headset and a K800i. i have no instructions have to connect the headset to my phone.
1. Charge it 4-7hrs 2. When ready, it must be light up either Green or Red when you PRESS IN on the Up/Dn Volume button 3. Press and hold the Answer button (on microphone boom) for 2-3secs, then Push IN and UP on the Up/Down Vol button'Light should flash Red/Green/Red/Green..... 4. Go to Phone, Enable Bluetoth and tell it to FIND new adapter/Devices 5. When it 'finds' M2500, punch in 4-zeroes (0000) and hit enter/Dial and it should connect 6. When connected, the 2500 will flash BLUE Thats it! If it will not charge up (light either RED or Green) the charger is bad, or the M2500 Battery is gone. I opened mine up and will (!) replace it eventually, but it is consisted of 2 tiny batteries, about 1/4 as long and same diameter as a AAA connected together. They measure 1.3v each, but I think this is SUPPOSED to measure 2.4v. T Open, you have to use force and pry it apart starting at the charger socket end. Go slow and it wont break.
Oct 21, 2008 | Cell Phones
I have a Plantronics M2500 bluetooth headset but i cannot connect it to my phone, which is a Samsung D900.
1. Charge it 4-7hrs 2. When ready, it must be light up either Green or Red when you PRESS IN on the Up/Dn Volume button 3. Press and hold the Answer button (on microphone boom) for 2-3secs, then Push IN and UP on the Up/Down Vol button'Light should flash Red/Green/Red/Green..... 4. Go to Phone, Enable Bluetoth and tell it to FIND new adapter/Devices 5. When it 'finds' M2500, punch in 4-zeroes (0000) and hit enter/Dial and it should connect 6. When connected, the 2500 will flash BLUE Thats it! If it will not charge up (light either RED or Green) the charger is bad, or the M2500 Battery is gone. I opened mine up and will (!) replace it eventually, but it is consisted of 2 tiny batteries, about 1/4 as long and same diameter as a AAA connected together. They measure 1.3v each, but I think this is SUPPOSED to measure 2.4v/4.8v total(?). To Open, you have to use force and pry it apart starting at the charger socket end. Go slow and it wont break.
Jun 17, 2008 | Cell Phones
Plantronics m2500
1. Charge it 4-7hrs 2. When ready, it must be light up either Green or Red when you PRESS IN on the Up/Dn Volume button 3. Press and hold the Answer button (on microphone boom) for 2-3secs, then Push IN and UP on the Up/Down Vol button'Light should flash Red/Green/Red/Green..... 4. Go to Phone, Enable Bluetoth and tell it to FIND new adapter/Devices 5. When it 'finds' M2500, punch in 4-zeroes (0000) and hit enter/Dial and it should connect 6. When connected, the 2500 will flash BLUE Thats it! If it will not charge up (light either RED or Green) the charger is bad, or the M2500 Battery is gone. I opened mine up and will (!) replace it eventually, but it is consisted of 2 tiny batteries, about 1/4 as long and same diameter as a AAA connected together. They measure 1.3v each, but I think this is SUPPOSED to measure 2.4v/4.8v total. To Open, you have to use force and pry it apart starting at the charger socket end. Go slow and it wont break.
Jan 28, 2008 | Plantronics M2500 Consumer Headset
Dell Latitude D600 new battery won,t charge
the charger in the laptop is not functioning. pc will need repaired
Dec 28, 2007 | Dell Latitude D600 Notebook
No 'green' light on bacl of my 'old' Vivitar 285
Then I'd say it's a reasonably sure thing that the green light is just burned out, The lights are supposed to be off at first, then red when there's a partial charge, then green when there's a full charge, then flashing between red and green when the "battery saver" kicks in. If you're seeing off, then red, then off, then flashing red, then that means everything in the charging circuit is working perfectly, there's just no green light.
Nov 30, 2007 | Vivitar 285HV Flash
Dell Latitude D610 Notebook Logo
Alun Cox
