Question about HP Cameras
HP PHOTOSMART E427 CAMERA IT WORKS FINE WITH NO SD IN IT BUT WHEN I PUT ANY SD IN THE CAMERA IT SAY THAT IT DOES NOT HAVE THE RIGHT FORMAT... note, it gives me an option to format or cancel ive chosen both in diffrent occasions but it then says card not readable when i select format
  • Jack Feb 15, 2012
    I have that same problem but the solution isn't working for me. Every time I erase the memory and then put the card back in again it says that I don't have the right format of card. Any help?
    Brigadier General:
  • 11,967 Answers
1. With no card in the camera, go into the menu and find "format"...follow the on-screen instructions to erase the internal memory. 2. Insert the card and again, go into the menu and do the format thing again. Do not stop to select one of the choices the camera has offered before. Go straight into the menu and format from there.
Posted on Sep 06, 2010
I got the e327 photosmart, and I jsut put in the 8gb sd card in the camera. Does not work. It wont even let me format the card at all. The screen turns on but I cant even take a picture. Can this camera...
The E327 works with SD cards. Your 8GB card is actually an SDHC card. While it fits into the slot, it's electronically incompatible and will not work in devices not designed to accept SDHC cards. You need to use SD cards, 2GB and smaller.
May 17, 2011 | HP Photosmart E327 Digital Camera
I have HP Photosmart R827 with the same problem. when I was uploading stuff onto my memory card I might have hotlinked and when I disconnected it said "Card Unreadable" and told me to format. i...
memory cards can become damaged. this can be from removing it at the wrong time or a file become corrupted, it can wipe the format off the card. and will need reformatting. dont do this on the camera as it can put the wrong format on the card. doe this on a pc, it will probably say when you instal the sd that it needs formatting. click yes, a box will appear and have it all set out for you but don't click format yet, in the box where it says restore device defaults click this. and then press to format. this will put it as the best for any device its being used for. if you had anything on the sd card before it will not be there before or after the format. hope this helps.
Jul 01, 2017 | HP Photosmart R827 Digital Camera
When i put my sd card into my camera it needs to be formatted
Having received no response in over a month, I assume this is no longer a problem.
Jun 04, 2010 | HP Photosmart E327 Digital Camera
Formating SD card
You can do the steps indicated in this manual:
Hope this helps you. Please let me know.
Sep 22, 2009 | HP Photosmart 735 Digital Camera
The card on my Photosmart HP E427 appears to be locked all of the sudden. I get a message that says "cards is locked" - What caused this and how do I unlock the card?
SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Mar 17, 2009 | HP PhotoSmart M437 Digital Camera
Can't format 2 GB sd card for HP 735 camera
Make sure the SD card is unlocked. There's a tiny switch on the side. Put it into the camera. Under storage, when you select the card, also select format.
Mar 13, 2009 | HP Photosmart 735 Digital Camera
HP photosmart E427 camera--No power!!!
dear,
if you are a technical person or can handle the electronics then open it from the screws and see if the cable or points that connects battery to the circuitry are broken or desoldered or unwired...
if you cannt handle it so dont try.. get it repaired by a technical person near u...
regards,
Oct 26, 2008 | Cameras
Sd card formatting
Does SD card work in PC? HP R707 will not work with SD card larger than 2GB.
Oct 22, 2007 | HP Photosmart R707 Digital Camera
Memory card problem
use batteries with higher mah value prefereably above 2000 mah .use energizer or duracell
Sep 17, 2007 | HP E427 Digital Camera
Won't read sd card - says card not suppoorted
Did you try putting the card in the camera, and using the camera's "format" card option?(Make sure there is nothing on the the card-a format will delete it.) Often times, a digital camera requires a format of the card so the proper file/directory structure can be created. If the card is empty, you have nothing to lose.
May 21, 2007 | HP Photosmart M417 Digital Camera
Cameras Logo
82 people viewed this question
Top HP Cameras Experts
Fred Sops
teddyboy
Lawrence Oravetz
Are you a HP Camera Expert? Answer questions, earn points and help others
