Question about Pari Proneb Ultra II Compressor Nebulizer System
My nebulizer appears to have stopped working properly. The airflow seems a bit constricted as it doesnt seem to be blowing air out very hard. After putting the medicine in and turning it on, I am not getting the cloud of smoke as I should be. I am putting everything on correctly and the medicine is in. I know this because I have been using this nebulizer for months now, and just recently it stopped working. Should I take it apart and see if something is wrong inside? Please help, thank you.
On my wifes 2006 chrysler sebring air blows cold and hard in town once on the highway it seems to stop blowing hard , its still cold it gets loud like the air is blowing but , just not all out the vents
Do you live in a High Leaf Area? The Cabin Air Filter could be blocking the system. Additionally, there is a resistor that is common on Dodge's to go bad and cause the fan not to work properly.
Apr 05, 2013 | Chrysler Sebring Cars & Trucks
Omron vibrating mesh nebulizer quit working
You must be having trouble with the battery. Also please keep the nebulizer properly cleaned as instructed on the pack. Check the connection properly or replace the batteries if needed. Also check out for more information about Omron Nebulizer on the web. It would help you a lot.
Aug 06, 2012 | Omron Health & Beauty
The ac is not blowing air
there is a resister for the blower motor near the motor under the dash behind the glove box the connectors over heat then they loose electrical contacts look at the connector for melting
Jul 12, 2012 | 2004 Cadillac CTS
2006 Nissan Quest - Overheats when sitting idle, A/C won't blow cold when sitting idle, A/C knob will only blow from the face vents when on Max A/C and changes blowing direction on any other setting,...
All seperate things, usually. I'll address these in the order they appear in your note....
It is normal for the A/C air to warm up a bit when sitting, less airflow thru the condensor. However, if the cooling fan(s) are not working properly both the A/C air and engine temp will rise higher than usual.
All A/C's only blow from the dash vents when on MAX.
Drivers window switch could be bad, or the safety sensor is faulty. It sense's upwards pressure, and if to great it will reverse the window. I believe the thought here is to prevent a child from choking.
The tire sensor. If you are refering to the air pressure sensor, it could just be bad, missing, or dead battery.
Aug 30, 2011 | 2006 Nissan Quest
Airflow from heater/ac seems to be constricted or blocked
some time the squirel cage is full of trash and leaves. take the blower motor out and see if there is any.
Feb 28, 2010 | 2000 Dodge Caravan
A/C blows warm air
Have your a/c tech look at the pressures at an idle. It sounds like the condensing coil does'nt have enough airflow or the compressor is week. Another possible problem could be that the temp control door is'nt operating properly. Hope this helps. Good luck.
Jun 11, 2009 | 2003 Jeep Grand Cherokee
07 ranger stx a/c problem not blowing enought air
hi one of your plastick vents has come of your main vent please check that all vents are ok in there right spots cheers peter
Jul 21, 2008 | 2007 Ford Ranger FX4 Off-Road
Pari Proneb Ultra II Compressor Nebulizer System Logo
232 people viewed this question
Top Pari Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Pari Health and Beauty Expert? Answer questions, earn points and help others
