Question about Ricoh Aficio MP 1600 Black and White Copier
Functional problem sc 302 in ricoh photocopier model aticio1600
  • 5 Answers
The charge roller in the drum unit is faulty or need to be cleaned.strip the drum unit and clean the unit
Posted on Sep 06, 2010
  • 70 Answers
Charge roller current leakage, replace charging assembly and check power pack.
Ricoh Errors
Posted on May 20, 2011
Functional problem sc 302 in ricoh photocopier model aficio gestetner 1802d, pls help me out, nobody want to help i begged you all. mordecai Olugbenga.
that is a charge roller leak error. try a different photo conductor see if it goes away. If so could be charge roller bad or drum . if it has more then 60,000 copies on it rebuild it .
Mar 04, 2017 | Ricoh Office Equipment & Supplies
How could I solve sc 302
sc 302 cause dirty copy, if u see the dram it is dotted, replace dram or charging roller..
Sep 25, 2014 | Ricoh Office Equipment & Supplies
How to solve this problem sc 302
Hi
I managed to find a list of Ricoh error codes with brief explanations of their causes here:
Ricoh copiers error code messages
This clearly identifies the problem as a laser motor problem - OR
Charge roller, HVT, or fuse FU5 (AFICIO 340, 350 series, 355, 450 series, and 455) - OR
SC-302-01, 02, 03, 04 Charge corona assembly Aficio 550/650
SC-303 Charge corona wire cleaner, disconnected or time out for printer.
All of these sound rather like an engineer requirement but you may be able to something with appropriate spares
My printer ricoh 2045 show an error sc 302,not print image correct
i have an error on my printer sc 302 how i can clear it easily .printer is ricoh 3045
Aug 11, 2011 | Ricoh Computers & Internet
Error occured SC:302 Functional Problem Turn main power switch off and on if the error appears again. Call Service
SC:302
Symptom: A current leak signal for the charge roller is detected.
Possible Cause:
?? Charge roller damaged
?? High voltage supply board defective
?? Poor connection of the PCU
May 27, 2011 | Ricoh Aficio MP 1600L Black and White...
Sir, My copier model RICOH MP 2000Le shows error . ADD TONER & some time it shows SC 302
sc 302 - charge roller current leak. strip the drum unit (dmu) and clean the unit
Sep 04, 2010 | Ricoh Aficio MP 2000 Black and White...
Ricoh Aficio 1018 photocopier
For the Aficio 1018. SC-320 is laser failure - the polygon mirror motor inside the laser has failed and needs replacing. You will need to contact your nearest service agent for repair.
For your RICOH Aficio 1013F - SC-551 is overheat in standby mode as far as I can tell. The circuitry that controls the fuser section ie manages the heat has problem. Unless its right near a source of heat like a heater or has no circulation around you machine you will need contact a repair agent for this machine also.
Mar 18, 2008 | Ricoh Aficio 1013F Copier
Ricoh Aficio MP 1600 Black and White Copier Logo
1,171 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
