Question about Whirlpool 24 in. DU1100XTP Built-in Dishwasher
After a cycle the dishes have goop on them, almost like caramel. it doesn't smell and the goop is about the size of a pin head or smaller. We tried changing detergent but it persists. What is it and what is the solution
  • 901 Answers
If it is a lime scale deposit, check your inlet water quality.
If the dish water support salt for softening water add the salt in the
correct compartment provided in the machine.
Check rinse aid for dispensing! Check the level and refill
rinse aid liquid.
Run a empty cycle and clean the machine.
Posted on Sep 06, 2010
Is drinking caramel frappuccino 3 times per week bad for you?
That would depend on your current medical condition.
Jan 04, 2017 | Restaurants
Dishwashwer not cleaning dishes at all, though it runs through a complete cycle.
try removing spray spinner and clean out holes the spray heads get blocked and stop water flow, or you may be able to remove spray nozzles and clean out , i had this several times in the past also make sure the base drain filter is clean some times the small holes in the filter get smaller and smaller reducing water flow
hope this is of some help good luck
Aug 02, 2016 | Bosch SHE5AL06UC 24 in Builtin Dishwasher
Electrical burning smell coming from control panel on westinghouse dishwasher
Had the same issue with a 903sa. Strong burning smell. Continued to run for a while then just died. Opened the control panel (4 screws holding the plastic part at the top of the door on - open the door to access).
Mains feed into the controller was totally fried. Case was all melted. Very nasty. There was nothing obvious on the Board other than a mains resistor that looked like it had been pretty hot at some stage. The three pin mains connector (at least I think it was 3 pins) was just a big, charred bit of goop.
Feb 09, 2014 | Westinghouse Dishwashers
1998 olds intrigue keeps running out of radiator fluid and hoses good
Is fluid leaking onto the ground? Onto the front floor? . If you cannot find an obvious leak, you may want to check you oil when car is cold. Look for traces of white goop, or water in the oil. Smell dipstick and see if it smells like gas . I'm leaning towadrs a head gasket if you cannot find a leak. More details will be needed to say anymore. Have a look for leaks first
Jan 13, 2013 | 1998 Oldsmobile Intrigue
Why do dishes stink when they come out of dishwasher?
try running the dish washer on the heated cycle and use a quality wash detergent not ordinary washing up liquid
Apr 14, 2017 | Maytag Dishwasher
Today, while watching tv on the Dish, tv suddenly started powercycling. I unplugged it, waited, and then tried a DVD -- worked fine. Tried Dish again, power cycled again -- on off on off, 1/2 second of...
If you are using a powerstrip may not be supplying enough power to run the LG HDTV and your HD receiver. If you are using a powerstrip make sure the receiver is plugged directly into the wall. Otherwise this may be a grounding issue please reply if this doesn't work and we can look into some other possibilities.
Daniel Busa
DISH Network
Customer Service
May 16, 2011 | LG 47LD520 47 in. HD-Ready LCD TV
Nailer drives one nail but driver pin doesn,t retract back into nailer head
Remove the air hose and open the nailer head section. Look for a foreign object in this are that could be jamming the drive pin. Also, make sure you are using the right size nails.
Jul 11, 2009 | Craftsman Nailer Kit, Palm Air Driver
Bad smell on dried dishes after being washed.Stale water smell.
Try Running Goo Gone Through It Although It Smells Like Oranges It Removes Stains As Strong As Sap. Also Try Running The Dry Cycle While Its Empty Two Or Three Times.
Jan 06, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
correct, no filters to clean, but what you are smelling is soap residues that have built up on the heating element and when it goes thru the heat dry cycle, it burns the soap causing the odors.
trying the cleaners you have may help but the cause is the residues. you need to use a d/w cleaner like d/w magic or citric acid. if you just run the unit with the waterheat option and vinegar in a bowl right side up in the top rack, it should rinse out the residues then dont use to omuch soap and only use dry powder soap. no tablets or liquids.
run hot water at the faucet first and then be sure to use the heat option. it may take a few cycles to get rid of the odor but it will go away as you get the unit cleaned out.
Jan 06, 2009 | Dishwashers
Smell in LG LDF8812ST
First, scrape your dishes clear of food before putting them in.  Rotten food makes smells.  Second, use a good brand of detergent in the recommended amount and use the heating cycle to heat the water up.
Most dish washers have a dryer heat cycle but this one apparently does not.  This may cause mold in the machine.
How to get rid of the smell:  With no dishes in the machine, add half a cup of bleach in the bottom of the unit and do a full wash cycle.  If the unit still has an odor, get some baking soda...about a half cup and put that in the bottom of the machine.  Close the door and leave overnight.  Then, run the machine through one wet cycle...say a wash cycle and then it should stop smelling.
Hint:  When leaving dishes in the machine between uses, leave the door ajar...do not close tightly.
Nov 13, 2008 | LG 24 in. LDS 5811 Built-in Dishwasher
Whirlpool 24 in. DU1100XTP Built-in Dishwasher Logo
91 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
