Question about Polaroid i830 Digital Camera
The zoom lens will not come out - Polaroid i830 Digital Camera
  • 6,831 Answers
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
Hope the advise is useful.
Regards
Andrea
Posted on Sep 06, 2010
How do I zoom in and out on a photo?
This camera has a 9mm lens, and while shooting, you can't zoom. For that you need a zoom lens. You can buy one from Samsung.
I checked the manual, and it also does not show how to zoom in on a picture when it is on the display. So I guess, you should view it on a computer, or tablet ant use the picture viewer on that device to zoom in.
Be aware you have a great camera and the result with a prime (one focal length) is superior to the results make with a zoom lens.
But if you don't like to move around, to farm the picture, a zoom lens can be convenient.
Oct 07, 2014 | Samsung Nx Mini Smart Camera With 9mm Lens...
Best telephot zoom lense for my canon 1000d
That's a decision only you can make. What's most important to you? Long focal length? Wide zoom range? Lens speed (maximum aperture)? Weight? Cost?
Also, what do you want to do with the lens? The best zoom lens for taking wedding pictures is not necessarily the best zoom lens for taking sports pictures.
Jan 25, 2011 | Canon 75-300mm f/4-5.6 III USM EF Lens
Fujifilm finepix j38 series reads zoom error and wont take a pic.
If you have some skills, you can open the camera and cline your zoom lens with toothbrush and compressed air. Try to separate zoom lens from the electric motor. usually is 2 or 3 screws. You will see a lot of sand inside the camera and lens. And next time when you will go to the beach, you will take more care about your camera.
Solution 2, and more easy is to buy another zoom lens from ebay.Or another camera same model with broken LCD or other technical problem than zoom lens.
May 31, 2010 | Fuji Cameras
How to zoom in using Canon EOS Rebel XS?
Zooming is done from the lens on a DSLR, assuming you have a zoom lens on the camera. For example, if your camera came with the 18-55mm lens, you should see the numbers 18, 24, 35 and 55 on the lens barrel with a white index line next to one of the numbers. Turn the barrel to move a different number next to the index line. 18mm is wide angle, 55mm is 'zoomed in'.
Mar 12, 2010 | Canon EOS Digital Rebel XS / 1000D IS...
How to achieve full zoom with a Nikon 55-200mmf/4-5.6G ED lens?!
1) What camera body are you using?
2) I do not understand your assertion that it automatically zoomed in. Zooming is a manual function. The automatic functions of your lens pertain only to focusing on of the subject so that your picture is sharp and ensuring that the correct amount of light is admitted so that you have a correct exposure.
3) Are you sure you were turning the zoom ring and not the f-stop ring? The zoom ring is labeled 200 on one end of the scale and 55 on the other. It is also the widest ring on the lens barrel. When you rotate it, the physical length of the lens will lengthen as you rotate it clockwise (viewed from behind the camera) and shorten as you rotate it counter-clockwise.
4) For reference, at 200mm the angle of view on your lens should be 10 degrees and at 55mm about 40 degrees.
Dec 27, 2008 | Nikon Zoom-Nikkor 55-200mm f/4-5.6G ED...
Zoom lens is "locked"
Is there a little lock switch on the lens?? My Nikon lens all have a tiny little lock and if it accidentally gets pushed into lock position it will not zoom. Barry Brown www.coralreefphotos.com
Aug 18, 2008 | Quantaray Tech-10 70-300mm f/4.0-5.6 Lens...
Optical zoom
Hey needacamera,
The range of an optical zoom lens refers to how wide angle to telephoto the lens covers. An example of a 6x optical zoom would be an 18mm-108mm lens, which covers wide angle to telephoto. An example of a 3x zoom lens would be an 18mm-54mm lens, which would provide a capability of capturing images from wide angle to normal views. To calculate the x factor of an optical zoom you would divide the largest number by the smallest number on your zoom. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
May 31, 2008 | Cameras
Zoom Lens doesn't Zoom
Check you haven't accidentally got the camera into some fixed-zoom mode ("Super-Macro" is a favourite for this on Olympus cameras).
A.
Apr 06, 2008 | Olympus Camedia C-765 Digital Camera
Zoom Lens
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension.
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but they're still worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Jan 11, 2008 | Fuji FinePix A303 Digital Camera
Polaroid i830 Digital Camera Logo
Top Polaroid Cameras Experts
Greg Cann
Greg Cann
Steven Wander
Steven Wander
Are you a Polaroid Camera Expert? Answer questions, earn points and help others
