Question about Daewoo Washing Machines
Dear sir my Daewoo Washing machines DWF-1098PS did't working perfactally when I want to rinse & spin my clothes the machine gives me Puzzy sound & lamp indicate LE & stop all bottoms no working could U help me please Thanks
  • 1294 Answers
SOURCE: daewoo dwf-6094r wont spin on spin cycle
You need to clean out your outlet filter;(which is accessible thru the front bottom right side of machine, small push door, or plastic screw) this needs to be done periodically - according to your usage. If this does not solve your problem check out your outlet pump. Plug off the wall first before you do the jobs. The machine will not drain water if the outlet is clogged. For the pump, tubes, etc you hav to open up behind the machine. Be prepared for water to come flowing out.......
And rate me pl, if the solution has worked......
Posted on Dec 02, 2007
SOURCE: daewoo washing machine dwf-75ts
Found the manual for a similar model. LE error code indicates a "Lid Open" error. Most likely the little switch that is tripped when you open the lid has failed due to corrosion or some other reason. If you can find an equivalent switch then replacing it should do the trick. Otherwise, you can simply short the connection so the machine thinks that the lid is always closed. WARNING: This effectively overrides the open lid detection system and poses the risk of having the unit run a spin cycle even with the lid open! find a replacement switch if you can. good luck! just shorted mine out temporarily and it works -- until i can find the right switch.
Posted on Jun 10, 2008
masteria
  • 355 Answers
SOURCE: what is LE error for Washing Machine Daewoo DWF
In other Daewoo models LE error code means pressure sensor failure. This sensor is used to know water level in the tube. It is probable that your model reports the same codes.
It does not necessary means a broken sensor you must check the electrical connectors and cables as well as all the mechanic and pneumatic elements like the hose connected to the sensor.
It is often clogs with soap and other particles.
Good Luck!
Posted on Jun 16, 2009
  • 215 Answers
SOURCE: Water overflowing during use
Seems like blockage in pressure system, machine will always think it is empty if so. Pressure system is under the lid, a round switch with a thin pipe going to it. At bottom of this pipe it is probably blocked with limescale or residue from detergent.
Posted on Feb 12, 2010
  • 3 Answers
SOURCE: The washer was not rinsed
check suis door
Posted on Apr 09, 2010
What is the exact belt size of Daewoo Fuzzy Logic washing machine 7.5 kg dwf-75ts? Where can I order this?
Hi,if you still have the old belt,take it to the shop and ask them to give you a replacement.
all the best.
Apr 28, 2015 | Daewoo Washing Machines
DAEWOO WASHER DWF-800WPS machine the outer water is countune going out what is the problem
pump is running and not stopping, low water sensor is not working properly, replace part. it is behind control panel .
Jan 11, 2015 | Daewoo Washing Machines
Daewoo washing machine not working
I have a problem in hitachi automatic machine SF 95GJ in which the spin is very slow now the impact fast spin action is not activated to wash and rinse the clothes. kindly give some solution.
Jan 03, 2014 | Washing Machines
My Daewoo DWF 806 MP doesnt dry/spin after washing and rinsing and shows LE error. When drying starts some sound comes and then LE error apperas
my Daedwoo DWF-806 MP machine when i swith on shows figure 49 and not figure 0, and it also making noise like Buzz in between when the machine is ON. Can anybody help me to resolve this defect
thanks
Nov 01, 2013 | Daewoo Washing Machines
Daewoo nano silver dwf-170mp
This Daewoo top load washing
Machine is the worst washing machine ever. Tried to call their maintenance many times still the problems coming back. Water flowing non stop, i need to spin it first to work properly. They repair it but the problem coming back always and its not abyer yet. My advice dont ever buy this machine again.. Its a full waste of money
Oct 17, 2010 | Washing Machines
I have a DAEWOO DWF-1150P top loader washing machine and when I switch it on I get an error code E9. Can you please tell me the fault and how to repair it?
I have a daewoo top loader washing machine ,,
Mode W/M-DWF-200MP
The power main board does not take the programs to work how should be its olny one program
Apr 29, 2010 | Daewoo Washing Machines
Washing Machines Logo
77 people viewed this question
Top Daewoo Washing Machines Experts
Paul Bade
Are you a Daewoo Washing Machine Expert? Answer questions, earn points and help others
