Question about Microsoft Xbox® 360 Core System Console
XBOX 360 Core system
XBOX wont read game disks or DVD's. close tray and it will just reopen. If I put in a CD it will close and play just fine.
    New Friend:
    Problem Solver:
  • 8 Answers
If cleaning the laser does not work you will need to by a new one you can find them from e bay and a tutorial on www.llama.com or YouTube.com
Posted on Mar 02, 2013
  • 68 Answers
There is something in your xbox 360 called a lens and that what makes the xbox read cds so try this go to a store like walmart or maby even a local store and find something called a laser lens cleaner this can clean a lot of stuff game consloles cd players dvd players and probaly more so over the years haveing a xbox 360 it collects dust on the lens and does not read good
Posted on Jun 23, 2008
What do you do when your xbox won't read disks?
The main problem might be a big problem with the disk tray. There might be an faulty wire that has lost connection and if your disk wont event turn on, there might be a problem with the power supply that supplies the cd tray. If the disk opens and closes but doesnt read and wont say tray is in and keeps saying open tray, there might be a small fracture on some of the wires or there is something wrong with the motherboard of the xbox 360. The best way is to buy the warrenty now and send it to the xbox 360.
Jul 27, 2011 | Microsoft Xbox 360 Console
My Xbox 360 isn't reading any discs. Games nor Movies. When i put either in the game console it tells me to open the tray because it didn't read.by the way it makes a funny noise when it tries to read the...
take out the cd. close the tray with no disk in it. let it read till it says open tray
open and close it like 3 times with tha method mentioned above with out the disk. then put the disk back in and it will probly work.
sometimes the system turns dumb and u haft to remind it to reconize when there is actally no disk.
Oct 25, 2010 | Microsoft Xbox 360 Console
Wont read games only reads dvds
This is going to be a bit long -- but very detailed, so please read it carefully. There are several reasons that an xbox 360 system will have problem reading discs. The error messages also vary from unreadable disk, no message at all but the game skips, "please insert disc in a 360 console" to "open tray." There are a few reasons this may happen:
1.Bad disc. Check the back of your disc for scratches. If it looks good (or plays fine in another console), then the disc is probably fine. Also-- try more than 1 game to be sure.
2. Bad laser. The XBox 360 has a DVD drive very similar to a PC's DVD drive inside. The drive contains a bunch of parts including a few motors and gears and a laser.The laser is the part that actually reads the disc. The reality is...with all the hours and hours of game play, lasers do eventually wear out. The laser isn't very easy to replace, but it is replaceable. You can find any and all XBox 360 lasers at the following website:
http://store.richspsxparts.com/xb360ac.html
3.Bad DVD Drive. Sometimes other components inside of the DVD drive can become bad such as the motor that spins the disk, the motors that open the tray, etc, etc. You can get a new DVD drive to just replace everything,including the laser, in one shot but there is a catch. The XBOX 360's DVD drive is tied to the motherboard using a software lock.The easiest way to overcome this lock is to buy the exact same manufacture DVD drive that is in your system now, remove the circuit board from the old DVD drive (which contains the software key) and transfer the circuit board into the new DVD drive that you purchase. If you do this simple procedure, there is no flashing involved. The following website carries DVD drives and also provides instructions on swapping the circuit board from the old drive into the new one.
XBox 360 parts: http://store.richspsxparts.com/xb360ac.html
DVD Drive Swap Info: http://store.richspsxparts.com/imnooninxb36.html
May 15, 2010 | Microsoft Xbox 360 Pro System Console
My xbox 360 will never read the game i put in it always says open tray.
try a Music CD Or DVD Movie ??
also try using a cleaning disk, incase of any dust on the laser head.
If none of the above work, the DVD Drives laser Unit, has weakened/Failed. And the drive should be suitably repaired, Or replaced.
Mike @ Compurepair.
Nov 05, 2009 | Microsoft Xbox® 360 Core System Console
Put cd in then it says open tray wont play cd
Hi. this open tray code is caused by a failed limit switch that is responsible for sending a signal to the optical assembly, confirming that the tray is totally closed and ready to read the disk. this switch is part of the drive and, it is recommended to replace the DVD-ROM drive in this case.
Jun 03, 2009 | Microsoft Xbox 360 Console
My xbox 360 doesn't play my games
it could be that u got **** like food in your x box360 open it up and clean it out put it back to gether and try it if this dose not work tell me at alexswierenga@yahoo.com ty
May 29, 2009 | Microsoft Xbox 360 Console
the lens of the disc drive needs a check up...
Its definately an internal problem, just have the people at microsoft repair your console.
Xbox 360 disk tray wont stay shut
My 360 is/was having a similar problem...my 360 would say "reading disc" then "open tray". Well since my system is only about 8 months old...I opted to send it in for repair. Its under warranty. My system is in route to be fixed as we speak. I would advise you to get yours registered too.
May 28, 2009 | Microsoft Xbox 360 Console
Do Not Call The Hot Line, 100.00 Dollars to just look at the problem thats not even fixing it. Waste of my time and money for there f--- up man.
Aug 25, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox® 360 Core System Console Logo
143 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
