Question about Microwave Ovens
I have a whirlpool oven/microwave combo, model number GMC305PD. I had to replace the oven latch because it melted from doing a self clean (2nd time this happened in 2 years) Anyhow, when I was done the microwave wouldn't heat and smells and looks like smoke from the magnatron side of the microwave. I replaced the magnetron and the HV diode, but I still have the same smoking real bad. Is it a transformer of the HV cap?
  • Eric Brinker Sep 12, 2010
    I have a whirlpool oven/microwave combo, model number GMC305PD. I had to replace the oven latch because it melted from doing a self clean (2nd time this happened in 2 years) Anyhow, when I was done and put everything back together the microwave wouldn't heat and smells and looks like serious smoke from the magnatron side of the microwave. I replaced the magnetron and the HV diode, but I still have the same smoking real bad. Could it be a transformer or the HV cap? I tested all 3 transformers I could see and they courently test short. Of course, that doesn't mean one isn't on it's way out. Would the microwave not heat with a new HV diode, new magnetron and a transformer smoking like crazy? I'm not sure where to look or what to test with the meter. Thanks
  • 10,515 Answers
Is it only smoking or do you hear any buzzing sound ?
Thanks!!
Posted on Sep 12, 2010
  • 3,083 Answers
It most likely is the transformer heating up. Look for discoloration on the transformer. Caps can burn up, but they usually swell up and explode or crack. Also, I've read that it isn't good to use the self clean function on many types of microwaves, as this can cause problems. This situation isn't normal, and you need to contact Whirlpool about this problem. I couldn't find your unit on a recall list, but perhaps it should be (some of the GSC models were on the list).
Here's Whirlpool's support page:
http://www.whirlpool.com/custserv/index.jsp
Good luck, hope this helps, and thanks for using FixYa.
Posted on Sep 06, 2010
How can I close the oven door to my Whirlpool GMC305PRB01 Oven and Microwave combo?
We're very sorry to learn of your concerns regarding your Whirlpool® Microwave. We would like to inquire further about your review with you. Please respond back to this email address Whirlpool_Reviews@Whirlpool.com with your Reviewer ID, the name of the site you were contacted on (fixya.com), name, phone number, street address, zip code, model & serial number, and date of purchase on the appliance. Please include a brief description of your concerns in your email. Thank you.
Sep 12, 2017 | Whirlpool Microwave Ovens
Tip
Troubleshooting KitchenAid oven, range and microwave error codes
Here list of Kitchen Aid range and oven codes.
4 Digit Failure Codes
F1 - E0 EEPROM communication error
F1 - E1 EEPROM checksum error
F1 - E2 UL A/D error
F1 - E4 Model ID error
F1 - E5 Calibration shifted
F1 - E6 Latch signal mismatch error
F1 - E9 Stack overflow
F1 - E3 Wiring harness cavity size does not match stored value
F2 - E0 Shorted touch pad
F2 - E1 Keypad cable connection error
F2 - E5 Cancel key drive line open
F2 - E6 Cancel key drive line open
F3 - E0 Oven temperature sensor (RTD) opened (upper oven on double oven models)
F3 - E1 Oven temperature sensor (RTD) shorted (upper oven on double oven models)
F3 - E2 Oven temperature is too high (Cook mode)
F3 - E3 Oven temperature is too high (Clean mode)
F3 - E4 Oven temperature sensor (RTD) opened (lower oven on double oven models)
F3 - E5 Oven temperature sensor (RTD) shorted (lower oven on double oven models)
F3 - E6 Drawer sensor open
F3 - E7 Warming drawer sensor shorted
F4 - E1 Meat probe malfunction - shorted
F5 - E0 Door Switch
F5 - E1 Self clean latch will not lock
F5 - E2 Latch during CLEAN error
F5 - E5 Self clean temperature not reached within 45 minutes.
F5 - E6 Door is open, but latch is locked
F5 - E7 Self clean latch will not unlock
F6 - E0 Return line not connected
F7 - E1 Common switch wire defective
Two digit codes:
F0 ERC Board failure
F1 ERC Board failure
F2 Oven temperature is too high
F3 Oven temperature sensor open
F4 Oven temperature sensor shorted
F5 ERC Board failure
F7 Function key stuck on ERC
F8 ERC Board failure
F9 Oven door lock failure
Microwave and Microwave combo error codes:
F1 - E3 or F1 - E4 Electronic control malfunction
F2 - E0 or F2 - E1 Keypad connection error
F2 - E3 Keypad held down too long, or keypad is shorted.
If you get an error code, try first resetting the code:
1. Disconnect power for about two minutes.
2. Connect back power.
3. If code re-appears, test and eventually replace faulty part.
Regards.
on Mar 27, 2010 | KitchenAid KHMS155LSS 1000 Watts Microwave...
How do i fix a whirlpool microwave and range hood combo
869a8192-23d2-4ffd-9f6d-9d352dca9204.pngWhat is the model number? F-6 is a Microwave Relay Failure.
1. Check wiring to Relay 4903 for short circuits.
2. If wiring is OK:
• Unplug microwave oven or disconnect power.
• Replace electronic control.
• Plug in microwave oven or reconnect power.
Sea Breeze
Jul 25, 2013 | Microwave Ovens
Door error message on microwave whirlpool Gold rmc275pd
This indicates the door is not latching. The simplest fix is if it really isn't closed, and simply pressing on the door does the trick. Not so lucky? Latch mechanism itself may be dirty and not latching. Try cleaning it with standard spray kitchen cleaners and a good scrub, followed by a toweldry. Still no good? There's often an electronic interlock-- a place outside the latch, perhaps along the face of door, which must contact the body of the microwave oven. Again, try cleaning all possible contact areas. No? OK: microwaves are designed not to run without a tight seal to prevent emissions. perhaps the seal itself is damaged. Finally, and most unhappily, and expensively, the electronics module in the combo unit is shot. If the appliance is under warranty you're in like flynn; if it's relatively new but not under warranty, call the Whirlpool service 800 number and very politely but firmly remind them that this is really quite a new unit and certainly their products aren't meant to fail so soon... and surely they have a service bulletin because this can't have just happened to you... This will usually result in (oh happy day!) a free service call or (more common) a deal to sell the part at half price. Better than nothing!
Jul 03, 2012 | Whirlpool RMC275PD Microwave Oven
Need to know how to self clean a whirlpool oven... Model number RF302BXDW it is suppose to be a self cleaner, but does not have a cleaning mode.
I checked the owners guide here:
https://www.whirlpool.com/digitalassets/MLPDF/Use%20and%20Care%20Guide%20-%203189066.pdf
The cleaning steps are on page 23 of the manual.
Note the comments about using a commercial oven cleaner
("Easy Off" is one oven cleaning product that works well)
One product I find that works well on all oven surfaces is Mr Muscle kitchen cleaner. I have a real hard time finding it in the USA stores. Product image and description Link below:
http://www.mrmuscleonline.co.uk/kitchen
Thanks for choosing FixYa,
Kelly
Jul 17, 2011 | Whirlpool Microwave Ovens
How do I use the self-cleaning function on my Whirlpool Super Capacity 465 self-cleaning oven?
If you just want to run the basic self-clean cycle. First remove the broiler pan and racks from the oven. Next clean any heavy spills up with a non-abrasive cleaner (do not use an oven cleaner). Clean the window of the oven door and the door frame (to the outside of the gasket). Then close the oven. If the oven has a touch-pad, press the Auto-clean pad on the oven followed by Start. The oven will automatically lock and then unlock when the oven has cooled after the cleaning cycle. (I'm less certain of the control settings for the dial type of oven control.)
In order to get your manual you need the full model number of the oven. This is on a plate located behind the storage door. This pdf, http://adcxns1.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/ca8e028c60d9804f85256a8c00621f04/$FILE/4322089.pdf , gives you a picture of where the model and serial numbers are is on page 4 as well as some of the information contained in the serial number on the subsequent pages.
Once you have your model number, go to http://shared.whirlpoolcorp.com/product_literature/search.jsp?siteCd=WHRCOM and enter the model number. This should let you get the manual specific to your oven.
I hope this helps.
Apr 26, 2011 | Whirlpool Microwave Ovens
One of the interior latches, or hooks,(rear) which hold the metal rack in place has melted and has begun sparking while the oven runs. Im wondering where to find a replacement and how to access the latch...
Ken, I have the same problem . . . I was told by the company that I need to replace the overn as the inside wall is burnt so it will happen all the time. . . have you found a soultion or heard any differently/?
Dec 07, 2009 | Whirlpool Microwave Ovens
I have a Whirlpool gold accubake microwave / oven combo model number GMC305PDS07. The microwave will not turn on and will display "DOOR". I think it is thinking that the door is open?. Please help.
Press and hold the DELAY START TIME button for +5 secs and a chime will sound. The option to toggle between SND HI and SND LO will come up, pressing Delay Start Time will change it between these options.
Jul 18, 2009 | Whirlpool RMC275PD Microwave Oven
Arching microwave oven
The area that has arced needs to be cleaned thoroughly, and if the paint is affected, it will need to be sanded smooth and cleaned with alcohol.
Then you can apply some high-temperature appliance paint, available from places like Wal-Mart, Lowe's or Builder's Square.
If the rack support is charred or melted, it will need to be replaced. It's best to replace them as a set.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Sep 03, 2008 | Whirlpool Microwave Ovens
Microwave Ovens Logo
41 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
