Question about Home
I recently purchased a home and in the master bath there is a Swirlway Acrylic tub. For the life of me I cannot figure out how to turn on the jets. Where would I be able to obtain an owner's manual?
  • 4,340 Answers
Well, look in places further away. Sometimes installing people use distance, rather than GFCI for safety.... It may be a switch in a strange place. It may be a timer.
Posted on Sep 06, 2010
Cloudy water
Always clean you jet tub as directed by the manual. If you don't have one, than fill tub above the jets, add liquid dishwasher gel (not tabs) with bleach and run through the jets for 20 minutes. Drain, fill with clean water and run two times to clean the tub and jets and then use. Be sure your metal filter is clean of hair and soap debris. This will keep your tub and jets nice and clean. Also recommend using Epsom salts and either essential oil of lavender or eucalyptus to your bath. Both essential oils have antibacterial properties. If you want it simpler, purchase Dr. Teal's lavender soak from the drug store. Happy soaking!
Oct 19, 2013 | Home
American standard jet bath tub black particles coming out of jets
The problem you are experiencing is common to many jetted bathtubs.It is a result of dried bathing water in the tub. There are a couple of solutions to resolve this ongoing problem.
  1. Use your tub more frequently as the water will not have time to fester in the pipes.
  2. Use a cleaning solution made for cleaning the pipes on jetted bathtubs once every three months.
You find Cleaning and Maintenance Products for jetted tubs at the following website. US Parts Center
Rod
US Parts Center
888-521-6183
Feb 25, 2013 | American Standard Evolution Oval Comfort...
Need to find out why 2 of the 6 jets on my acer swirl bath tub don't push water out like the other 4, and where can I find replacement jets. We bought the home recently and it was built in 2000. so...
see if the jet faces turn at all. Sometimes the jets are adjustable to allow more pressure from some jets.
turn the face of the jet and see what happens.
Aug 16, 2011 | Home
Purchased new home with a swirl-way avalon jetted tub dont know how to start it please help
is there an air button on the top of the tub? if so that is what you would turn the pump on/off with. give it a push and see. if you do have a button to push like that then make sure the air tubing is hooked up to the bottom of the air button and the other end is hooked to the air switch in the back of the motor.
if there is NO air button to push and just the logo on the top of the tub then you will need to fill the tub with water, get into the tub and then touch the logo. that would turn an older Swirlway tub on/off.
Feb 06, 2011 | Home
I have a whirlpool bath in my master bath in my mobile home, years ago my grandson pushed the button to activate the jets without water in the tub, it hasn't worked since, yesterday I had a friend who is...
the air switch should be connected to a switch by the motor the air switch is ur on off and should run from the button to another switch by motor the air switches were put in so there was not live wiring by the tub surface ,the the tub button/switch is like a bellows and pushes air into tube to turn switch on/off
Mar 04, 2010 | Kohler Home
I have an air tub with and aquaflo tub master pump
probably already solved this but yes, you can put a heater on any bathtub that has water jets.
Feb 02, 2010 | Aqua Flo Aquaflo Tub - Master Tmcp 3/4 Hp...
Shower/Tub Diverter Value Low Water Pressure
I had the same problem. I discovered that an O ring was missing (or I lost it without noticing) from a new diverter that I installed. Just got an O ring that fits on the threaded part of the collar where it meets the pipe. Worked fine. Amazing how a little plastic piece could make such a difference.
Jan 25, 2010 | Eljer Arlington Non-Jetted Acrylic Bath...
I know I can take a bath without turning on the jets. However; does the bath water with soap flow back into the jets? I like bubble baths, If I leave the jets off can I use the bubble bath without having...
The soapy water will fill all of the jets, tubes and the pump assembly. Will it hurt the tub if the jets are not running? The soap film will build up in the jets, tubes and pump assembly and can possibly cause damage if the tub is run at a later date. Contact the tub manufacture and see if there is a safe bubble bath you can use.
Aug 23, 2009 | Jacuzzi - Bathtub - Alcove - Navona -...
Jets not working
i have seen this in the past, a ground fault electrical outlet on the inside of a roman tub,if you have a 2 story house look for access panel on or by tub. otherwise you have to remove tile or other to access motor, you probably need a step too anyways
Mar 12, 2009 | Eljer San Antonio Acrylic Whirlpool -...
Home Logo
211 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
