Question about Poulan Garden
Chain and bar oil not dispensing Poulan chainsaw 2250
SOURCE: Poulan Farmhand chainsaw chain tightens too tight for motor to move chain
Make sure the chain is not over tightened. When adjusting the tightness, ensure there is at least 1/8" of looseness by pulling up on the chain in the middle of the bar and releasing it. If a chain becomes overheated because of leaning on the saw when the chain is dull, or lack of oil on the chain, it may expand in the track and not turn freely.
Marlyn, Mountain, Ont. Canada
Posted on Oct 03, 2008
  • 24 Answers
SOURCE: poulan 2600 chainsaw
check and make sure you have the correct sprocket.is your chain .325,3/8?sprocket has to match as well as chain and bar
Posted on Oct 20, 2008
SOURCE: chainsaw wont oil the chain and bar it is a poulan 2000 woodsman
It's probably the oiler check valve located on the crankcase just in front of the clutch. You will probably need to remove the clutch and sprocket to get at it.
Posted on Mar 06, 2009
SOURCE: Poulan-Pro 295 leaks excessive bar-chain oil
Most saws have a tendacy to leak after they are used. After use, just "burb" the oil fill cap to relieve any pressure. The closed oil system will siphon out all of the oil.
Posted on Aug 06, 2009
  • 15 Answers
SOURCE: Poulan 2 cycle gas chainsaw 18 inch. Was real
no bar oil should just hurt your chain and bar. remove them and try to start saw. if it still won't start you have other problems you may have to buy a new bar and chain
Posted on Feb 09, 2010
Poulan pro troubleshooting
CHAIN STRETCHS AS IT HEATS - KEEP CHAIN TIGHTENED CORRECTLY AND ALWAYS KEEP OIL IN OILER AND MAKE SURE IT OILS THE CHAIN. IF THIS DOESN'T FIX - REPLACE THE CHAIN. IF IT STILL HAPPENS THEN REPLACE BAR. WILL FAIL AGAIN WITHOUT OIL. POULAN WILL NOT HOLD UP WITHOUT CHAIN LUBRICATION. WORSE THAN OTHERS. IF CHAIN OR BAR OVERHEATED YOU'LL WORK ON IT MORE THAN YOU CUT. OIL IS THE KEY TO CUT WITH A POULAN!
Aug 10, 2014 | Poulan Pro PP4620AVX 46cc Gas Chainsaw...
What oil do we put into the poulan 3.0 peak hp
I assume you are referring to the Bar/Chain oil?
That would be Almost any Available brand chainsaw Bar and Chain oil, If that is not available you can use New uncontaminated SAE 30 motor oil.
May 15, 2014 | Poulan 16Inch 30 HP Electric Chain Saw...
Poulan chainsaw oil leak
sounds like the small oil feed pipe inside oil tank as come away from the end. just push it back on you may need a pair of long snout pillers.. good luck
Nov 30, 2013 | Poulan Garden
I need a manual for a new Poulan 3.5 electric chainsaw, or, failing that, I need instructions on what kind of oil to use on it, and whether I need separate oil for the chain.
You shouldn't need any other oil than the oil to keep the chain and bar guide oiled (pressing down on the button adds more oil to the chain/bar). You can use standard Bar and Chain Oil, or probably pay a little more and use the Poulan brand oil, but in my experience, any bar oil for chainsaws will work, and the larger the container you buy, the less per ounce you will pay. Remember this is NOT an automatic oiling system, so it will be cheaper in the long run to remember to press that button than to replace the chain/saw if it overheats.
Aug 29, 2011 | Poulan 14" Electric Chainsaw
I have a poulan wild thing 14" 2050 at wt chainsaw and i need to know what chain and bar oil i need to use, can i use ordenary engine oil for chain and bar ad where do i get spare parts in perth...
You should use a non fling oil, this is an oil with a sticky addative to stop the oil just spraying off the end of the bar, and not lubricating the underside of the bar where most cutting is done.
Jun 19, 2011 | Poulan Garden
Chain turns but comes loose and burns at wood. also get alot of smoke from chain area
Insufficent chain oil to the bar, check there is oil in the oil tank, remove the bar and clean out the delivery hole in the bar.
Jun 15, 2011 | Poulan 14" Chainsaw
Feb 02, 2010 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
I have a poulan wild thing 18" bar and I have had a problem with the bars wearing out quickly. I use regular poulan bar and chain oil. Did this saw have a specific problem with the oiling system?
If the oil level in the chain oil tank goes down normally then you may be running the chain too tight. Also make sure the oil ports in the bar are clear so the oil can get to the chain. hope this helps you
Nov 03, 2009 | Poulan Pro Chain Saw 46cc 20"
Poulan 14" gas leaks bar oil all over, plenty on bar/chain, using thin synthetic oil.
Use actual bar oil sold for that purpose. It's thicker and won't run out like water. Synthetic oil is very thin does not have the proper density.
Jun 26, 2009 | Poulan 1630 16" Chain Saw
Garden Logo
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
