I was pulling paper jam from lexmark 6570 where it was jammed in the duplexer. it got stuck and i cann't get it out.
  • 944 Answers
This problem could occur due to many reasons.In your case it is due to Defective D-roller or Gears not turning or broken gear.If the system itself is not able to control it then it is because of the bad sensor.
D-rollers,We have the take apart the printer.and see internally what could be wrong.Open the sides of the printer and turn the D-roller and other rollers so that it could be made rotated and loosen the paper.
This pfd is the repair guide when the paper get stuck in lexmark system.See how the stuff works and how to solve the problem.
http://lexmark.com/publications/pdfs/w820/eng/prfedprb.pdf
http://www.lexmark.com/publications/pdfs/lexmarkc720/eng/jams.pdf
post a comment for further assistance.
Thank you for using fixya have a nice day:-)
Posted on Sep 06, 2010
Fix repeated paper jams on Lexmark 901 Pro
If you are getting a jam and there is no paper visible then a likely cause is a false jam that is caused when the paper is not picked up from the tray at the start of printing. Send a print job and listen closely. If you can hear the pickup rollers turning but no paper is being pulled into the printer then either the rollers are dirty or are worn and need to be replaced. Trying printing from a different tray or the manual feed tray to eliminate a fault with a different component on the printer.
Oct 14, 2014 | Lexmark X Office Equipment & Supplies
Tip
Paper Jam Error on HP Printer
Paper Jam is the most common issue in all the HP Printers ( Officjet, Photosmart, Deskjet Printers )
What Causes a Paper Jam ?
  • Paper thickness.
  • Room temperature OR due to Dust in atmosphere or the room.
  • Paper pulled out in a hurry and paper pieces stuck in Rollers or Carriage
  • Could be Hardware Failure
NEVER PULL THE PAPER STUCK IN THE PRINTER FROM FRONT SIDE OF THE PRINTER ( unless the paper is 3/4th visible in front view if you open the printer front panel door )
Follow the instructions below to resolve Paper Jam issue.
  1. Turn off the printer.
  2. Open the rear access door ( or duplexer )
  3. Check for any bits of paper stuck, if so, remove them.
  4. Open the front access door where you see the cartridges.
  5. Check for any paper pieces, if so, remove them.
  6. Take a lint free cloth. Little bit Damp ( use water )
  7. Clean the Rear rollers pushing it upwards and close the door.
  8. Close the front access door.
  9. Connect the power cord and power on the printer.
  10. It should be ready to print/copy/scan/fax.
To clean the duplexer ( 2 - sided printing device ) remove the duplexer and clean the rollers you find inside.
If the above steps do not solve your problem, you printer needs repair. Contact HP. ( 1-800-474-6836 )
If the printer is In-Warranty please contact HP for replacement. HP may charge for repair for Out of Warranty printer.
Find the Video below for paper jam cleaning
Regards,
Ron
Your rating will help us improve the service we provide
on May 20, 2011 | Office Equipment & Supplies
What does the "heart beat" symbol/light mean?
I assume you mean the symbol that has a pair blackened circles and then a pulse up and then down below the starting line before returning to the starting line.
That is the paper jam symbol. If the continue light is on (steady) and the paper jam light is on, then you have a paper jam. Press Continue twice to see any secondary error message (this will show where the problem is).
See the manual for the list of the lights that show where the jam is occurring. Different groups of lights will be lit. The manual is available as a PDF at the bottom of this page: http://support.lexmark.com/index?locale=EN&page=product&userlocale=EN . An example: if the Continue, Toner Low and Paper Jam are all on, then the jam is in the fuser area under the print cartridge assembly. For a paper jam, even a small corner of torn paper could be in the mechanism.
In all cases, you should check the entire paper path. When you pull out any paper, grip it so that you can gently pull the sheet straight out. Remove all paper from the output tray. Then remove the paper tray if you are using it. Pull any paper from this area. Press down on the green duplex flap and remove any paper from there Reinsert the paper tray. Open the front door of the printer and remove the print cartridge assembly. Lift the green flap and remove any paper from the area. NOTE: the fuser and the fuser area may be hot. Open the rear exit door and remove any paper from that area. Use a flashlight to check for small pieces of paper that may be stuck. Once all the paper is removed, reinstall the print cartridge assembly and close all the doors. Press Continue to reset the printer.
The page that jammed may be reprinted.
I hope this helps.
(please note that frequent paper jams may be a sign of excess humidity in the paper. Put less paper in the tray at each refill and keep the remaining paper in a dry location. If the paper jam light is coming on when no paper jam is present, one or more of the paper jam sensors may be bad. Contact Lexmark for more information.)
Nov 30, 2010 | Lexmark E250dn Laser Printer
Duplex paper jam . i thought i took out the paper that was jammed and i am still getting that message, PLUS now I cannot the top tray back.
The duplexer, which flips the paper to automatically print on the back side, slides into the back of your printer. Unplug the printer and slide the duplexer out to check it for jammed sheets. You might have pulled out a sheet or two in the main printer section and left one in the duplexer.
As for the top tray, the paper feed wheels ride on the end of a long lever that drops down to rest on the paper. It should be held up out of the way by a spring until the drawer is inserted, but sometimes the plastic nub that the spring pulls on breaks off. Lexmark sells a little kit of the spring and "bellcrank" to fix it. If your paper tray holds 500 sheets - a whole **** - you need part no. 56P1331 "Parts packet, bellcrank and spring, 500 sheet." For 250-sheet trays the part number is 56P1337. A web search for either part number will find you a seller.
Sep 20, 2010 | Lexmark T632 Laser Printer
Our machine shows E051. so what can i do.
The JAM DUPLEX message appears if you remove a sheet of paper from the face down output tray after only one side has printed.
The paper sizes you can use with the duplex printing function are A4, Letter or Legal.
If the paper adjustment lever for duplex printing is not set correctly for the paper size, paper jams may occur and the printing will be out of position on the page.
Open the back output tray.
Use both hands to slowly pull the jammed paper out of the fuser unit.
Close the back output tray.
If the paper jam cannot be cleared, go to the next step.
Pull the duplex tray and paper tray out of the printer.
Pull the jammed paper out of the printer
Put the duplex tray and paper tray back in the printer.
Click solved and vote if problem is solved. Otherwise post again
Aug 02, 2010 | Office Equipment & Supplies
Papaer jam "check duplex"
Here's an article in the Lexmark website on Paper Jams and the Printer Displays a 'Check Duplex' or a '23x' Type Paper Jam Message: Lexmark T650, T652, T654, or X65x Series Printers. Just click on this link: http://bit.ly/aqGjtK. Read the instructions thoroughly. Hope this helps but if you need more assistance, don't hesitate to contact Lexmark Technical Support. Thanks.
Jun 25, 2010 | Lexmark T652DTN MONO LASER PRINT Printer
My school's computer "Lexmark E323" has a paper jam and nobody knows how to fix it
hi!!!!try to open the duplexer at the back of your printer and see if there's a paper stock in the duplexer who cause a paper jam to your printer.
May 01, 2009 | Lexmark E323 Laser Printer
Paper Jam Error on Dell 3100cn Laser Printer
Push the side button and open the front cover
Pull out the jammed paper from the duplexer. If jammed paper cannot be found, go to the next step.
Pull up on the belt release levers and rotate the belt unit up
Remove the jammed paper and close the belt unit
Close the front cover
Jan 03, 2009 | Dell 3100cn Laser Printer
Duplex jam
repalce dupliexer or check the duplexor gears as i ahd it at one point otherwose doa printer ressetr ans ee if problem clears up
Feb 18, 2008 | Lexmark C912 Led Printer
16 people viewed this question
k24674
jasbo
jasbo
