Question about Nintendo Wii Console
Error code 52030 will not connect with the internet
    Genius:
  • 1,035 Answers
Hi. All you need to do is change the wireless encryption from from WEP to WPA2 (AES).
have a good one!
Posted on Sep 06, 2010
  • kae2021 Jun 05, 2011
    I am not computer literate at all. I used this and it worked but am I leaving my wii less protected by changing encryption codes?
  • 5 Answers
SOURCE: error 52030 in internet connections
Are you using a WEP? If so, it will only connect using KEY #1.
Posted on Nov 26, 2007
bdizzle
  • 41 Answers
SOURCE: internet connection error 52030
http://www.wiierror.com/wii-error-52030.php
Posted on May 24, 2008
SOURCE: error code 52030
I'm not sure if this is the case, but don't plug the WiFi adapter into the Wii console, plug it into the USB port in your computer. If you are plugging it into your computer, there might be too many walls between your computer and Wii, in that case get a USB extension cord.
Posted on Mar 29, 2009
brucew79
  • 24 Answers
SOURCE: Error Code: 52030 unable to connect to Belkin
This error code usually indicates a problem relating to wireless security. Please try the following troubleshooting:
  1. Are you using WEP or WPA security on your router?
    1. Log into the router using the default IP (consult your router's manual for assistance)
    2. Locate the "wireless security" section of your router settings and find the WEP or WPA key.
    3. If you are using 64-bit encryption, the WEP Key must be a 10-character key consisting of numbers or letters A through F.
    4. If you are using 128-bit encryption, the WEP Key must be a 26-character key consisting of numbers or letters A through F.
    5. The WEP Key must be a Hexadecimal (0-9, A-F, no other special characters or letters).
    6. If your router has multiple slots for a WEP Key, make sure the active key is the one in the #1 slot.
    7. If you are using WPA, the Wii console is compatible with the following types:
      • WPA - PSK (TKIP)
      • WPA - PSK (AES)
      • WPA2 - PSK (AES)
  2. If your WEP or WPA key is correct, then the problem might be related to MAC address filtering:
    1. From the router settings, locate the "MAC address filter" settings (also known as "access control", "access list", or "network filter" depending on your router model).
    2. If the Mac address filter is set to "enabled", then you must add the Wii's MAC address to the "allowed" list. You can locate the Wii's MAC address from the "console information" page (located under "Internet" in the Wii Settings).
    3. If the Mac address filter was disabled, then continue troubleshooting.
  3. If your connection was working previously, try power cycling your router and modem by unplugging them both from the wall. Wait a few minutes, and plug the modem back in. Wait a couple of minutes for the modem to initialize, then turn on the router. Try to connect the Wii console online and test for proper response. (Some routers may lose their connection to the Wii console while it is in Standby or turned off for a period of time. Check with your router manufacturer's website for the latest firmware, as there may be an update that will help prevent this issue from occurring in the future.)
  4. Try adjusting the "Channel" your wireless router broadcasts on. We highly recommend setting your wireless router to either channel 1 or 11. This can potentially increase the download speed. For information on accessing your router's settings, click here to select the brand name and model number of your router (if available).
  5. Try a "Manual Setup" with the Wii console (how to), using your network's IP configuration settings. To access these settings:
    1. On your PC, click "Start" and then "Run."
    2. Type "CMD" into the field that appears to open a new window.
    3. Type "IPCONFIG/ALL" and press "Enter" to display a list of internet settings. Locate the settings asked for by the Wii console during the Manual Setup process and enter them.
Posted on Oct 29, 2009
  • 3230 Answers
SOURCE: error code52030
This error code is well defined on the Nintendo site, you can please follow the below link -
http://www.nintendo.com/consumer/wfc/en_na/ds/results.jsp?error_code=52030&system=Wii&locale=lang
(Please copy and past the above link in your web browser)
Good Luck!!
Thanks
Posted on May 15, 2010
Can not connect to internet on my wii error code 52030
It's possible that the wireless security pass code for your home network may have been changed or is entered incorrectly on the Wii console
Jun 04, 2012 | Nintendo Wii Console
Lost internet connection reading code 52030
Error Code: 52030
Unable to connect to your wireless network
Likely cause: It appears that the security settings entered into the Wii console are not the same as what your wireless router is set to allow, or your router is not able to assign the Wii an IP address.
How to fix: Make sure the security key and security type are entered into the Wii exactly as they appear in your router's settings; manually assign an IP address to the Wii.
Jul 20, 2011 | Nintendo Wii Console
I have netflicks and is has quit working, i have a error code 52030
That error code means that your settings for your router are incorrect. Try to re-enter your settings and see if that fixes the issue.
May 01, 2011 | Nintendo Wii Console
Wii will not conect to the internet today, we have not had a problem before today. When I test it it shows an error code of 52030.
The following information was taken directly from Nintendo's website about error code 52030. I have included a link at the bottom directly to the page from which I got this information. If you click the link, there will be a step by step guide on fixing the error:
Error 52030
http://www.nintendo.com/consumer/wfc/en_na/ds/results.jsp?error_code=52030&system=Wii&locale=en_US&action2.x=29&action2.y=19
Apr 07, 2011 | Nintendo Wii Console
Error code 52030 mean
Your nintendo Wii cannot connect to wifi.
Here's a link to a detailed diagnosis and solution to error code 52030 on the nintendo wii
Apr 07, 2011 | Nintendo Video Game Consoles & Games
When I try to connect to the Internet it keeps giving me a error code 52030
Error 52030 is a security settings error built into the Wii. This means the Wii is either incompatible with your router's security settings or your router isn't able to assign the Wii an IP address (which means it can't register it onto your network).
Nintendo has provided official information for solving this problem here: http://www.nintendo.com/consumer/wfc/en_na/ds/results.jsp?error_code=52030&system=Wii&locale=lang
Mar 12, 2011 | Nintendo Wii Console
My wii will not connect to wireless internet error code 52030
If you get an error code of 52030 on you Wii console, this indicates a problem with your Wii communicating with your wireless router. There are a couple things you can try/check to help fix this problem.
1 - Try using a different channel on your router and update your Wii to take to the router on that channel.
2 - If your router is using WEP (encryption), make sure your Wii is set to the same encryption.
Feb 28, 2011 | Nintendo Wii Console
I have an Error Code 52030 on my WII. What does
it means that u are trying to connect to wifi but there is no wifi around so go 2 tech support for wii and enter the error code.:)
Jan 30, 2010 | Nintendo Wii Console
Error 52030 in internet connections
one option is try choosing a different type for your password...i've had the same error before and what i did was to change the password type e.g. from wpa aes-tkip to wpa-aes passphrase (this option will appear during your wii internet connection set-up as you would probably know by now) and everything right afer started to fall in place perfectly...my wii started connecting to my router and never had the same error code ever since.
Nov 23, 2007 | Nintendo Wii Console
Nintendo Wii Console Logo
183 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
