Question about Raymarine Ray 240 Modular Vhf System
I have a Raymarine 240 VHF from the USA and I need to get it switched for Australian use (VHF Channels - Frequencies) ?
  • Raymarine Master
  • 695 Answers
Hi Michael
From the owner's manual (Page 14) you need to press "menu", then select "Frequency Group", then you have the choice of USA, Canada or International channels:
Here's the link to your owner's manual should you require it:
http://www.raymarine.com/ProductDetail.aspx?SITE=1&SECTION=2&PAGE=830&PRODUCT=1948
Hope this is helpful to you.
Posted on Sep 11, 2010
THE CORD ON THE HANDSET IS BROKEN TO THE SIDE WHICH IS CONECTED TO THE BASE UNIT. I TRY TO SOLDER IT TO THE PINS BUT WHAT COLOR GOES WHERE?
Phone connections are low electrical connections. Soldering would cause heat dispersion fluctuations, creating more complications. Best to replace cord or unit.
Sep 02, 2015 | Raymarine 240 Vhf Radio E42001
No backlight on raymarine E120
You may have inadvertently turned the backlighting off. Ray marine has an extensive library on-line. I have usually been able to find what I need there. May take some digging though.
Jun 12, 2014 | Raymarine Ray 240 Modular Vhf System
Raymarine R49144
Hi
Any Raymarine dealer should be able to source a new cord for you.
Hope this helps.
-Steve
Ray 240 VHF how to obtain new cord
Apr 29, 2014 | Raymarine Ray 240 Modular Vhf System
Need a replacement cable for ray 230
Hi
For your 230, you need part number R49085 which should be able to be ordered by any Raymarine dealer. On the link below, scroll down to post #8.
Hope this helps you out.
-Steve
Feb 20, 2014 | Raymarine Ray54 Vhf Marine Radio Dark Grey
In Thailand Cb radio users must use freq range 245.000 - 249.999 freqs. Do usa Cb's use this freq?
Thailand actually has three "CB" bands, the first is the same as the U.S. / CEPT (EU "European Community) band 26.965 - 27.405 MHz, the second is a 78MHz VHF mid CB band (I think its either 40 or 80 channels with FM mode) and then the 245.0000 - 245.9875 MHz VHF 80 channel band - apparently the law also stipulates that the 78MHz CBs must be yellow colored and the 245MHz CBs must be red colored.
But yeah, 245MHz Thailand VHF CBs are very illegal in the United States.
Jun 24, 2010 | Cobra 19 DX III 40-Channels Base CB Radio
Since the digital switchover, I have lost channels, despite re running the setup and tuning. Any suggestions as to why this is happening?
I have a similar issue. When the digital switch happened here some of the local TV stations changed frequencies from UHF to VHF. I do not have a VHF antenna so I am unable to receive these channels. I do have a great UHF antenna, but it will not receive VHF. The fix is of course is a new UHF/VHF antenna. I am 50 miles away from the TV transmitters.
This may or may not be your problem. I hope this is helpful to you.
Bob
Nov 08, 2009 | JVC LT42P789 42 in. LCD TV
Receiving digital tv service in Australia using samsung LE32R87BD
rest tv to manufacture settings then in the menu it will ask for your area i think its on there for australia. you will need to go down the menu. and then setup it would ask for the area you are as well, make sure you have a aerial in and its pointing in the right direction .
Jun 04, 2017 | Televison & Video
Raymarine Ray 240 usa model
You cannot just reprogram your Raymarine to european standard.
This radio has been built and is licenced for using with USA frequency, in Europe his use will be limited to lower bands with no modification.
To be fully adapted to higher bands, the radio must be taken apart, and you need to bridge a contact on the main board.
The use of the radio after modifacion won't be legal in Europe.
Oct 03, 2008 | Raymarine Ray 240 Modular Vhf System
I have a Raymarine VHF marine radio but cannot get channel 37 - why not?
To my knowledge, Ch 37 (M1) is used by the UK Marinas and Yacht Clubs, however, the Raymarine Ray45VHF uses the US VHF Marine Radio Channels allocations/standard where there is no Ch 37 (actually no Chs 29-59).
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa
Jun 17, 2008 | Raymarine Ray45VHF (53 Channels) 2-Way...
What's the channel frequencies for a common 22 channel motorola 2 way vhf radio?
Not sure what you want.....VHF band ius approximatly 130mhz to 175 mhz..... in that VHF band there is a commercial VHF band aprox. 155 mhz to 175...... the amateur radio vhf band is aprox. 135 to 150mhz.
With amateur radio, any freq in that range can be used...... with commercial radio the FCC cangive a company any freq. in that range also.
If you are looking for FRS/GMRS frequencies they are UHF freqs not VHF.
So I'm not sure exactly what you want......sounds like you might want to program in FRS freqs into an Icom amateur radio. If thats  the case you will need an Icom that will do UHF freqs.
Oct 12, 2007 | Unwired UFR650 (14 Channels) 2-Way Radio
Raymarine Ray 240 Modular Vhf System Logo
320 people viewed this question
Top Raymarine Boating Experts
Steve
Steve
David Burbee
David Burbee
Are you a Raymarine Boating Expert? Answer questions, earn points and help others
