Question about Samsung DVD-P244 DVD Player
Audio CD was playing ok then sound started to 'play up' and player stopped and now CD cannot be removed from player. only message is "open" or "load" and tray will not open. Thanks.
  • akenny51 Sep 08, 2010
    Checked all gears etc. and all ok so solution suggested did not find problem. Given cost to buy new unit I have scrapped it and will buy a new one.
    President:
  • 1,961 Answers
That is a mechanical error of the loading tray of your dvd player.there are 2 motors on it one is the spindle motor and the other one is for the CD open/close tray.here's what you need to do.open the cover of your player then unsrew the CD mechanism and take it out from the player.detach the connectors from the mainboard be very carefull of the connectors not to interchange them use a marking pen.On the loading motor,check the gears replace any broken gear.and belts...when dismantling the loading tray be very careful with the timing between the lens assy and the tray...timing sequence of mechanical are important so be very careful..goodluck
your rate is important to me so pls click the tumb up button.
Posted on Sep 06, 2010
I have a 6 cd changer in my 2005 chysler Pacifica that stopped playing. Shows error message no cd.
My experience with CD/DVD players has been, unfortunately, that when the trays stop opening and/or closing, or when error messages start regularly, it's history. Hope yours turns out differently, but I wouldn't count on it. It will cost you as much or more to fix it than to replace it. if you live near a large junkyard you might try to retrieve one there, but the fact that your car is 13 yrs. old will make that tougher.
Jan 17, 2018 | The Audio Players & Recorders
Denon DCM-370/270 - issue playing CD's. A CD will
I would replace the audio cable from the CD player to the Denon amp, a long shot, if you have other devices hooked to the amp and plays fine, the problem will be in the CD player. However! if all sound sources have the same problem, the issue is with the Denon unit.
Mar 09, 2012 | Denon Audio Players & Recorders
Good day - I moved for my work and upon
First clean the laser head with a Qtip and alcohol. It gotta be perfectly clean, so wipe with fresh brand name qtip and make sure there is not a single dust particle on it. You gotta remove the cabinet with star screwdriver. Your beam might be tired. First try with the clean up! Unplugg before opening!
Oct 12, 2009 | Yamaha CDC-665 CD Player
How to play audio clip in java
  • Create an AudioClip object
  • Load .au sound file into AudioClip
  • Play sounds once or loop continuously
  • Stop playback
Here's how the code for these steps looks:
import java.applet.*;
AudioClip ac = getAudioClip(getCodeBase(), soundFile);
ac.play(); //play once
ac.stop(); //stop playing
ac.loop(); //play continuously
It would seem logical to use this same code to play audio clips in a Java application. Unfortunately, if you do that you will get errors from the compiler. Why? Because the AudioClip object and the getAudioClip() method are part of the java.applet package -- and are not part of applications. The good news is we can dive down and make things work ourselves.
The trick to solving this problem is to use some undocumented features that are provided by Sun in its JDK. Taking a peek inside the classes.zip file from the Sun JDK (using any of the various zipfile utilities), we find not only the standard Java packages such as java.applet but also sun.audio. (These are in the directory sun/audio.)
The sun.audio package contains everything we need to be able to play audio clips! Here's the code:
import sun.audio.*; //import the sun.audio package
import java.io.*;
//** add this into your application code as appropriate
// Open an input stream to the audio file.
InputStream in = new FileInputStream(Filename);
// Create an AudioStream object from the input stream.
AudioStream as = new AudioStream(in);
// Use the static class member "player" from class AudioPlayer to play
// clip.
AudioPlayer.player.start(as);
// Similarly, to stop the audio.
AudioPlayer.player.stop(as);
To use a URL as the audio stream source, substitute the following for the input stream and audio stream setup:
AudioStream as = new AudioStream (url.openStream());
Playing the audio stream continuously adds a bit more complexity:
// Create audio stream as discussed previously.
// Create AudioData source.
AudioData data = as.getData();
// Create ContinuousAudioDataStream.
ContinuousAudioDataStream cas = new ContinuousAudioDataStream (data);
// Play audio.
AudioPlayer.player.play (cas);
AudioPlayer.player.stop (cas);
Jan 22, 2009 | Computers & Internet
Playing Music
Besure that the cd inserted is readable by your CD rom.
You can open your windows media player.
click file menu,
then click open. browse your CD drive and select all the musics files and then click ok.
click play.
If this not resolve then verify if your computer has a speaker, not mute the volume control. or the device controller is installed properly. (the audio driver)
may this help,
melnavz
Oct 04, 2008 | E-Machines eMachines Desktop PC
How do i bypass the parking brake switch in order for my video to play
1. FACTORY RESET METHOD (Temporary)
(This isn't the most effective, but it is the easiest to try, so it's worth a shot since it apparently works on some units.)
** Go to the Menu
** Get to the Settings Menu
** Select <yes> to Reset to Factory Settings.
Credit: DKA
2. AUDIO CD METHOD (Permanent)
** Insert Audio CD
** Press PLAY
** Press STOP twice on remote
** Enter 26604 on remote
** Press ENTER
** Take out Audio CD and Insert a DVD
Credit: Myself via a DUAL Tech
3. DVD METHOD (Permanent)
** Insert a DVD
** Let it play until you hear sound
** Enter 26604
** Press ENTER
Credit: Adam P.
Feb 18, 2008 | Dual XDVD8181 Car Video Player
Samsung DVD-SH853M HDD/DVD Recorder/Digital Receiver
Make sure you are not using DVD+R dics - the player won't play these. It is OK with DVD-R.
Jan 21, 2008 | Samsung DVD-HD950 DVD Player
Samsung DVD-P244 DVD Player Logo
41 people viewed this question
Jerry Greenberg
Jerry Greenberg
