Question about Western Digital 500GB My Book World Edition 500 GB Hard Drive
Western Digital 1TB My Book World Edition II (Blue Rings) I had a HDD die and would like to replace with one off the shelf, but WD says this is not recommended. How can I do this safely, and possibly upgrade the size of 1 HDD?
amusedgeek
  • 787 Answers
SOURCE: WD mybook world won't work on mac?
Window and OSX - fun and joy.
Since you formatted a 1TB drive and it works fine in Windows, I have to concluded the the drive was formatted NTFS.
Here is the issue in a nutshell, OSX supports reading NTFS but have very limited write cababilities.
If you want both Windows and OSX to have full access to an external drive you should format it FAT32. The only issue then is that under normal conditions a FAT32 drive has a maximum size of 32GB.
I would partition the drive to have 1 or more FAT32 partitions and then have the rest of the drive NTFS.
Is the OSX version correct or should it be 10.3. If it is actually 1.3 it would mean you have the OSX Server edition that originally came out in 1999 and it may not have very good USB support - version 1.2 would only support 1 USB device.
Posted on Oct 16, 2008
  • 5 Answers
SOURCE: slow WD World Edition HD
I understand your pain. Mine was always slow, but it's by design. I am sure the limitation is the amount of RAM it has, because everytime it needs to access data, the RAM is so small that it will have to go back to the drive just to re-read an index. When mine died after 1.5 yrs, I took it apart and found a WD5000AAKS SATA 7200rpm drive. Performance of the drive should be excellent, but in that little plastic box that is acting like a stand-alone NT server, performance is s-l-o-w. As a MyBook, it's best used as a backup unit, but be sure you have a backup of that, since it is highly unlikely it will live much more than 12 months, if that, because it has no forced cooling. See other issues on this site with regard to other MyBooks.
Posted on Dec 09, 2008
calanan
SOURCE: Need to open WD MyBook 1TB HDD model WD10000H1CS-00
I have this same problem and found a great write-up here that has text and photos of the process. I haven't tried the process with mine but there are plenty of responses to his posting indicating success. Good luck.
- mike
Posted on Dec 10, 2008
SOURCE: Problems with Western Digital My Book World Edition
I have the same drive. It works great with windows XP but with Windows vista has difficulty seeing this type of drive and keeping the connection once it is established. Take it back if you have windows vista and then search for which 1TB drives work well with windows vista. It really has problems with windows vista 64bit. I was able to finally see the drive when I was using photoshop file/browse/network... then I dragged the shortcut Icon to my desktop and access the drive that way from that point on. Mine stopped completely tonight... I think the power cord went bad or something.
Posted on Jan 06, 2009
JulesPCaut
  • 702 Answers
SOURCE: External HDD not working , but can here it running
Have you tried powering it up without connecting it to the computer?
It should at least power up and do something. After that try connecting it to your PC (with the disk powered up already).
You can further check this external drive troubleshooting article, which has some tips on trying to get external disks to work.
Jules
Posted on Apr 20, 2009
WD 1TB drive only shows up as a 10GB hard drive
WD has a courtesy Drive cloning tool from acronis. It's on their web sit under drivers. Don't worry about the "My Book" thing the file is labeled Acronis True Image WD Edition Software download.
http://support.wd.com/product/download.asp?groupid=132&lang=en
Apr 27, 2014 | Western Digital My Book Essential 1TB...
WD My Book essential edition 1tb no power
western dig probably haven't shipped with a supercheap psu but then my maxtor external psu went first followed by the drive ...
end of the day there is just a hdd inside the box take it out and use it in a desktop...
good luck
Oct 26, 2009 | Western Digital My Book Essential Edition...
Western Digital World Book 1TB - Lights don't light, HDD vibrates
I would try to connect the drive directly into an ide or a sata cable on the motherboard. Maybe using the western digital tools from their website you'll be able to access the data and copy it. I hope this helps you.
Aug 23, 2009 | Western Digital My Book World Edition 1TB...
Same Problem with MyWorld Book Edition II, sent back got a new on
Exactly but this time around they change it. If there is some issued about your My Book keep us update here to know what is the problem it made.
Jul 29, 2009 | Western Digital 500GB My Book World...
Cant connect my 1TB WD world edition to my linksys router
Your My Book World should not be formatted or you will lose all ability to access it through the Network -- it will simply become a hard-drive at that point. There is software installed on the hard-drives that communicate with your Router in order to obtain an IP and be available as a Network Drive. If the drive and the Router are communicating, you should see an IP in the DHCP list of your Router. It is possible that the My Book World is not setup for DHCP, so if it is placed in an alternate environment with incompatible static IPs, it won't be able to access the Internet or be available locally. You can try a hardware reset on the drive and see if it pops up in your Router's DHCP/Client list, at which point it should also appear locally and over MioNet (MioNet will need to register the device to an account before it will appear in MioNet, but it must detect the drive locally in order to attach).
1. Turn off My Book World
2. Identify the reset button on the back of My Book World
3. Depress the reset button while restarting My Book World
4. Keep the reset button depressed for about 10 seconds after you see blue lights on My Book World
Jul 02, 2009 | Western Digital 500GB My Book World...
Wd my book world 1tb will not power up
check usb interface. problem in usb terminal. try to press round button switch.
Jun 01, 2009 | Western Digital My Book World Edition 1TB...
Flashing blue rings
The alternating flashing between the inner and outer blue rings means the drive is currently in Raid Degraded mode per KB article 1480. You will need to have your drive serviced. If you are able to access the device's Shared Storage Manager you should find a Drive Status: Drive (A or B) failed. If you can access it, you might be able to re-create the raid by replacing the bad drive (they're labeled A and B internally with a sticker so you'll know which one to replace) -- it's generally recommended that you first go through the warranty process though:
KB Article 915 and KB Article 8 will start you on the RMA process.
1-800-275-4932 can assist.
May 21, 2009 | Western Digital My Book World Edition 1TB...
Replacing HDD's on WD MyBook World II won't format
I was attempting something similiar -- replacing my World Edition II 500GB drives with 1TB drives. My research unearthed two things... These units will only work with Western Digital Caviar Green drives. The blue ring won't light if other drives are installed. I also read (in a couple spots) that the unit's O/S is stored on the hard drive (as opposed to be stored in Flash memory). If this is true, you would need to image the old drive to the new (using a tool like Ghost or True Image), and increase the partition size as part of the imaging process. I don't know if this would work, as I opted to not proceed with the upgrade. For me, the new version of the World Edition II (WDH2NC20000 and WDH2NC40000) turned out to be a better option than upgrading. These units provdide the extra space and are MUCH faster than the old ones.
Apr 16, 2009 | Western Digital 500GB My Book World...
Western Digital 500GB My Book World Edition 500 GB Hard Drive Logo
155 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
