Question about DISH Network 135899 Remote Control
SAT button will not light up - DISH Network 135899 Remote Control
    Novelist:
    Champion:
  • DISH Network Expert
  • 286 Answers
Becki Barned with Dish Network customer service here. This may have been resolved, but if not, here are some easy steps. If the batteries have not been chaged in the past 60 days, go ahead and replace them if you are able. Then, follow these simple steps. http://www.dishnetwork.com/SupportSection/remote-control Happy Troublehshooting!
Posted on Dec 25, 2010
Tv says receiver is not on and do not respond to remote control
Hi Jackiewes928, I apologize for the inconvenience you have experienced. It is my pleasure to assist you today. I understand that the only channel you are currently getting is channel 116 and that your remote is not responding. Do any buttons at the top light up on the remote when you try to change channels? If so, what button lights up in red or green? if any button other the SAT button lights up this means that the remote is not on SAT mode and this would be why is not responding. In order to put the remote in SAT mode press the SAT button for 3 seconds. Once you do this try using the remote. If you need further assistance please feel free to reach me directly at kimberly.escobar@dish.com
Feb 06, 2013 | DISH Network IR Remote Control
My sat button will not work. and i hold it in.
Are you using good batteries? Does the sat button lights up when you press it? If you are using good batteries and the sat button won't light up each time it is pressed, then you will have to call Dish Network for a remote replacement.
Jan 24, 2011 | DISH Network IR Remote Control
That SAT button does on my remote control does not want to light up. All 3 other buttons work.
mannyaflores,
I just want to clarify your problem. It sounds like the SAT button on your remote is not lighting up but the other 3 buttons do light up, is that correct? Are you still able to change channels? When you press the "Select" button on the remote, which button lights up on the remote? Trying pressing and releasing the SAT button to see if it lights up and goes out. If it doesn't, then we will need to replace the remote. Please call 1-800-333-3474 and speak with Technical Support. I hope this helps.
Ray Calo
DISH Network
Nov 27, 2010 | DISH Network IR Remote Control
The tv is jammed. Remote is fine but have pressed the wrong button
It sounds as though you might have just accidentally pressed a button and changed the remote into an incorrect mode for example, tv, or aux modes. This would in fact prevent the remote from successfully working with the DISH Network receiver. If this is in fact the problem, then the remote simply needs to be put into "SAT" mode, once its back in SAT mode you will then be able to change channels, select menu, power receiver on and off, etc. The "SAT" button is labeled & in the upper left hand corner of the remote to put the remote back in satellite mode, please just press that SAT once and then release, the SAT button should briefly light up red & then the light will go out, you should then be able to use the remote again, to ensure remote was successfully changed back to SAT mode, you can press select or any other button you chose & as long as the SAT button lights up when you press another remote control button- then your all set to go & everything should be working once again! I hope this helps -please let me know if there is anything else I can help you with!
-Kirstie DISH Network
Oct 01, 2010 | DISH Network IR Remote Control
My tv remote will not allow me to access the satellite
walk_alan,
Are you still having problems with your DISH Network remote? Which light on the remote lights up when you press the select button? If any button besides the SAT button, the remote is not in SAT MODE. Pressing and releasing the SAT button will put the remote in SAT MODE.
If the remote is in SAT MODE and doesn't operate the receive, then the remote may need to be readdressed to the receiver or the remote may need to be replaced. Do you have fresh batteries in the remote? If so, I have provided steps on readdressing the remote to the receiver.
Remote: All Other Remotes
  1. Go to System Info screen(depending on the receiver, you can press the "System Info" button, or pull the smart card out from the receiver till the "System Info" screen appears on the TV)
  2. Hold down the SAT button until all mode lights light up.
  3. Enter a number between 1 and 15 using the numeric keypad on the remote.
  4. Press the pound (#) button
  5. Once the SAT button blinks three times, press record. Note: If successful the number selected in step 3 will appear in the System Info screen under Remote Address.
I hope this helps.
Ray Calo
DISH Network - Executive Offices
Jun 20, 2010 | DISH Network 135899 Remote Control
My dish network remote stop working
It sounds as though you might have just accidentally pressed a button and changed the remote into an incorrect mode for example, tv, or aux mode. This would in fact prevent the remote from successfully working with the DISH Network receiver. If this is the problem, then the remote simply needs to be put into "SAT" mode, once its back in SAT mode you will then be able to change channels, select menu, power receiver on and off, etc. The "SAT" button is labeled & in the upper left hand corner of the remote to put the remote back in satellite mode, please just press that SAT once and then release, the SAT button should briefly light up red & then the light will go out, you should then be able to use the remote again, to ensure remote was successfully changed back to SAT mode, you can press select or any other button you chose & as long as the SAT button lights up when you press another remote control button- then your all set to go & everything should be working once again! I hope this helps -please let me know if there is anything else I can help you with! -Kirstie DISH Network
Mar 11, 2010 | DISH Network IR Remote Control
Sat button won't illuminate nor operate
Hi jscot myname is Mike Houston of DISH Network and I was going over your post and thereare a couple of things we can check. The first is to replace the batteries andafter the batteries are replaced push and release the SAT button and press select.If the SAT button did not light up the remote would need to be replaced.
Dec 30, 2009 | DISH Network IR Remote Control
I cant push the SAT button to control the satellite
Try pressing and holding the SAT button for about 6 seconds to see if it lights up, if not remove batts and hold SAT in till lights go out then replace batts and try again. your remote may need repalced if you have good batts and sat will still not light up.
Nov 30, 2009 | DISH Network IR Remote Control
The TV light is the only one that will light up, the SAT light will not light up. Also, pushing the TV button does not get all the other lights flashing, as it is supposed to do. This is a, replacement...
Hi pendley2I was reading over your post and seen where SAT button on your DISH remote willnot light up and I am very sorry for the in convince of that. If you put in newbatteries and the SAT button still will not light up it needs to be replaced.
Sep 22, 2009 | DISH Network IR Remote Control
Dish dvr uhf pro remote
i did everything i could at the moment but i got the soultion hold down the SAT button and if your control has a [green R] press it at the same time then it should swith to sat hold it down for like 30SEc it works trust me.............
Feb 22, 2008 | Universal Remote Control Dish Network...
DISH Network 135899 Remote Control Logo
339 people viewed this question
Top DISH Network Televison & Video Experts
S. Gontko
john milligan
Jaime Hernandez
Are you a DISH Network Televison and Video Expert? Answer questions, earn points and help others
