Question about RTO Brand New Phoenix TBF 440 Talking Body Fat Scale
How do I change the language on my phoenix tbf 440
My casio wave ceptor 3054 wv-58a is not working right. I live in Phoenix,Arizona and we don't observe daylight savings time and when I went to take it out of dst mode the day of the week is in a foreign...
The correct time zone setting for Arizona on this watch is YEA (Edmonton International Airport). Hold the adjust button for several seconds until the three code time zone starts flashing, then use the forward/back buttons to select YEA.You need to keep the DST mode off, so press mode once, then the forward button to select off in the DST select screen. From there, you can then press mode to manually adjust each time/date area individually. The final thing that you can adjust is the language, choose ENG for english. Press adjust to keep your settings, and you should be good to go.
Mar 14, 2011 | Casio Wave Ceptor WV57HA-1AV Wrist Watch
My laotop is languge italy i want change in english
It's in the Setup ... when you first turn your laptop on you will see instructions for "setup" It can flash on the screen very fast so be observent. The Language can be changed in most setup menus
Feb 25, 2011 | Acer Extensa 4620 Notebook
I had to change the batteries and now it only reads in "kg" how do i change that on the model 2204?
Since your problem started with a battery change, I am going to assume that method 1 is most likely going to fix your problem...Good luck!
Method 1
Press the Set and Up Arrow buttons at the same time. Release the buttons, the display will flash. Press the Arrow button to cycle through each weight mode until just the mode that you require is displayed. Then press Set. The display screen will flash to confirm your selection and store in memory.
Note: If weight mode is set to pounds or stone-pounds, the height programming mode will be automatically set to feet and inches. Similarly, if kilograms is selected, height will be automatically set to centimeters.
Method 2
Body Fat Monitor/Scales: BF-542, TBF-551, TBF-521, TBF-531, BF-681, BF-682, BF-679, BF-680, BF-578, all Ironman products, and all InnerScan products.
Select the preferred weight mode by using switch on the back of the measuring platform.
Jan 12, 2011 | Tanita 2204 Body Fat Scale
Getting error E 11 on unit.
ok here is what I found: •E - 11 is displayed when there is a loose connection between the control box and the weighing platform.•Confirm that none of connections between the scale and control box are loose or unplugged.•There may be excessive vibration which will disturb the measurement process.
you can dowload the manual here http://www.tanita.com/en/tbf-300a/184-catId.520093719.html. If those solutions do not work i reccomend contacting the manufacturer here http://www.tanita.com/en/contact-us/ as the unit may be under a warranty.
Apr 01, 2009 | Tanita TBF 310 High Capacity Pro Body...
Somehow my tanita ultimate scale has been switched from pounds to stones. How can I get it back to pounds?
Q: Why does "st-lb" or "kg" appear when taking a measurement?
A: The unit's "Weight Mode" has been set to measure your weight in units of stone-pounds (st-lb) or kilograms (kg). Tanita's Body Fat Monitors and the UltimateScales can measure weight in three different modes: lb (pounds), kg (kilograms) or st-lb (British stone-pounds). To change the setting, first find out which model you have (it should be written just above or below the display screen of the unit).
Method 1
Body Fat Monitor/Scales: TBF-611, TBF-612, TBF-621, TBF-622, BF-541, TBF-560, TBF-572. UltimateScales: 2000, 2001, 2001T. BF-662, BF-555, BF-556, BF-558, BF-559, BF-625, BF-626.
Method 2
Mar 15, 2009 | Health & Beauty
Scales show weight in kg. How to get them to show lbs.
Mar 13, 2009 | Tanita 2204 Body Fat Scale
Measurement is in kilograms instead of pounds
check if there is a tiny whole in the back you could probably poke it with a needle
Jan 01, 2009 | Tanita Health & Beauty
I have a tanita tbf-612 scale and the measurement changed to metric instead of pounds when the batteries died. How can I change it back as I don't see anything on the back to re-set the scale.
Jan 01, 2009 | Health & Beauty
RTO Brand New Phoenix TBF 440 Talking Body Fat Scale Logo
55 people viewed this question
Top RTO Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a RTO Health and Beauty Expert? Answer questions, earn points and help others
