Question about Toshiba Satellite P105-S9312 Notebook
I can't type @, # and ~ on my laptop
Laptop type: Toshiba Satellite Premium Series P105
Everytime I try to type @ (shift - 2), " comes out instead of @. As for # (shift - 3), poundsterling logo comes out. Any solution?
  • Anonymous Apr 01, 2014
    Regulators for Oxygen tanks ther are 2 types Pin Type and screw type what are advantages and disadvantages to both?
  • 72 Answers
You may have your NumLock enabled. That will make you type whatever blue characters are on the keys instead. Press your NumLock (sometimes Num Lk) button and see if that helps.
If that's not the case then you probably have the wrong keyboard profile enabled in Control Panel. (Thinks you are using a foreign keyboard layout of some sort.) If the above solution doesn't wok, open up the Regional and Language Options from Control Panel, select the Languages tab, and press the Details button under the Text services and input languages section. Make sure everything in there applies to you.
Posted on May 13, 2008
I cant type @, # and ~
Everytime I try to type @ (shift - 2), " comes out instead of @. The same problem for typing ~ (shift - 1) and # (shift 3), but other comes out. Any solution?
My Toshiba Laptop is P105 Professional Premium Series.
Thanks in advance.
on May 12, 2008 | Toshiba Satellite P105-S9312 Notebook
Toshiba Satellite P105-S9722 white screen on stat up
Don't assume. Diagnose.
Problem could be graphics chipset, Video Cable, screen Inverter, or LCD screen.
Graphics chipset:
1) Laptop OFF, monitor OFF, connect a VGA monitor to the VGA port, on the laptop.
(Back of laptop - Blue)
Example of a VGA Cable, and a VGA connector, (Port on laptop),
If you have a CRT type of monitor (Looks like a small TV), you can use it, or a flat LCD screen monitor with a VGA cable.
The Toshiba Satellite P105-S9722 Notebook PC, also has a DVI connector on the back of the laptop. (Next to the blue VGA port)
You can connect a flat LCD screen monitor with a DVI cable.
Example of a DVI Cable, and DVI connector,
2) Turn the monitor on. If a CRT type allow it to warm up.
Turn the laptop on.
By factory default the display should be on the external monitor.
If not;
Press, and hold down on the Fn key, (Bottom left), and tap once on the F5 key.
The F5 key is the Display Toggle-Over key.
You will see a list. It 'hot cycles' through the list, until you come to the external monitor device you are using.
External monitor display shows no white screen?
Your graphics chipset is good.
Go on with the diagnoses.
Problem is with the Video Cable, or in the Display Assembly.
(Screen Inverter or LCD screen)
Video Cable:
The Video Cable attaches to the motherboard under the Switch Cover, and about at the F2 and F3 keys.
It then routes under the left Hinge, and up into the Display Assembly.
From there it connects to the screen Inverter, and back of LCD screen,
Due to normal opening, and closing of the laptop, the Video Cable may become pinched, and pulled on.
This can lead to a simple loose connection of the Video Cable TO the motherboard, or TO the back of the LCD screen.
(The screen Inverter connection should also be checked)
Visual inspection will NOT do. You need to physically see if you can plug the motherboard connection, and LCD screen connection in.
It could be just loose enough you won't be able to see it, but will affect the display.
Sheath of Video Cable needs to be visually inspected for signs of damage. Signs of damage to the sheath, may also mean damage to the tiny wires inside the sheath of the Video Cable.
Assurance that the Video Cable is not the problem, means checking out, or have checked out, with a multimeter set to OHM's, to run a continuity check of all the wires.
('Mom and Pop' computer store. See if they will check it)
Or simply replace the Video Cable. (After you fire up the laptop, and see if loose connections was, or was not the problem)
(Left side connects to LCD screen. Right/Top connector goes to motherboard. Right/Bottom connector goes to screen Inverter)
Video Cable checks out OK?
Go on to screen Inverter.
The plastic thin frame in front of the LCD screen, is the Display Bezel.
The screen Inverter is behind the Display Bezel, and mounted at a location towards the bottom of the LCD screen frame.
A screen Inverter is tested with a sensitive multimeter. Read fairly expensive,
It is for this reason that those who do not have access to a sensitive multimeter, usually just replace the screen Inverter.
(Also low cost, and ease of access to replace)
Screen Inverter checks out OK?
Problem is the LCD screen,
For additional questions please post in a Comment.
[ Bet it's the video cable, or screen Inverter, that is the problem ]
[ Primer:
An LCD screen cannot produce light by itself. It needs an additional light source.
A Backlight is the additional light source.
A Backlight can be a CCFL, (Or two of them), or a series of LED's.
(Light Emitting Diode)
The Toshiba Satellite P105-S9722 Notebook PC, uses One CCFL for a Backlight.
A CCFL is a Cold Cathode Fluorescent Lamp.
Similar to Fluorescent lighting used in homes, and businesses, but on a MUCH smaller scale.
Average thickness is 2mm. That is a little larger than 1/16th of an Inch.
Average length is almost as long, as the LCD screen is in height,
General example,
A CCFL contains -> Mercury, just like Fluorescent lighting used in homes, and businesses.
A screen Inverter is used to convert the power from the laptop, for the Backlight, and LCD screen.
90 Percent of the Time the fault is a bad screen Inverter.
Primer over.
Oct 16, 2012 | Toshiba Satellite P105-S9722 Notebook
Hi Rabin,
hope you r doing good,
in laptops there are shortcut for num lock button
Hold the Fn (Function key) and scroll lock this will act as a numlock key
to type @ press shift +2
I hope i have answered your question
Thanks and Regards,
Mar 03, 2010 | Toshiba Satellite P105-S9312 Notebook
No sound
Your speaker wires may be disconnected from the sound board. See diagram 15 at . It's pretty easy to peak into the case when the front case screws are removed.
Dec 18, 2008 | Toshiba Satellite P105-S6024 Notebook
OS came on machine - no CD. How can I R&R hard drive?
Download Linux from PCLinux:
This works quite nice with many laptops, and I already replaced Vista with this.
Burn the ISO on a CD using Nero and boot your laptop with this.
Dec 14, 2008 | Toshiba Satellite P105-S6197 Laptop
Toshiba Satellite P105-S9312 Notebook Logo
390 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
