Question about Craftsman 21 Hp 42" Lawn Tractor Riding Mower Warranty
The bolt holding the blades is broken off - Craftsman 21 Hp 42" Lawn Tractor Riding Mower Warranty
    Problem Solver:
  • 9 Answers
Your st bet is to replace the entire spindle assembly.
Craftsman part number 130794,the bolt holding the blades is broken off - 3e9889e.jpeg
It's not as cheap as drilling out the old bolt and using an "easyout" tool to remove it, but the outcome is certain.
Better yet do a web search on "137645, 137646 Shaft Kit For 130794 Mandrel, AYP" and you can find the shaft only with bearings.
On Amazon:
Posted on Sep 06, 2010
Honda lawnmower blade broken at shaft
How To Remove Lawnmower Blade Adapter
If it's the blade that is broken, remove the two bolts that hold the blade onto the blade adapter. If the blade adapter is broken, it needs to be taken off the engine shaft. The Link shows a video on how to remove a blade adapter. Hope this helps......
May 01, 2014 | Garden
How do i replace a broken blade
Pull off the spark plug wire (safety precaution). Turn the mower on its side to expose the blade. You will have to get something to hold the blade in place while you remove the bolt ( I use a block of wood in most cases) Loosen the bolt, remove the blade and replace. Use the wood to hold the blade again while you tighten. You may be able to just sharpen the blade if it is not too far gone.
Sep 27, 2012 | Garden
How to change blade
UN BOLT CENTER BOLT AND/OR ANY OTHER (SOMETIMES 2) BLADE HOLD ON BOLT. MAKE SURE NEW BLADE IS:
1. CORRECT FOR MACHINE
2. RIGHT SIZE
3. USE LOCTITE THREAD LOCK ON BLADE BOLT THREADS BEFORE REINSTALLING
4. TORQUE BLADE TO MANUFACTURE SPECS
5. GO CUT THE GRASS
Jul 30, 2012 | Troy Bilt 5.5hp Self Propelled Mower
Cannot get saw blade off a makita 5090d saw.
Lift the guard and clamp the blade in a vice using a pair of soft jaws and then undo the bolt.
Jun 10, 2012 | Makita 5090d 96v Cordless Trim Circular...
Motor runs but blade wont turn belt not broken
Although there really isn't much info to go one from your description (type of mover, make and model would help). It sounds like you may have broken the shear pin on the motor shaft pulley.
Mar 28, 2011 | Garden
It's impossible to change a blade on a craftman edger. There is no way loosen the bolt holding the blade
Can you grip the blade and hold it still with say a pair of Vise Grips and remove the bolt that way? Lock the grips on the blade and then when it turns will it jam itself against the blade guard allowing removal. What type of bolt actually holds the blade on? Post back with more details.
Aug 16, 2010 | Craftsman Garden
How to remove a blade from a 2.5 hp sears table 10 inch tablesaw
First and foremost unplug the unit from the receptacle. Raise the blade as high as it will go and have it set to 0 degrees in a vertical position. Remove the throat plate (usually red) so you can access the bolt holding the blade in place. The saw came with a wrench for this purpose. It may have even come with 2 wrenches. One to remove the bolt holding the blade on and another to place behind the blade on the shaft to hold the motor. If it only has one wrench look for a small hole in the blade and use a screwdriver to keep the blade from turning. If there is no tool or hole to hold the blade then use a heavy scrap piece of wood to hold the blade while you remove the bolt. As you remove the blade notice the direction the teeth are pointing and put the new blade on turning in the same direction. You just reverse the procedure to put the new blade on. NOTE: Some saws have a motor lock that locks the motor and blade in position making it easier to change the blade. Just be very careful as it is easy to cut yourself on the blade.
Jan 10, 2010 | Craftsman 10" Table Saw
Can't get bolts loose on mower blades
The bolts that hold the blade need to be turned clockwise.
The bolts holding on the deck need to be turned counter clockwise
Jul 29, 2009 | Garden
How do I remove the old broken lawn mower blade. I can't seem to keep the bolt and nut from moving together when I try to loosen the bold. thanks in advance
i uses impact gun with 3/4 " socket.run it in reverse or you have to remove the stationary parts of the motor.mark them so u will know how to put them back together & somebody has to hold the armature will u r turning the nut on the blade.
Jul 27, 2008 | Black & Decker 19" Electric Lawnhog...
Craftsman 21 Hp 42" Lawn Tractor Riding Mower Warranty Logo
190 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
