Question about Altec Lansing Multimedia Computer Speakers
Altec n800f crossover network schemetic - Altec Lansing Multimedia Computer Speakers
What does the fuse holder look like oh an altec llanNsong subwoofer K
The fuse may be soldered on the crossover and won't look much like a fuse. It may be green with the letter F on it. Numbers represent the value of the fuse.
Feb 18, 2017 | The Audio Players & Recorders
Can i wire non amplified mid-range/tweeter speaker's on the inside of an altec acs250 sub woofer directly to the woofer speaker
Probably not. Somewhere there is a filter (crossover) that only sends the lower frequencies to the sub-woofer driver. Where that filter resides (either in the pre-amp, receiver or sub-woofer enclosure is yet to be known).
Oct 27, 2016 | Audio Players & Recorders
After increase volume of Altec lansing T612 voice are break
Also the crossover inside the Altecs must both be controlled.
The diafragms of the tweeters replaced, thats in most cases easy to do selfmade . look for examples on youtube .
What is Clipping Understanding Amplifier Clipping Clipped Signals
Sep 12, 2016 | Altec Lansing Audio Players & Recorders
I need my pantech networ pin
You can get network pin for Pantech Crossover (P8000) from the online vendor MobileUnlockSolutions.com .To get the service you need to submit your mobile model,country name,network provider name and IMEI number.
Nov 24, 2013 | Pantech Crossover (P8000)
Sim network unlock pin
You can get Sim network unlock pin for Pantech Crossover (P8000) from the online vendor Classicunlocking.com .To get the service you need to submit your country name,network provider name and IMEI number.
Nov 23, 2013 | Pantech Crossover (P8000)
How do you connect the altec lansing ada 890 speakers to a flat panel HD TV
You can use the audio output RCA outputs to connect to the speakers. You need to use a multi- connector to match the input of the Altec. You can get the mating connectors to the headphone to RCA which can be connected to the Audio outputs. Also you can use a network to match the input impedance, use a simple reisitive network.
Dec 09, 2011 | Altec Lansing ADA 890 Computer Speakers
I want to network two pc with windows xp using crossover cable,, how do i do it step by step pls.
Connect two computers using a crossover cable
If you need to connect two computers but you don't have access to a network and can't set up an ad hoc network, you can use an Ethernet crossover cable to create a direct cable connection.
Generally speaking, a crossover cable is constructed by reversing ("crossing over") the order of the wires inside so that it can connect two computers directly. A crossover cable looks almost exactly like a regular Ethernet cable (a "straight-through" cable), so make sure you have a crossover cable before following these steps.
Before buying a crossover cable, check your network adapter. Some newer network adapters automatically "cross over" when they detect that they are connected directly to another network adapter using a regular Ethernet cable.
To connect two computers with a crossover cable
This works best if both computers are running this version of Windows.
Plug each end of the crossover cable into a network port on the back of each computer.
On one of the computers that is running this version of Windows, do the following:
Open Network and Sharing Center by clicking the Start button , clicking Control Panel, clicking Network and Internet, and then clicking Network and Sharing Center.
In the network map at the top of Network and Sharing Center, double-click the Unidentified network? icon. (If you have more than one network, this icon will be labeled Multiple networks.)
If network discovery and file sharing are turned off, in Network, click the Information bar containing the following message: "Network discovery and file sharing are turned off. Network computers and devices are not visible. Click to change...," and then click Turn on network discovery and file sharing. If you are prompted for an administrator password or confirmation, type the password or provide confirmation.
In the Network discovery and file sharing dialog box, select one of the following options:
No, make the network that I am connected to a private network
Yes, turn on network discovery and file sharing for all public networks
The first option is usually the best choice because it only affects the network that you are connected to.
Notes
Networks created with crossover cables are automatically set up as "Public place" networks, which means that network discovery, file sharing, and printer sharing are off by default.
For Gigabit Ethernet or token ring networks, you will need a slightly different kind of crossover cable. For more information, contact a cable manufacturer.
Icons for both computers should now be visible in the Network window. Double-click each computer icon to share printers and other resources.
Note
If one of the computers is running Windows XP, it can take some time for that computer to appear in the Network window. You might need to move both computers to the same workgroup. You can do that by changing the workgroup on either computer. To change a workgroup, see Join or create a workgroup. You might also need to turn on file and printer sharing on the computer running Windows XP.
Hope this help!
Sep 06, 2011 | Pine Technology Motherboard Xfx Nforce...
Does the D-Link DES 1016D 16x10/100 Mbps Networking Switch accept either of strait-through or crossover cat 5e cable configuration to NICs?
Auto MDI/MDIX Crossover
All ports support auto-negotiating MDI/MDIX detection, which eliminates the need for crossover cables or uplink ports. The DES-1016D is the perfect choice for Plug-&-Play support for 10BASE-T and 100BASE-T networks.
See -->> http://www.d-link.co.za/des-1016d.php for further specs.
Hope this helps.
Feb 08, 2011 | D-Link DES 1016D (DES-1016D) 16x10/100...
RIGHT SPEAKER IS DISTORTED EVEN AT LOW VOLUME.
Either a bad crossover network component usually a capacitor, OR it is the Voice Coil in the speaker has gone faulty and is Rubbing against the Post. replace faulty component in crossover, or get the speaker re-coned/coiled, or buy a new one.
Mar 06, 2010 | Altec Lansing Multimedia Computer Speakers
380 people viewed this question
Top Altec Lansing Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Jerry Umali
Are you an Altec Lansing Audio Player and Recorder Expert? Answer questions, earn points and help others
