How to hook up cable and get more channels than 2-13????
Bought this tv less than 2 years ago...had cable hooked up to it through a a cable box and it worked fine.I can also get all cable channels by hooking up some vcr's to it....now, I have cable, but without a cable box and I can only get channels 2-13..I have tried everything, the cable techs have also tried with no luck..any suggestions?
  • 1 more comment
  • barbb372 May 13, 2008
    don't know if this will work 4 u or not, but we had the same problem actually 2 thing's. one was the tv was only programmed for 21 channels so we had to reprogram the tv.ok the other was we had to run through our vcr even though we had cable , we ran the cablr through the vcr that way we got all channel's,hope this help's some
    have a blessed night
    barbb372
  • Anonymous May 11, 2009
    my retarded tv has the same thing i only have 13 channels
  • Emmett Jester
    Emmett Jester Jan 07, 2014
    Thanks
  • 520 Answers
Change setting in menu to cable from tv or antenna. May be in channel setup menu.
Posted on May 13, 2008
    Problem Solver:
  • 10 Answers
Ok so i know what the problem is. It just happened to me. Under settings on your TV there will be an option that is to switch your tv to cable. Otherwise known as CTV just play around with the menus certain tvs have a built in setting which allows the first 13 channels. I dont know why it doesnt make sense. But anways switch that setting to CTV or cable tv and you should be recieving all channels
Posted on Feb 17, 2010
Why will my new tv not pick up any channels when using the auto channel search
It depends on if you have cable or are using an antenna. If you have cable, make sure you have the cable that runs in between them hooked up to the correct spots. If you're using an antenna, you might need to get a TV converter box. A couple of years ago, they stopped making regular TV channels and switched to only digital channels. Most older TVs don't work with digital channels, so you need a box that will convert the picture. You can get one at any place that sells TVs (walmart, amazon, etc)
Feb 02, 2015 | Televison & Video
Can't get TV picture after hooking up PS 2
How many sets RCA ports (for Video 1 / Video 2 so on and on) does your TV have?
Jul 26, 2008 | Panasonic Televison & Video
I am unable to record digital tv channels on my LG RC389H dvd recorder. I have a new tv with a digital tuner and have hooked them up but unable to view any digital tv on my LG player only the old analogue...
The RC389H is only deigned to receive standard TV signals, not digital. If you are routing through a straight cable line you usually can't access anything above 100 if you don't have a digital tuner. Try using a cable/satellite box if you haven't already, this bypasses the requirement for a digital tuner because the cable/satellite box has one of it's own.
Aug 27, 2011 | LG Televison & Video
Hi, I have a sony bravia tv ( klv20G300A) which was bought in Hong Kong about3 years ago . I haven't been able to get it to work with the uk digital signal. I am wondering about it's compatibility-...
This tv has analog tuner and you need digital tuner in tv to get digital signal in UK, alternate way is to hook cable box with this tv that will convert digital signal into AV output that will connect to AV input of tv to get cable channels.
Aug 03, 2011 | Sony BRAVIA KLV20G300 20 in. EDTV-Ready...
Try to re tune but it goes throught the motions but does not pick up any channels at all. Tried this many many times. all cabled up correctly. help required please. Its a TWFdigital STB501 Box (Digital...
You need to have a newer digital antena hooked up to it also if your tv is flat panel and its less than say 2 years old the digital tuner should be built in. I dont mean to sound dumb but if you are using a digital coverter box and thats what the antenna is hooked up to make sure your in the menu of the converter box. You can determine this by what channel the TV is on. If you hooked the Box to the coaxle then your TV should be on 3 or 4 if you used Composite(RCA) cables then it should be on aux. But once again I will say the antanna makes all the difference with digital. Old ones do not work. Please respond with more info if this doesnt help.
Dec 14, 2010 | Televison & Video
The mitsubishi model vs-60805 tv will provide air channels off of cable hook-up, but does not provide cable channels. What needs to be done to recieve cable channels? The menu does not provide an apparent...
Mitsubishi VS-60805 is 1999 model tv and unable to receive digital cable channels because it is equipped with analog tuner that can not receive cable channels because it is almost 11 years old.
You need to hook Cable Box in AV input of tv, plug digital cable in cable box and get digital cable channels in tv. Cable box has its own remote control and inbuilt digital tuner to receive all digital cable channels and widely available in Store, Radio Shake, amazon.com etc.
Let me know if you have additional question.
Thanks.
Aug 07, 2010 | Mitsubishi Televison & Video
HDTV converter box only brings in 3 channels
We have a pretty good signal when we use the antenna but when we hook up the converter box we get no channel weak signal no channels we have a amplipher on it it does not help .
Nov 22, 2008 | Insignia Digital-to-Analog Converter for...
TV channels
If cable is hooked through cable box with a coaxial cable, then turn tv to ch 3 or ch 4 as appropriate.
If cable is hooked through any other type of cord (red/green/blue or red/white/yellow) use the AV+ or Source button to change your source to Av1, AV2, HDMI, or however you have the cable box hooked to TV (I am assuming your TV is a Philips).
Feb 24, 2008 | Philips TV Tuner Video Capture PCI Card -...
Local tv channels come in snowy
you have cable and the stations are still snowy? could be tuner do you have a box or directly hooked up to tv, try unhooking box if you have one and directly hook it up to tv if you havent already done so
Jan 21, 2008 | Zenith C32V37 32" TV
Connecting VCR/DVD combo
Put the Tv on Channel 3
Jul 11, 2007 | Sanyo DS25390 TV
Televison & Video Logo
2,342 people viewed this question
Top Televison & Video Experts
