Question about PQI 512MB Intelligent Stick USB 2.0 Flash Drive (437353) Hard Drive
I found no instruction booklet and I never used a flash drive USB 2.0 Flash drive. Is there somewhere I can find this on line?
  • 6,487 Answers
This device is very easy to use you don't actually need a booklet for it , this use as a portable storage disk just plug it to a usb port of you computer then you can save files on it.
Posted on May 13, 2008
How do I record from an LP to a flash drive onPLTTB9U?
Have you tried formatting the flash drive on the computer before using it on the device?
Dec 11, 2014 | Electronics - Others
Tip
Installing Windows 7 to ANY Netbook Using USB Drive
To copy the Windows 7 ISO file to a USB flash drive Before you begin:
  • Make sure you've already purchased and downloaded the Windows 7 ISO file to your PC.
  • Make sure you've copied any files on the USB flash drive to an external location. The Windows 7 USB/DVD Download Tool will erase any data on the USB flash drive.
  1. Click the Start button d49affd.jpg, click All Programs, click the Windows 7 USB/DVD Download Tool folder, and then click Windows 7 USB/DVD Download Tool.
  2. Under Step 1 of 4: Choose ISO file, click Browse, browse to the Windows 7 ISO file you downloaded, click it, click Open, and then click Next.
  3. Under Step 2 of 4: Choose media type, click USB device.
  4. Under Step 3 of 4: Insert USB device, click your USB flash drive in the drop-down list, and then click Begin copying.
  5. If you see a dialog box that says that there isn't enough free space on the USB flash drive, click Erase USB Device, and then click Yes.
  6. When the process is finished, click the Close button 890548ff-eff6-4f93-ba12-92692a835f86.jpg in the upper-right corner of the window.
To install Windows 7 using a USB flash drive If you don't need to start your netbook using the USB flash drive, you can simply browse to the USB flash drive, and then double-click setup.exe to begin Windows 7 installation.
To start your netbook using the USB flash drive:
  1. Turn off your netbook, insert the USB flash drive, and then restart your netbook.
  2. Press any key when prompted, and then follow the instructions that appear.
  3. On the Install Windows page, choose your language and other preferences, and then click Next.
    If the Install Windows page doesn't appear, and you're not asked to press any key, you might need to change some system settings. To learn how to do this, see Start your computer from a Windows 7 installation disc or USB flash drive.
  4. Follow the instructions to finish installing Windows 7.
on Apr 19, 2010 | Computers & Internet
How do i reformat a data traveler kingston 2 gb usb flash drive? i tried formatting but it shows that it is Chipsbank usb flash drive with only 8 mb memory and then it wont complete formatting when i...
Are you positive there isn't a flash drive stuck in a USB port somewhere else on the computer? Very peculiar for the computer to be recognizing a completely different device.
May 18, 2011 | Electronics - Others
My drive is almost fill a 4g now when i plug it in it is not reading any of the stored files.
Hello there!
USB flash drives in general, are wonderful little tools that allow people to store a relatively a large amount of data in a compact and portable interface that is extremely easy to use at all. The downside of storing lots of critical data on a USB flash drive, however, is that they're fairly susceptible to damage and that you can lose all of your information immediately if something goes wrong. When troubleshooting a USB flash drive, there are several key things to check and to remember that will help you to determine whether your flash drive is destroyed or not.
1. Look and see whether or not your USB flash drive's indicator lights are activated when it is plugged in to your computer's USB port. The vast majority of USB flash drives have small LED lights located somewhere on them that flash intermittently when they're hooked up to a computer. If your light does not turn on, then it's either not plugged in properly or is damaged and likely not repairable.
2. Make sure to download and install the right driver software for your USB flash drive.
3. Try your USB flash drive on more than one computer before giving up on it altogether. If it works on another computer, then the problem is likely with your computer hardware or software, not with the USB flash drive.
4. If you cannot restore your files, you may use a third party software to recover them.
Regards,
fossildude
Mar 01, 2011 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
I purchased 4GB Cruzer ubs 2.0 flash drive. before I open the package, will there be instructions inside?
OK, don't worry.. It will all work Out-of-the-box, The instruction are simple. Unpack, Pluc in to a USB port, software will detect and install necessary drivers... then ya good to go. Simply treat it as another drive... Cut, copy, Paste.. If you want you can install any software from the manufacturer, that may have come with the unit.
Jan 18, 2010 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
Instructions for using usb flash drive
there is a problem with your computer usb port.
try to use other computer
Jul 06, 2009 | Computers & Internet
2GB USB Flash Drive
Hi. Here are the steps:
1. Plug your flash drive into a USB port on your computer.
2. If you use Windows, the flash drive will appear as an icon in the "My Computer" window, with a caption along the lines of "Removable Device" or "Flash Drive". Note: Please wait the first time you plug it in - Windows needs to "discover" the flash drive, and will essentially set itself up to recognize the device so that it's usable. If you use a Mac, the flash drive's icon will appear on your desktop with similar captioning mentioned above.
3. You can double-click on the icon to open the flash drive and see its contents. You can drag files from anywhere into that window, or over the flash drive's icon itself to copy files into it.
Mar 20, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Ethernet
If you have access to another computer with internet (friend, relative, neighbor, etc...), get a USB flash drive or thumb drive (2 or 4 GB can be found for around $10 - $15), then follow these steps:
1. locate your express service tag code, usually found on a sticker somewhere on the computer's case, and write it down.
2. go to Dell's support website: http://support.dell.com
3. Click "Drivers and Downloads"
4. Choose "By Service Tag"
5. Enter your Express Service Tag and click GO
6. Scroll down to "Network"
7. Download the "Recommended" driver and save it to the USB flash drive.
Take the USB flash drive back to your computer, open it in Windows Explorer, then double click the downloaded file and follow the installation directions from there.
You could also do the same with a CD-R if you don't have a thumb drive, but it's a bit more involved.
Feb 01, 2009 | Dell Optiplex GX60 PC Desktop
Massstorage
This will walk through the steps to create a bootable USB flash drive for the purpose of installing a Vista or Windows 7 OS. These instructions assume that you have a computer with Windows Vista installed on it.
Required:
· USB Flash Drive (4GB+)
· Microsoft OS Disk (Vista / Windows 7)
· A computer running Vista / Windows 7
Step 1: Format the Drive
The steps here are to use the command line to format the disk properly using the diskpart utility. [Be warned: this will erase everything on your drive. Be careful.]
Plug in your USB Flash Drive
Open a command prompt as administrator (Right click on Start > All Programs > Accessories > Command Prompt and select “Run as administrator”
Find the drive number of your USB Drive by typing the following into the Command Prompt window:
diskpart
list disk
The number of your USB drive will listed. You’ll need this for the next step. I’ll assume that the USB flash drive is disk 1.
Format the drive by typing the next instructions into the same window. Replace the number “1” with the number of your disk below.
select disk 1
clean
create partition primary
select partition 1
active
format fs=NTFS
assign
exit
When that is done you’ll have a formatted USB flash drive ready to be made bootable.
Step 2: Make the Drive Bootable
Next we’ll use the bootsect utility that comes on the Vista or Windows 7 disk to make the flash drive bootable. In the same command window that you were using in Step 1:
Insert your Windows Vista / 7 DVD into your drive.
Change directory to the DVD’s boot directory where bootsect lives:
d:
cd d:\boot
Use bootsect to set the USB as a bootable NTFS drive prepared for a Vista/7 image. I’m assuming that your USB flash drive has been labeled disk G:\ by the computer:
bootsect /nt60 g:
You can now close the command prompt window, we’re done here.
Step 3: Copy the installation DVD to the USB drive
The easiest way is to use Windows explorer to copy all of the files on your DVD on to the formatted flash drive. After you’ve copied all of the files the disk you are ready to go.
Step 4: Set your BIOS to boot from USB
This is where you’re on your own since every computer is different. Most BIOS’s allow you to hit a key at boot and select a boot option.
I used these instructions to get my new Dell Mini 9 laptop loaded with Windows 7 (the PDC bits). HTH.
Jan 23, 2009 | Computers & Internet
Usb flash drive
It is simple to use, simply plug it into a working USB port on your computer and Windows or Mac will detect it as an external drive device. You will find the new drive under My Computer. The bottom right may display a "found new hardware" or something similar. Once you find your drive, open it and choose what you want to put on it. Just drag everything you need onto the new drive. There is a possibility that you have to format it first. Do do that, just right click on the drive device and choose Format. Use FAT or FAT 32. To remove the USB drive, find Safely Remove Hardware close to the time, right click it and select remove. This is more important on a MAC because data could easily get erased if removed without giving instruction to remove it.
Oct 29, 2007 | Toshiba 1GB USB 2.0 High-Speed Flash Drive...
PQI 512MB Intelligent Stick USB 2.0 Flash Drive (437353) Hard Drive Logo
59 people viewed this question
Top PQI Computers & Internet Experts
Arora Singh
Arora Singh
William Alequin
Are you a PQI Computer and Internet Expert? Answer questions, earn points and help others
