Question about HP 2159M Monitor
My hp2159m monitor keeps resetting when I turn off pc and then on , keep having to factory reset to make it look normal, also switches to foreign language when I reboot pc
agnelkj
  • 210 Answers
SOURCE: My printer keeps requireing a power reset
hi,
try to perform a semi-full reset
> unplug the power chord while the printer is turned on
> press and hold the # and 3 button on the printer at the same time.
> while holding it, plug the power chord. wait for 5 seconds and release your hands.
> once the reset is finished, check whether you are having the same problem.
thanks and regards
agnel
Posted on Mar 18, 2008
  • 125 Answers
SOURCE: Reset Monitor back to factory spects.
Menu
Advanced
Factory Recall
Select
Select
(select must be pushed a second time to start the factory recall.
Posted on May 04, 2008
siawolf
  • 749 Answers
SOURCE: reset my computer
Recovering during startup Use the following steps to perform a recovery from the hard drive :
  1. Backup files from the My Documents folder and from other folders you may have created.
  2. Disconnect all connected devices (such as the Personal Media Drive, USB drives, printer, and fax), remove media from drives, and remove any recently added internal hardware. Do not disconnect the monitor, keyboard, mouse, and power cord.
  3. Turn on the computer.
  4. Just after the first screen appears (the logo screen), press the F10 key repeatedly until a recovery menu appears.
  5. Select one of the following procedures, depending on which recovery type you want to perform:
    • To perform a standard system recovery, click Next , and then click Yes .
    • To perform a destructive recovery, click Advanced , (select Destructive Recovery ) and then click Next . CAUTION: A destructive recovery will format the hard drive. This will delete all the information on the hard drive and reinstall Windows XP and the original software that came with the computer .
  6. Read and respond to each window and screen that appears.
  7. After the System Recovery is complete, the computer restarts and continues into Windows setup. Complete the setup screens and wait until the computer finishes the setup. NOTE: It may take a long time to complete Windows setup. This time varies and may take over several hours, depending on the amount of files that were stored in the user account folders (for example, My Documents and the Desktop).
  8. Before using your computer, update and protect your computer. For more information, refer to Things To Do After Performing a System Recovery in Windows XP .
  9. Reinstall applications that you added after purchasing the PC, and any files you need from backup.
Posted on Apr 05, 2009
seeker5211
  • 1089 Answers
SOURCE: hp laserjet 2840 - need to reset language to
Under device settings Go to system settings, Then go to system setup. You can change the language from there.
Posted on May 17, 2010
  • 14 Answers
SOURCE: Monitor optimum size
Do you have the latest Graphics drivers?
Posted on Jul 17, 2010
How to factory reset?
What would you like to factory reset?
product.
make.
model,
Aug 09, 2015 | Computers & Internet
My 48 inch television keeps turning off by itself is there a reset? I have to keep unplugging it.
There is no such external reset button to this TV. There are two types of reset to TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight; will be better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
As far the set do not switch On; you can't enter its service mode. If the set switches ON for a while; say 2 seconds or so, and then switches Off by itself, the main board is faulty.
Dec 14, 2014 | Olevia LT42HVi 42 in. LCD Television
Osd menu keeps flashing up
Try reset screen to factory default settings.
If you have a sensor on your monitor, try turn that off (done in the On Screen Display).
Check for buttons that might be stuck (unless its touch screen ones).
Apr 06, 2014 | Computers & Internet
My daughter kurio 7 keeps resetting itself any solution for this?
You could factory reset the tablet by turning it of then while holding the power button press the volume up and you will be brought to a menu to factory reset it. It will ask you if you are sure and you can confirm. KEEP IN MIND FACTORY RESETING IT WILL DELETE EVERYTHING ON IT.
Jan 31, 2013 | Computers & Internet
I have a monitor that keeps flashing colours and can't turn off. Many threads tell me to reset it to factory settings, but how do you do that if you can't even get the menu to come up?
Try holding the menu button in for 10-15 seconds. Try pushing both power and menu buttons together.
It may be toast.
Take care!
damnor01
Sep 12, 2012 | Dell E197FP
My HP2159m monitor has changed its display, now showing a negative print on all pictures and its color background is now black with white printing. Some headlines, such as Google News, are all in yellow....
jskalko, Have you proved that your pc is not the problem by connecting a "known-good" monitor to it?? Will your 2159m unit work same way when connected to a "known-good" pc??? Do some "test" swapping first! Have you verified connector gold pins are not damaged on monitor cable?? 12fixlouie
Sep 06, 2010 | Computers & Internet
My computer monitor keeps saying auto adjust how do i fix this
Usually if the auto adjust is flickering intermittently you can attempt to reset the internal values to the factory settings. To do so: press the menu key on your monitor then choose factory reset. Press the menu button again then select all settings.
Jun 19, 2010 | ASUS VW192S Monitor
Starview box Keeps Re-Booting . l recieve a
try this delete the channels all of them but do not do a factory reset manually delete turn the emu off then go back and rescan and turn the emu back on but please do factory reset the box
Apr 27, 2010 | StarTech.com StarView SV211K 2-port KVM...
Contrast 100 window keeps appearing on screen
try to use the monitor menu button and do a factory reset, it should take care. try to unplug the monitor cable from the tower you will get monitor self test if its good then the problem is not with the monitor it should be the problem with the tower.
Dec 07, 2008 | Dell Dimension 2400 PC Desktop
HP 2159M Monitor Logo
180 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
