Question about eMachines T3604 PC Desktop
Board and power supply both dead, hard drive and contents still intact
  • eMachines Master
  • 1,183 Answers
if you have already determined that the motherboard and power supply is dead . Then the only solution would be to replace the same. There is power supply tester available in any local computer store. You can get one to check the power supply. Because if the system is not turning on at all, and the same is not caused by a power surge etc. the motherboard still has chance that it is good.
Thanks for using fixya
proton
Posted on Sep 06, 2010
Computer is dead, need access to hard drive content
your best bet would be to goto ebay and buy a kit which turns your hardrive into an external drive ..... determine what kind of hard drive it is and buy a kit .... ide or sata etc either way you will need to buy the coverter
Mar 29, 2014 | Western Digital Computers & Internet
Replacement controller board required
unlikely to get a board
dead is dead for most hard drives
however there are people who collect dead hard drives and can interchange boards as the failure can be the reader arm or laser and the board is in good condition
ask around the computer repair shops for anybody that they know off
Jan 13, 2018 | Iomega 34579 1 TB USB 20 Hard Drive
Can't start HD, I can hear only biping sound
a biping sound is usually indicative of either a dead drive, or not enough power on the USB bus (for unpowered external drives).
If the drive will take an external power supply, but is not connected to one, try connecting a power supply to it.
If the drive is out of warranty, try removing it from the external enclosure and hook it up internally to the PC. Sometimes the enclosure interface fails. If the drive makes the same noise inside the PC, it's likely dead.
May 17, 2012 | Seagate Expansion 1.5 TB USB 2.0 Portable...
My 500gb ext. seagates freeagent go is not detected in any pc, showing device driver software not fond, white light is blinking repeatedly...... please any solution
The drive is no longer recognized because the controller processor from the board inside it has failed. This is unfixable, the unit is dead. But you could salvage the actual hard disk inside it, it might still be operational and the data on it intact - just take it out and connect it directly inside a desktop.
Apr 16, 2011 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Solid green light until power button turned on the light goes out disconected power supply from mother board and everything else and plugged it in nothin happens is it dead Jim
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test the leads that attach to your ((hard drive from the motherboard)) or replace all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your ((motherboard to hard drive))
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they are probably old and faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error
hope this helps
dont forget to vote
Feb 02, 2011 | HP ATX-300-12Z (ATX30012ZBD) 300-Watt...
Dell Inspiron 530 won't start up - is motherboard dead?
From your description, I agree with you assessment of a likely Motherboard failure.
Mar 09, 2010 | Computers & Internet
500Gig HD Power Supply has Died - What can i do?
the power supply is probably dead. if its under warranty return it for replacement. if not under warranty have a local technician check the power supply.
Feb 13, 2009 | Maxtor Personal Storage 3200 (M1227310)...
Power Supply
Check all power cables plugged into M/board if these are correct
remove all hard ware
hard drives / cd player and anything else
except for video and memory and test to see if it boots. If it does, one of the removed hardware is faulty if it does not then you have M/board failure
Aug 02, 2008 | E-Machines Emachine T5026 power supply **...
Worked fine for a year, now not recognized or functioning
I had the same issue- light was blinking from red to blue, could not get my computers (I have a Mac and a PC) to recognize the drive, sounded like the drive wasn't powering up...
I replaced the Acom drive enclosure with a new one (CP Technologies). I don't know if the drive enclosure or power supply was at fault-- but it wasn't the internal drive. Plugged it in and amazingly all my data was back. For thirty bucks it was far less than sending out the drive to a 'data recovery' expert!
Jun 09, 2008 | Acomdata (HD320UFAPE5-72) (HD320UFAPE572)...
5-yr old Maxtor 160GB fw/usb down
drives dead. Head crash problem.
The read head, has clattered the disk(s)
the only other option is to swap the logic boards over ( if they,re identical ) ** circuit boards on the drives**
Mike @ Compurepair.
Feb 22, 2008 | Maxtor Hard Drive
eMachines T3604 PC Desktop Logo
71 people viewed this question
Top eMachines Computers & Internet Experts
Computer Links
Are you an eMachines Computer and Internet Expert? Answer questions, earn points and help others
