Question about Westinghouse WWS833ES Super Capacity Top Loading Washer w/ Precision Wash System
My washer starts of just fine but when going in spin cycle its slow and wont drain belt looks good,its just looks like the motor wont go into high speed
  • Westinghouse Master
  • 43,501 Answers
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Posted on Sep 06, 2010
2 Suggested Answers
  • 142 Answers
SOURCE: Washer will not spin at high speed
check for any blockages around pump and air trap area.
Posted on Sep 14, 2009
WFS1073DD front load WASHING MACHINE Everything works but will not spin fast enough to spin the water out. It spins very slow
Early automatic washers used a motor with multiple windings to provide the various speeds required by different parts of each wash programme. Modern washers use an entirely different sort of motor and the speeds are selected and controlled electronically with feedback to ensure the speed is correct.
I suspect the problem is the electronics - the part of the programmer and controller that regulates the motor speed but you should check the motor and motor brushes, the drive belt and all electrical connections as a matter of best practice before you spend money...
Aug 13, 2017 | Washing Machines
My washer has slow drain and won't spin out completely. What might be the problem?
Repairing a Washer That Won't Drain or Spin ' ThriftyFun
www.thriftyfun.com/Repairing-a-Washer-That-Wont-Drain-or-Spin.html
Did everything look at everything that has to do with slow water draining. ReplyWas ... My washer washes fine, but it won't drain the water out or spin on any cycle. The guy who .... My Kenmore 417 washer will not completely empty and spin.
my washer won't spin and empty? ' Yahoo Answers
https://answers.yahoo.com/question/index?qid...
Jan 15, 2008 - If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many washers, a small sock or other piece of clothing ... My Whirlpool washing machine won't empty all of the water after ...
Mar 21, 2013
Clothes washer won't spin clothes to drain water out?
Jun 11, 2008
More results from answers.yahoo.com
Why won't my washer spin or drain? - Kenmore 110 Series ...
https://www.ifixit.com/.../Why+won't+my+washer+spin+or+drain
iFixitMar 16, 2014 - Belt, Water Pump If the washer won't drain the pump belt might havebroken or might have worn ... It will fill with water but won't spin or drain on its own. ... Keep in mind that any water in the washer will pour out of the hoses when removed. ... I would have had to take apart entire washer to fix clogged pump.
My washing machine won't drain - LaundryDoc.com
www.laundrydoc.com/Washing-Machine.../My-washing-machine-wont-...
If your washing machine will spin but it won't pump water out, then the drain line is probably clogged up. In most washing machines, a small sock or small piece ..
Jan 05, 2016 | Washing Machines
GE front load washer model number WBVH6240HWW SERIAL NUMBER RM200099T spins freely by hand but started smoking and belt behind looks fine. What could be the problem. Before the smoke started when spin...
Hmm... Kind of difficult to say for sure. Does your inner spin basket wiggle up and down? If so, you've got a main bearing going. Also, put it in a spin cycle for a minute or so and then try smelling the windings on your main motor. If they smell burnt, you'll need to replace the main motor. Also, one last thought, check to see if your drain pump overheats. I say this because the drain pump is active during the spin cycle and a bad drain pump can sound extremely noisy and start overheating.
I hope this helps. Good luck!
Oct 19, 2014 | Washing Machines
Washer belt is loose, & seem to slip at start of spin cycle.
there are several drive belts for this model... check here to see if the one you are fitting is the correct one... also,is the tensioner siezed? causing the tension to be too slack therefore allowing the belt to shred at speed?
check here .. http://www.partselect.com/AppliancePartList.aspx?Brand=Admiral&Appliance=Washer&ModelNum=&Type=Belt&MinSize=U&MaxSize=U&Electrical=U&Metal=U&Plastic=U&OneColor=U&PageSize=15&FirstPart=1
Dec 03, 2008 | Admiral AAV7000A
Final spin cycle problem
Sounds like maybe the clutch is worn?? Ge has several versions of this washer out some use a clutch and some dont Does yours have a clutch attached to motor or is it a solid pulley? Also GE uses the slow speed to start the spin and then kicks into high one or 2 mins into final spin. Is this noticable or does it sound like it starts slow and then never shifts???
Jan 20, 2008 | GE WBSE3120B Top Load Washer
Spin/Drain cycle...Kenmore 417.40042990 Front load belt drive washer.
If the water is draining quickly (less than 30 secs) every time, than it sounds like its sensing an out of balance load, the CCU looks for this.... Before every spin cycle it goes through an out of balance routine it will do this even when empty.....It speeds up, slows down and will tumble again at least once....then speeds up ....looks at motor amps......decelerates.....looks at rate of deceleration.......Then decides if its ok to spin at the high speed...or if it should tumble again to distribute the clothes....If it cant balance itself to what it like than it will spin at a lower speed like yours is doing if its bad enough than it wont spin at all really (very slow). Im sure you checked the shocks while you were looking at the pump, but double check that there not broken at the mounts, or lots of grease at the base mount. If thats all good than you should try this......Sort a large size load of just regular tshirts and casual wear (no towels, jeans). Let me know how it spins then. Also make sure that its draining quickly every time. Sometimes the drain pump can appear fine and not be starting every time.
Jan 19, 2008 | Washing Machines
Wash but no spin
1st of all is there a spin cancel buuton on this machine and has it been activated, or is there a spin speed selector knob and has it been turned down...is inner drum easily turned by hand.if it is ok then belt tension could be suspect (tighten)im sure there is an out of load balance detection circuit on the main circuit board....also is it draining ok because it wont spin until it cant dectect low or no water prior to final spin.....also if it has a programme dial the select a spin programme on another section of selector dial.........hope this is of some help...
May 08, 2007 | Zanussi F1045W Front Load Washer
Drain pump starts and stops prior to final spin cycle
Jayron, is the motor jogging? start to spin, stop, start to spin stop. If so, your motor is jogging between the high and low start windings. The motor during spin should start on the high speed windings and stay there until most of the water is drained. GE came out with a new motor, harness and run cap because of this. If you have a meter, there should be a white and white/red wire going to the motor. If you have a steady 120V and it's doing this jogging, replace the motor with the kit...Let me know if this the issue, Catriver..post back.
Nov 05, 2006 | GE WWSE5200B Top Load Washer
Westinghouse WWS833ES Super Capacity Top Loading Washer w/ Precision Wash System Logo
176 people viewed this question
Top Westinghouse Washing Machines Experts
Dan Webster
Dan Webster
Harjeet Singh
Are you a Westinghouse Washing Machine Expert? Answer questions, earn points and help others
