Question about MSI MEGABOOK M510C Notebook
Laptop will not power on, remove battery and laptop still does not power on, Power supply is OK - when power button is pressed led flashes momnetarily then goes out. I suspect the mainboard is the problem
    Sergeant:
    Champion:
  • 233 Answers
The problem might be with the display adapter or with the motherboard malafunction.
Visit the below weblink for more information on how to troubleshoot the issue:
http://notebook-solutions.blogspot.com/2009/05/notebook-solutions-notebook-solutions.html
Posted on Sep 06, 2010
Thought I should add more detail about what the laptop is doing. The laptop sat for a long time with a dead battery, because the power supply low voltage wire got chewed by one of our puppy's when it was...
from the web -
1 Removed the battery
2 Removed the AC power
3 Plugged in the AC power again
Note:- At this point the light from flashing amber light to solid green indicating AC Power
4 Plugged in the Battery
Note:- Solid green AC power light and Amber charge light
Oct 30, 2013 | Toshiba Satellite C655D-S5084 Laptop
E system 1212 Laptop won't switch on. Power
Laptops are so integrated that usually a system failure that involves power issues such as in your case where you cant get it turn on with anything on the screen mean the mainboard (motherboard) is damaged. This usually leads to buying a new laptop or paying for the board to be replaced which usually costs as much as the laptop.
May 12, 2011 | Computers & Internet
Dell inspiron 6000 dead when connect power adeptor to laptop the led light on psu goes off is this mother board fault or psu.
If the led on the power supply turns off after connecting it to your laptop, the problem most likely lies with the power supply especially if the machine will run on battery power. This can be tested by
1. Turn the laptop off.
2. Remove the battery and power supply plug.
3. Press and hold the power button for at least 15 seconds to reset the laptop.
4. Replace the power supply plug into the laptop without replacing the battery.
5. If the computer will not start and there are no lights turning on on the laptop the power supply is bad.
6. Replace the battery and attempt to start the machine both with and without the power supply plugged in.
Apr 04, 2011 | Dell Inspiron 6000 Notebook
Acer aspire 5552nwxmi notebook can't power on.
Unplug the battery and power supply from the laptop, then press and hold the power button for 25sec(No battert and power supply), then connect the cable back to laptop, then try to turn on the computer, if its turning on hten connect battery back to laptop...
Nov 24, 2009 | Acer Computers & Internet
I have a HP ZD8000 laptop, which wont turn on. When I press the on button the LED's light up, and sometimes the fans begin to fire up, but only for a split second. When I press the on button whilst both...
Try just the power supply fromt he wall to the laptop without the battery inserted. If it comes on and then turns off, you probably have a bad power connection. DC power jack may be bad and would need to be replaced or re-soldered.
-=/ Daft Tech /=-
Oct 23, 2009 | HP Pavilion zd8000 Notebook
Inspiron 1150 won't turn on. Noticed recently that battery life seemed shorter, plugging it in did not prevent it from shutting down after receiving the low battery warning, and it took a long time to re...
A fast check to determine whether you have a problem with the power adapter, power cord or the laptop's battery is to turn off the laptop, remove the battery, connect the power adapter, turn on the laptop & see if it works.
If the laptop works directly from the power adapter with the battery removed, then the power adapter is good. In this case we can suspect that the battery is defective.
Oct 18, 2009 | Dell Inspiron 1150 Latitude D600 14.1 LCD...
Does not power up.
Remove the battery and try to turn on the laptop without the cord plugged in to allow the device to completely discharge. Put the battery back in and hold the power button in for 45 seconds, the lights should flash and then turn the laptop on normally.
This always works for my laptop.
Jun 26, 2009 | Computers & Internet
HP Pavilion zd8000 don't startup
have you even try to remove the battery in your laptop?
if not try to remove it in a miniute then put it back again.
maybe it is in standby mode.
Jan 23, 2009 | HP Pavilion zd8000 Notebook
Toshiba Laptop SPA 10 -WONT START
that just sounds like the hard drive running, try plug an external monitor and see what happends
get back to us
regards
Nov 27, 2008 | Computers & Internet
Power problem in monitor
This type of problem generally occurs when adoptor stops working and battery goes down. Show first of all check your power adoptor, its working or not, to check-out remove battery and use power adoptor then try to boot. If there is power led on means adoptor is ok otherwise try to reconnect and also check whether the power supply is ok for adoptor. For canfirmation use another adoptor.
If above not working then you can try to these steps:
1. Remove Power connection (Adoptor connection to Laptop).
2. Remove battery.
3. Re-Connect power to laptop.
4. Make switch on.
If above does not work then after step 2 try the followings
A. Press and hold power button for abt 20-30 secs. keep holding on and insert Power connection now if power led get on leave the button. After that it should on.
If all above didn't solve your problem, then its time to take tour of service centre.
Thanks and Good Luck
Iqbal
Aug 16, 2008 | Dell Vostro 1500 Notebook
MSI MEGABOOK M510C Notebook Logo
171 people viewed this question
Top MSI Computers & Internet Experts
vsri9
David
David
Matthew Spark
Matthew Spark
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
