Question about Kenmore 23822 Top Load Washer
Will not start - power plug is fine - Kenmore 23822 Top Load Washer
    President:
  • 3,773 Answers
This probably involves the spin lid switch.
You can tape the two wires to the switch together and it'll work just fine
Also check the plunger on the lid to see if it is not broken off
If this was helpful please rate me.
IMUFO2
Leo Ponder Appliance-Tyler,Texas
imufo2@sbcglobal.net
Posted on Sep 06, 2010
Completely dead acer chromebook..working fine on battery when plugged in died
So did you unplug the power supply and try to restart it? When you plugged the power supply in did the power light come on on the power supply showing it was working? Blue light usually.
Sep 23, 2016 | Acer Computers & Internet
Van has been loosing power going up hill. Runs fine on level land and going downhill. lately it has been stalling when u first start it up.
try checking your crankshaft or tps throttle position sensor it could cause you to lose power at times
Apr 02, 2014 | 2005 Kia Sedona
Starts up fine but has no power under a load
You said that it starts fine, so lets start with the easy stuff. Have you checked the air filter, spark plug, and valve lash lately? If filter dirty, you can gently tap it and knock out a lot of junk. For the spark plug you can clean it with a wire brush. If you do not feel confident in the filter or the plug, replace them, they are not too expensive. Try starting and test it, if still lacking power, check and set valve lash if necessary to .004, four thousandths with a feeler guage.
There are a couple other things that are a little more involved. Please let me know how it goes.
Aug 13, 2011 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
Toyota hilux 3ltr diesel,i put new glow plugs in about 3 weeks ago & it fixed the starting problem going fine.now it just started not starting when it is cold checked wiring has power to glow plugs...
Double check your fuel filter and replace as necessary. Also replace your coolant temp sensor. I would also pull out each glow plug and bench test with heavy cables and make sure they do glow red. It very well could be a couple of the glow plugs have failed due to quality. Let me know what you find.
Apr 19, 2010 | 1999 Toyota 4Runner
Lost power to engine
Check make sure all plugs are firing. Sounds like what my 93 Rodeo was doing-Idled okay but very rough when in gear. Turns out only 5 out of 6 plugs were firing due to a defective ignition module- 100 bucks later it works fine.
Hope this helps.
Mar 20, 2010 | 1992 Isuzu Trooper
Charger was plugged in and working fine, went into
OK unplug power supply from back of laptop, remove battery, insert power supply, if NO light, on laptop, power supply is broken..Replace. IF it is OK, hold power button ON for a while, or until, the PC starts, if/when it starts, shutdown, with power ON key, and then take out power supply, replace battery, replace power supply, turn laptop on, now should be OK.
Mar 01, 2010 | Toshiba Satellite A70-S249 Notebook
1997 f250 powerstroke has power but wont start. has power from batteries all connections are fine but when turning the key over i got nothin.
Items to check are
alarm/starter disable relay
neutral safety switch (automatic trans)
try to start on N.
clutch on safety switch (stick)
main fuse
glow plug fuse
glow plug relay
glow plugs
Nov 05, 2009 | 1985 Ford F 250
Kenmore 23822 Top Load Washer Logo
15 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
