Question about Kitchen Ranges
Can you tell me the power consumption of the GE TFF24R side by side Refridgerator? thanks, gra
5 Suggested Answers
SOURCE: leaking fridge ge
1) Check to make sure nothing has spilled in it. I had a bag of peas split open once and they were blocking some area and causing an airflow problem. I would then get Ice build up then it would thaw and spill on the floor.
2) I'm sure you have done thisw but make sure a water line does not have a split or pin hole.
Posted on Nov 17, 2008
  • 400 Answers
SOURCE: GE Profile Artica Side by Side Refridgerator isn't cooling.
You say fan seems to be working? it either is or it is not working. If you are getting a reduced airflow in the cabinet, it may indicate that the evaporator coil is iced up and needs to be manually defrosted.
Posted on May 08, 2009
  • 207 Answers
SOURCE: GE Side by Side is not cooling refridgerator or
if turbo fans not running then the evaporators probably froze up and wont cool at all unplug and replace turbo fan and make sure u let the unit thaw completely i recommend atleast24 hours and turn back on and make sure turbo fan is running and u should be fine
Posted on Feb 24, 2010
  • 246 Answers
SOURCE: GE PFSS6PKWSS refridgerator side panel
I know of a site that offers covers for your appliances. www.applianceart.com
These guys are awesome and have something for everyone.
Posted on Feb 22, 2011
I'm looking for a "garage heater kit" for a side
Ganak - I'm looking for the same think...did you find it?
Dec 10, 2010 | GE CustomStyle GCL22KGRSV Side by Side...
My ice maker on the freezer side door stopped working so I changed out the motherboard CCA in the back of the refridgerator & it started working again but the water did not. I need to replace the...
Blake are you talking about the dispenser control board? The ice maker tells the water control valve to come on for the preset amout of time to refill the ice trays most times about 7.5 seconds. and filling ice maker with tap water will test icemaker. If water freezes and the ice dumps the signal is sent to the water control valve Click here=> WR57X10050 here is a service manual=> PROFILE ARTICA SERVICE MANUAL CLICK HERE Have questions you may contact me here on Fixya or my Forum=> Appliance 911 My contact information is located above the Fixya Ad on my blog here=> Sea Breeze Appliance Parts and Technical Services, Thanks, Sea Breeze
Jan 22, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Refridgerator & freezer not cooling much, ice crystals on inside of freezer
Need you to unplug and remove the back panel in freezer to examine the evaporator coil. Check the defrost element and the defrost thermostat. On the back of the refrigerator is a main control board located behind a panel screwed to the refrigerator back. With the power off through all of this I need you to inspect the control board for burn marks on both sides. Click on link below and enter your model or 1 of 34 models like yours. Place model GSH25JFR in model parts search this will lead you to the many similar models like yours. On diagrams on left of your screen count eight down that shows the circuit board. If no burn marks I will tell you how to test the other parts I mentioned,
Thanks, Sea Breeze
http://servicepartstec.blogspot.com/
May 19, 2009 | GE GSH25JFR Side by Side Refrigerator
GE Monogram Built-in Refrigerator Side keeps freezing
Sounds like a faulty thermostat. Try replacing it with a known good one and retest.
Apr 20, 2009 | GE Monogram ZISS480DRSS Stainless Steel
GE Profile PSS26NG Not cold
hi thanks for the question the problem you are having is with the defrost cycle . check the defrost timer and the defrost termination switch. and also clean all coils at the back, and clean drain tube ,from freezer to drain tray at the back. thanks the appliance doc. rate me please
Sep 27, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
not gonna find another manufactures product to match your dimensions, best bet is to find a local metal fabricator get a s/s panel cut to the dimension you need, silcone or a quaity double stick tape will secure it to where it needs to be
Mar 05, 2008 | GE PFSS6PKSS
Kitchen Ranges Logo
44 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
