Question about Kenwood KGC-9044 11-Band Car Equalizer
Best settings on a 13 band eq for rock and r&b?
4 Suggested Answers
XSdB
  • 80 Answers
SOURCE: best settings on a 9 band eq for rock and r&b
Provided the rest of your system is all tuned an in proper shape, and up for the wattts, the best sound to set, starting with the low end...start with is a slightly elevated above zero (about 1/4 up from zero) then slowly gradually slope it down to 1/4 below zero in middle and then back up to 1/4 above at the high end.
The result is a gently curved V type shape.
Now, knock down the highest 2 or 3 freq bands a few clicks till they are just above zero. (1/8).
This is the curve you would shoot for with a real-time analyzer for SQ, punch and clarity.
Posted on Jun 12, 2009
rteemon
  • 578 Answers
SOURCE: best settings on a 13 band eq for rock and r&b
THAT IS BASE ON HOW YOUR SYSTEM IS SET UP MY FRIEND ADJUSTING ALL THOSE SETTING WONT GIVE YOU MORE BASS
Posted on Aug 07, 2009
  • 14 Answers
SOURCE: EQ settings
This setting is a blast,I adapted it from the 10 band "perfect" itunes eq setting. don' t be shy , give it a try...
80hz = (2) or 7
220hz = (0) or 5
470hz = (-1) or 4
1khz = -(-2) or 3
2.2khz= (0) or 5
4.7khz =(2) or 7
12khz= (4) or 9
I have this on my LG tv, however if you need more oomph! to it, simply stick to the same pattern between the two sets above and move each slider up accordingly.
Posted on Jun 15, 2010
I have the Nitro BMWX 483 4 channel amp, BMWX 484 2channel amp , and I have the Nitro BMWX 424 4 band EQ !! Now what I'm trying to do is hook up both amps together to the EQ ! So far, I hav the BMWX...
From what I have read about this EQ it is just for subsonic frequencies. You really don't want to run your components through this EQ. Leave the components running off of the 4 channel amp and your sub box on the two channel with the EQ in series between your head unit and the sub amp.
Jun 30, 2011 | Nitro BMW-483 Car Amp
The low frequencies adjustment is not working when i turn the sub frequency on low it lowers the volume of the bass completely
check the rca cables on the back to see if you might have the sub woofer cable in wrong rca spot
this is how it should be wired from your radio front output a set of rca cables go to the radio input of the eq. if you have sub out on radio it will not be used ... eq takes place of it ... turn off subout on radio ... to use eq or preamp you must have at 2 amps 1 for mids and tweets and 1 for subs to work eq right
then from the eq you have another set of rca cables comming from the front output to your mids and tweet amp and then if you dont have a second amp u wont need rear output move over to the suboutput and run a set of rca cables from eq's sub output to sub amp this is how the audio cable section should be connected if you still dont get it to work proper then then it has a electronic issue and need to warranted out if still in warranty or buy new one .... here is a link to the install manual with a wire diagram for repair shop .....http://www.poweracoustik.com/pa2006/manual%20and%20catalog/Processors/PWM-20.pdf
Dec 27, 2010 | Power Acoustik PWM-20 4-Band Car Equalizer
Need to connect Bose 901 + JBL TL260 to HK3490 and swap for classical / rock..
For analog stereo sources, place the Active EQ in a Tape Loop and only select that loop when your'e using the 901's. If you use a digital source and activate a Tape Loop you will kill the source.
If you have a sub, WATCH OUT as the EQ WILL AFFECT its pre-out.
The best solution would be to get a separate amp for tthe 901's and, using Y-cables, share the Pre-Out-Main In with the Active EQ, which would feed the new amp. That would give you HK-controlled volume for the 901's. This eliminates any undesirable Active EQ getting back into the receiver to affect the sub or JBL's..
Nov 11, 2010 | Bose 901 VI Main / Stereo Speaker
Hi I would like to know how to wire up a kam keq 15 dual band graphic equalizer to my home hifi thanks
Either run the main ouptut for your amp to the input of the eq and output of the eq to the main input of your amp OR use one of your tape monitors on your amp. Record on your amp goes to eq input and play on your amp goes to eq output. Hope this helps you.
Jul 29, 2009 | Audio Players & Recorders
Best settings on a 9 band eq for rock and r&b
Feb 11, 2009 | Kenwood KGC-6042A 9-Band Car Equalizer
Feb 11, 2009 | Kenwood KGC-9044 11-Band Car Equalizer
EQ settings
80hz = (2) or 7
220hz = (0) or 5
470hz = (-1) or 4
1khz = -(-2) or 3
2.2khz= (0) or 5
4.7khz =(2) or 7
12khz= (4) or 9
Sep 26, 2008 | Car Audio & Video
HOOKING UP???
im looking of wiring diagram of proline equalizer model GP-870XII
pls can i have a favor to send at my yh act serra_ricky@yahoo.com
tnx!~ and more power!
Sep 15, 2007 | AudioControl EQL 13-Band Car Equalizer
Custom eq problem
Contact Sansa tech support directly to inform
May 23, 2007 | SanDisk Sansa e260 MP3 Player
Kenwood KGC-9044 11-Band Car Equalizer Logo
265 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
