Question about Canon PIXMA MP780 All-In-One InkJet Printer
Always printing in B&W empties the color cartridges
I always print in gray scale/ B&W mode, but it keeps emptying the color cartridges.
What should I do to only have the black cartridge used when printing in B&W?
  • ced95 May 25, 2008
    Thank you!
    The setting that caused trouble for me was duplex printing:
    "Note: If either 'Borderless Printing' or 'Duplex Printing' are enabled from the Page Setup tab, grayscale will be created using a combination of the color (dye) inks to prevent smearing."
  • 2,058 Answers
Go to this link. In the Search box type "print with black ink only" and click the Search button. You will see directions to do this in either Mac or Windows.
Posted on May 14, 2008
The priter goes through the motion as always for printing but a blank piece of paper comes out. I have cleaned the print head but It still does the same thing. Do you have any suggestions that I might...
If you are printing using a color (not "black cartridge only" ) driver, yes, the printer won't print because it uses a "process black" when you use a color driver.
In other words it creates black using the 3 colors, and doesn't actually touch the black cartridge.
You will need to change the default driver to one that you create.
go into control panel, hardware and sound, devices and printers (win7)
right click the officejet 6500 (not the fax driver) and click printer properties
click the advanced tab, and click printing defaults
click the fast economical printing template.
Change "print in gray scale" to Black Ink Only
Click "save as" and name the profile "black draft"
click the newly created "black draft" profile, and click APPLY and OK
This will now be your default, and it will print in black and white while the color cartridges are empty.
Jul 29, 2011 | HP Officejet 6500 Wireless All-in-One...
I have a lexmark z2320 inkjet printer the colour cartridge is empty should it still print the black is full
I'm not a computer geek at all, but I find the color cartridges always run out first. Try to change your printer settings so it will only print in black and white and so uses the black cartridge and not the color one. If the the color cartridge is empty, the page will not print correctly. It may print some of the black color only.
Mar 26, 2011 | Lexmark Z2320 InkJet Printer
Hi! I am getting a "replace toner yellow" error message. The orange lightning bolt error light is on too. Do I need to replace the yellow toner to print in black and white or is there a different error...
Specifically on the Magicolor 5430DL you can print when a cartridge is empty, but this is disabled by default. To enable printing even with a toner cartridge empty.Press the Menu Button, then press the right button until the ENGINE menu appears and press the select button.Next press the right button until TONER appears and press SelectOnce in the Toner Menu the first option should be "EMPTY" if not press the right button until you see "EMPTY" and press Select.There are two options, the default is "STOP" pressing the right button once should change from STOP to CONTINUE.While the display reads "CONTINUE" press Select.You should see the message "CONTINUE is selected"You can now print even when one or more cartridges are empty. However, the lack of the cartridge's color will be noticed in any print jobs calling for that color... (Obviously)
Jun 13, 2010 | Konica Minolta magicolor 5430 DL Laser...
Hi there, Can I print in Black & White when I ran out one of colour ink catridges??? On Brother website it says that you can. According to their advice the Error message shoud come up on LCD screen...
as long as the color print cartridges remain in the printer you should be able to print in only black and white.
If the error message does not come up you should be able to tell the printer to print in black and white in your page setup or print properties portion when you go to print your page.
(1) go file print or print
(2) a gray box will pop up click on properties
(3) Click color
(4)click gray scale
This should do it for you!
(5) select black print cartridge only
Mar 26, 2010 | Brother MFC 6490CW InkJet Printer
Can I print if I do not have a color cartridge? I have a new black cartridge and recycled the empty color cartridge without replacing it. Now I get a flashing red light indicating I need ink and nothing...
Yes, go to print properties and find the print in gray scale and it will print in black only. WHen you open the print window. Click on preferences and then look for the color tab. Click on the "print in grayscale" box.
Mar 01, 2010 | HP DeskJet 940c InkJet Printer
I never use any colour other than black yet I have to purcgase cyan, magneta, and yellow when my black cartridge is empty. Is it possible to overcome this problem, ? My printer isa DCP135C
You don't have to replace the coloured cartridges if you only use black. But if you print something that is not pure black then it will use the other colors. For expample, if you print on a gray scale, since this is a color printer it will use the colored cartridges to get the gray color. The colored printer will only use the black ink for pure black colours. If you just use black to print, why not use an inkjet printer that just prints black or uses black cartridge. It is available in the market.
Nov 08, 2009 | Brother DCP 115C All-In-One InkJet Printer
Kodak 5100 Needs Both Cartridges To Print?
Unfortunately, you cannot used the printer if one of the ink cartridge is empty., compare to the other printers you can print a black text or gray scale if the color is empty or one of the cartridge is empty.
All kodak printers work the same both cartridges should have ink on ink before you can use It.
Nov 04, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
How can I print Black only?
HP Inkjet printers work only if both the cartridges have ink unlike HP Laserjet printers.
If you want the printer to print only in black, Follow the steps
Start --->Control panel -- >Printers and faxes ---->Right click on the printer icon (HP c5100) select printing preferences.
Under printing prefences there u will see an option to print with black or print in gray scale.
Note:HP Inkjet printers like Photosmart C5180 will work only both the cartridges have ink.
Jul 26, 2008 | HP Photosmart C5180 All-In-One InkJet...
Copier not working in color
sounds like a jobg for copier man.
at any rate, you'll find that most likely your cartridges are leaning towards empty, check em first.
Feb 21, 2008 | HP OfficeJet Pro 1170c InkJet Printer
Trouble Printing
You go into your control panel and select properties, select reset ink counter and tell it you have a new color cartridge. It won't know you lied. When you choose gray scale printing it uses the colors to create black just to extend the life of your black cartridge.
Nov 13, 2007 | Office Equipment & Supplies
Canon PIXMA MP780 All-In-One InkJet Printer Logo
old marine
old marine
