Question about Sony KDL52V5100 52 in. LCD HDTV
Sony KDL-52V5100, HDMI 1 shows no signal, HDMI 2 shows audio only. I have checked both devices feeding these 2 ports and they work fine in another tv. Is this a common problem? What can I check? The tv has worked great for several months until now.
I had this tv for almost a year, and I experienced this exact same problem about 3 or 4 times. The only thing you can do is turn the tv off and unplug it for a couple minutes. When you plug it back in it will work. This issue along with the intermittent sound issue on HDMI fed sources drove me crazy until I exchanged my tv for a KDL-52EX700. So glad to be done dealing with Sony customer support...because they're TERRIBLE. I had to email a VP at sony to get any results. The picture is beautiful on the V5100 for a lcd, but it's not worth dealing with the other issues...it's a flawed model. Hopefully your tv is still under warranty...you will have to call Sony and tell them your problem. They'll send a tech to come out, and he'll probably change out the motherboard..it won't fix anything. Then they'll probably send a tech out again to do the same thing when you keep calling...eventually they'll offer you an exchange. That's how it went for me...it was a 7 month nightmare.
Posted on Nov 24, 2010
Sony KDL-40NX711 HDMI PORTS STOPPED WORKING. EVERYTHING ELSE WORKS FINE. WHAT WOULD CAUSE THIS TO HAPPEN?
Sounds like everything works. Your remote has an input menu. Have you cycled it around to the right component? i.e. HDMI1 or HDMI2, or DVD, even PC?
If not, try that.
Feb 09, 2016 | Sony Televison & Video
Sony Bravia KDL-55BX520 HDMI ports won't work but the A/Vports t
Either the HDM firmware or the circuit board will be faulty. Connect it with an other known good HDMI cable, and make sure that the fault is not with the connecting cable.
Jul 22, 2015 | Sony BRAVIA KDL-55BX520 55" Class 1080p...
No signal
Try to unplug set AND a box or receiver if in line and plug back after a wait to allow units to boot up.
HDMI can be sensitive if connected with the units including the set turned on. Not likely all HDMI would fail at same time--if problem ends up being IN the set---either the board with the connections would have to be replaced or the set subjected to a reset or even a firmware upgrade.
Jun 08, 2012 | Sony Bravia V-series Kdl-52v5100 52-inch...
I have a sony bravia kdl-52v5100 the picture looks like a regular tv, I have digital hd signal (direct tv and ps3) they are connected thru hdmi 1.4 but I not happy with the image, how can I get a full...
Hi...
The manual will give you step-by-step help in getting the correct video mode for HD signals
If you dont have a manual , check the Sony Consumer website and download one
Oct 12, 2010 | Sony KDL52V5100 52 in. LCD HDTV
PS3 HDMI - Sony Bravi KDL-40V2000 Problem
  • Have your ps32_bing.gif in standby mode (red light).
  • Now, press andhold the power button in the front down. Your ps3 will beep twice. Letit go almost exactly after you heard the second beep.
  • Wait 10-15 seconds. A display will show up, and just answer yes to all!
try this
May 08, 2010 | Sony Playstation 3 (PS3) Console
KDL-40V5100 TV HDMI Issue
I have the same problem did you ever find a solution
Jan 07, 2010 | Sony Bravia KDL-40V5100 40 in. LCD HDTV
HDMI splitter audio drop-outs with Sony Bravia HDTV
Loose the splitter and you will be in good shape unless there was damage done you should be good.
Aug 15, 2009 | Toshiba 26HF85 26 in. Television
I have a 37" Sony Bravia KDL-37XBR6 that I purchased in July 2008. I also have a Time Warner HD cable box that also has a built in DVR. The HD cable has been connected to the HDMI 1 port. It worked just...
Hello, There is an update for your TV at Sony Support and I would strongly  recommend to call Sony Support to update your TV as firmware updating firmware is risky job for novice and TV firmware can be damaged and TV will shut down.
Jan 10, 2009 | Onkyo TX-SR605 Receiver
Sony KDL52V5100 52 in. LCD HDTV Logo
1,104 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
