Washer not spinning out
My maytag washer fills fine, but won't spin out the water.....help
  • Major M May 14, 2008
    I CHECK THE SENSOR, BUT THAT DOESN'T SEEM TO HELP WITH THE PROBLEM. ARE THERE ANY OTHER SUGGESTIONS?
  • 975 Answers
CHECK SENSOR where door closes , it could be loose or damaged , hope it helps AJ
Posted on May 13, 2008
Maytag Washer won't agitate after filling
Believe you are on right track would try door lock switch first easier to replace and most likely cause.
Aug 04, 2017 | Maytag Centennial 3.2 cu. ft. SuperSize...
Tip
Washing Machines will not rinse or spin
If the water won't drain out of your washing machine, either something is stuck in the drain hose or pump, or the pump is broken. Both fixes are simple if you're even just a little bit handy with tools. We're showing the repair on a Maytag washing machine.
What is wrong with a washer that does not spin?
If your washer fills with water but doesn't agitate, the problem is likely to be a faulty lid switch, a broken belt, or a problem with the motor. (Note: Direct-drivewashing machines do not have belts.) To diagnose the problem, do the following: 1Check the washing machine's spin cycle.
How to Drain Washing Machine That Won Drain Family Handyman
Washer Doesnt Agitate or Spin
Error codes in front load washers
Washing Machine Not Rinsing How To Fix
My washing machine stops at Rinse Does not DRAIN or SPIN
What causes a washing machine not to drain and spin?
If the washer won't drain there might be a clogged pump or hose. It's common for small socks or other small clothing items to get into the water drain system and clog the hose leading to the pump or the pump itself. Remove the hoses from the pump in order to remove the article of clothing.
SOLVED Why won my washer spin or drain Kenmore 110 Series Washing Machine
Maytag Washing Machines will not rinse or spin Google Search
on Dec 12, 2017 | Washing Machines
Maytag washer model mav5920eww won't spin
It is either your gearcase or timer. They both are recommended to be replacd by a repairman.
Apr 30, 2012 | Washing Machines
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE please show me a diagram
Jun 14, 2011 | Whirlpool LSR7333 Top Load Washer
Will not fill with water but works on spin cycle
If your washer won't fill with water, but works in the spin cycle then the washer is sensing that water is in the tub. If there isn't water in the tub, then it is probably a sensor. If there is water but the spin cycle doesn't get it out, then look at the pump or control board.
Jun 08, 2011 | Maytag Washing Machines
Washer will fill fill with water but doesn't start wash cycle
it will fill but won,t spin, will throw out water as if it washed, then it take water to rinse but won,t spin ,then will throw out water as if it did , but clothes are soaked
Feb 21, 2009 | Roper RAS8445KQ Top Load Washer
Maytag s1000 stacked washer will not start water fill and cycles.
could be wash spin relay stuck in spin must be 15 years old
Feb 19, 2009 | Maytag LSE7806A Top Load Stacked...
Mav6260 washer will not spin
the belts on these units will streach, and alot of the early unit had bad belts.
the unit should spin with or with out water in the spin cycle
also the thrust bearing on these units go bad often.
this is a magic chef washer with the maytag name on it.
Apr 26, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Washer stopped working??
change the pressure switch its the switch that you select the water level with
Mar 18, 2008 | Maytag LSE7806A Top Load Stacked...
Washing Machines Logo
55 people viewed this question
Top Washing Machines Experts
