Question about Pioneer VSX-07TX Receiver
I'm have a problem when i play the tuner, the only thing i lisent is the subwoofer any body knows what going on thank you
Jensen JPS12 growls at random...
Get rid of it and get a real sub!
Sep 27, 2009 | Jensen JPS12 Subwoofer
YEs i have a Kenwood X592.And my subwoofers only beat when the tuner is on.when i place a cd or my jump drive in all it does is play the music.the subs dont work
you have the remote amplifier turn on wire hooked up wrong. The power antenna goes off when the radio does... so it will lose power when you put in a cd or go to aux.
install the blue wire labled AMP. or REM.
Problem solved.
Dec 24, 2008 | Car Audio & Video
Sleep mode
It will power off if the frequency range of the signal being sent to it is set too low, or the amplitude of the signal is too low as well.
Try increasing the subwoofer crossover frequency and/or increase the gain from the LFE/SUB of the receiver/preamp you have it connected to. Also make sure that in the setup menus of ALL of your components have an LFE channel enabled such as by selecting the output of source material of your DVD player for example, to output 5.1. Otherwise, it will not send a signal for the subwoofer to play, nor will it play the signal if the crossover frequency is set too low.
Example; the setting on your DVD player setup menu is set to two channel: result with only one exception, subwoofer will not play
Example; subwoofer/LFE level on receiver/preamp set to -10dB and/or subwoofer volume too low. Result: subwoofer will not play.
Example; subwoofer crossover point set at 35Hz. Source material playing sound at 30Hz and lower. Result: subwoofer will not play.
Nov 23, 2008 | JBL PB10 Subwoofer
Ps2 schph-5001
My dear friend, The Model SCPH-5001 is not compatible for usb format.So, this is not not possible in it, But you can listen music from an audio cd.
Thanks
Oct 07, 2008 | Sony PlayStation 2 (PS2) Console
Tuner works but when i play a cd it shows that it is playing but no sound comes out this cd player is brand new
Take it back for a refund or replacement, If you have speaker output on the tuner,their is no reason or why it shouldn't give you tunes when you insert a CD.
Regards, Paul
Jun 12, 2008 | Kenwood Car Audio & Video
Kenwood receiver/sub problem
The amp's remote turn-on wire is probably connected to the blue wire coming from the back of the stereo - this is intended for a power antenna, which is why it only works when listening to the radio. Disconnect it from the blue wire and connect it to the blue/white wire coming from the back of the receiver and you should be good to go.
Sep 21, 2007 | Kenwood KSC-WD250 Car Subwoofer
Orange light
I have the same speaker and it sounds like its behaving properly.
if you look on the back of the amp, you will find a switch that allows the speaker to automatically switch the speaker on or off based on the level of the audio coming from the tuner that it is attached to. If the switch is set to the auto mode, then it will listen for audio on the line and if the signal level coming into the subwoofer is high enough, the amplifier in the subwoofer will turn on and play. If the signal is not strong or loud enough, then the subwoofer will not turn on. There are two solutions to getting the speaker to work.
1. When you turn on the tuner or audio source that is feeding the Subwoofer speaker, you will need to turn it up loud enough to trigger the circuit in the subwoofer to switch on.
2. Alternatively, you can bypass the automatic circuit and set it to the "ON position all the time. In this position the subwoofer is always ready and waiting and should play any signal that is fed to it regardless of the loudness or volume of sound from the tuner. The switch is located on the back of the speaker cabinet just to the right of the red and black speaker wire connections. It is labeled "AUTO" and the switch positions are labeled ON and OFF.
Hope this helps!
Jul 09, 2007 | Acoustic Research S112PS Subwoofer
Problems With RCA Television (Gray Screen)
Your problem is the old rca tuner sheild repair thingy. Its a simple but tricky repair where the tuner grounds around the tuner sheild and under the bottom of the tuner sheild has to be resoldered. Most repair shops in the states that i know of charge like 65 to 125 .00 to do this simple repair. Now if you know how to solder you can get this reapir mod from sams photo facts and do it your self but its really an involved thing if you dont know what your doing as some of the serface mounted parts look like a spec of dirt and i've seen a few peeps clean off those specs and ruin the whole set. Best for you to take this set in for a repair. Good luck
May 05, 2006 | RCA F25645 25" TV
49 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
T-Comtech Repairs
T-Comtech Repairs
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
