Question about DeLonghi Pinguino PACL90 Portable Air Conditioner
Pac L90 Hello, I got a PF error and not sure how to fix it. Do I need to send it back to Delongi? I live in Hawaii and not sure how much that will cost. Its been running great and have no problems but now it wont start the compressor at all. Thanks 808-398-9327 gwells@digipageit.com
  • 2 more comments
  • big smith Sep 09, 2008
    I have a probe failure and there are no repair shops in my area.
  • Anonymous Sep 21, 2008
    Same PF error. Had to get main pcb replaced. $150.00 now have unit plugged into power conditioner.
  • nando2r Apr 22, 2009
    I have the PF display. Son gave me unit can't find manual. No luck
    at the DeLonghi site.
  • smorley10 May 01, 2009
    I own 3 of the DeLonghi Pinguino portable air conditioners bought at Lowe's here on Maui about 2 years ago and one of them is consistently displaying the PF error code. I guess this is common and there's nothing cost effective that can fix it, so we'll try another model, I guess...
p f PROBE FAILURE
(The probe is damaged) Contact Service Center. From manual.
Posted on May 28, 2008
PAC L90 air conditioner keeps frosting up. The room air intake frosts up completely, blocking all the air.
Air conditioners frost up when there is a lack of air flow. Clean the filter, check if a belt is broken (if any), check that the fan spins freely, check all in ports and out ports for blockage and clean the coils with mild soap and water.
Jun 08, 2016 | DeLonghi PAC L90 Portable Air Conditioner
Does not blow out cold air. It comes on but does not blow out cold air, only has cool air
My DeLonghi PAC L90 Portable Air Conditioner does not blow out cold air,only has cool air
Jul 12, 2011 | DeLonghi PAC L90 Portable Air Conditioner
I have a pf code flashong on my a/c unit. Could you tell me what it means. I have the PAC l90
Here is a tips that I wrote that will help to explain why you get the PF Error Code
PF Error Code for Appliances
heatman101
Sep 24, 2010 | DeLonghi PAC L90 Portable Air Conditioner
Where can i send my amps to be serviced? I live in hawaii...
Hello: You cand send the amps to Delhielectronics.
We specialize in audio amps and preamp repairs. We offer a 90 warranty on parts and labor.
Send to or email for more information
Delhielectronics@live.com
or send to Lavell Turner
3151 Soaring Gulls Dr Suite 1202
Las Vegas Nevada, 89128
Oct 24, 2009 | Orion HCCA-D5000 Car Audio Amplifier
Error Message
It's actually "Ft", which means "Full Tank".  The instruction manual says to drain the internal safety tank through the drain hoses.
To drain the tank, open the cover on the rear of the appliance. Pull out the 2 drain hoses, take off the caps, and let all the residual water flow out.  When all the water has been drained, place the caps back on the hoses and put the hoses back inside.
It also says you need to clean the filters and let them dry thoroughly before putting them back.
This is also the procedure for "End of Season Operations."
Hope this helps!
Jun 05, 2008 | DeLonghi Pinguino PACL90 Portable Air...
Delonghi Pac L90
Hoses for proper connection should have been included with your purchase. Without the hoses the set-up can not be done satisfactory. One is for fresh air supply and the other is the hot air exit hose. These are normally vented out a window. Check with the dealer where you perchased the unit from. If from a private individual contact them.
May 21, 2008 | DeLonghi Pinguino PACL90 Portable Air...
Delonghi PAC L90
The probe is located on under the main board low inside the only silver metallic box on the bottom w circuit board under it.Remove cover and immediatly you see a 4 inch black wire connected to the main board tucked under and mounted.Unplug the white connector from board, power on, then carefully plug the white connector back on, turn unit off and back on, you should see all 3 mode lights now on steady , no pf error and it doesnt turn off,and you can change modes and temps.Took an hour to take it part and dig around, mine works fookin great now.
Jun 20, 2007 | DeLonghi Pinguino PACL90 Portable Air...
Heating & Cooling Logo
829 people viewed this question
Top DeLonghi Heating & Cooling Experts
Paul Carew
Michael Youngman
Michael Youngman
Are you a DeLonghi Heating and Cooling Expert? Answer questions, earn points and help others
