Question about Cyberhome CH-DVD 300 DVD Player
DVD WILL NOT PLAY
WHEN I TURN MY DVD PLAYER ON, I GET THE CYBERHOME SCREEN BUT NO MENU. I HIT PLAY AND A SMALL SYMBOL APPEARS IN THE FAR LEFT CORNER THAT HAS A CIRCLE WITH A LINE THROUGH IT. THE DVD DOES NOT PLAY. I DON'T KNOW HOW TO GET THE DVD TO PLAY. CAN ANYONE HELP ME?
  • Mamielee May 27, 2008
    I had set up my CH-DVD 300 a year ago. It played. Now I am trying to install it again in the same location with the same connector wires and
    it lights up but will not play a DVD. It will accept a DVD and eject it but
    does not respond to play. Help!
  • velvet_mile May 29, 2008
    I can hear the disc turning and the DVD player trying to read it with a horrible screaching sound like nails on a chalk board. After 3 minutes, it finally gives up and tells me there is no disc. Against all warnings, I just had to open it and see what the hold up was. I even did a major cleaning job to the player and the cd. Still, nothing. I am in a rut and at a loss...
I have repaired a couple of these cyberhome dvd players-if you are getting a no disc,it is because of a defective disc table motor or bad flex connector(between lens & circuit board).if your unit is not powering up, you should check the power supply board in the unit(.there are capacitors that go bad) i recomend these checks be made by a tech. rkelecworks.
Posted on May 14, 2008
Samsung BDE6100 region free codes
1. Ensure that there is no disk in the tray.
2. Switch the player off and then back on. This is necessary to clean-boot the
firmware.
3. Wait until the main menu page appears and the player stops doing
anything.
4. Press the eject button on your remote to open the tray.
5. Press the eject button on your remote to close the tray.
6. As soon as the "No Disk" message appears at the top left corner do the following.
8. Press the REPEAT button (the square symbol)
9. Enter 57538 on the number pad.
10. The region code "4" should appear at the top left corner of the screen.(this just flashed on then off, so keep an eye on the screen)
11. Enter a "9" to make the player region free.
12. Power down and power up again.
13. Play a foreign DVD to verify the change
Jul 10, 2012 | Televison & Video
Will not play a Blu-Ray Disc Terminator Salvation
go onto www.p4c.philips.com and download latest software update and transfer onto a usb stick to update dvd player
Jan 04, 2010 | Philips Televison & Video
VHS won't work
Had the same problem on my JVC vcr/dvd combo unit.
You need to turn off the timer function. I did this by making sure my remote was in the "VHS" mode...turn the swith from TV to the right (found on the remote in the upper left corner...an then hit the "vcr" button. Then point the remote at the VCR unit and hit the No. 4 button (timer turns off). Your unit should not have the red timer displayed and you should be able to play your tapes okay.
Hope this helps.
Jun 11, 2009 | JVC HR-XVC27U DVD Player/VCR
LOCKED DVR
I just bought the CH-DVR 1600 @ Target. This is just a temporary workaround to enable playing of region 2 DVD disks (don't have other regions but believe it will work also), until the real regional unlock is available.
1. Insert the region 2 DVD disk and close the tray.
2. Wait for the "Wrong Region" popup to appear in the upper-right corner of your TV screen.
3. The display on your DRV reads "STOP" at this point and the "Wrong Region" popup has disappeared.
4. Press the number "1" button on your DVR remote and a small input popup will appear in the upper-left corner of your screen.
5. Do not press anything else and the DVR will accept this entry as a chapter # and proceed to this chapter to start playing the movie.
NOTE1: The DVR runs in a somewhat restricted node, e.g. the DVR display still reads "STOP" and some remote functions do not work, such as "Menu". The input numbers correspond to the chapters on the DVD disk, so you can experiment and get to the menu once you hit one of the extra feature chapters with a "back to the menu" link on it.
NOTE2: I’m anxiously awaiting the real unlock sequence, as I tried most of the old ones posted here, none seemed to work.
also try this
-Switch player ON with no disc in the tray. Close tray and press MENU, 1, and 9 on the remote control. A menu should appear with the Region Option. Highlight the Region entry and press ENTER on the remote. Type in the Region you want. (Put 0 for code free) Press ENTER again to confirm choice. Press OPEN/CLOSE TRAY button and put in movie.
Mar 31, 2009 | Cyberhome DVR 1600 DVD Recorder
Cyberhome dvd player ch-dvd 300 What region code is this dvd player? can it play region 2 dvd's?
Dear friend,
Try this method to change the region.
1. Switch player on, making sure that there's no disc in the tray.
2. Close tray.
3. Using the remote control, key in the following: MENU, 1, 9.
4. A menu will appear with the region option near the bottom of the screen.
5. Press ENTER, enter the desired region AND PRESS ENTER again to save the desired region.
6. Next press OPEN / CLOSE.
Nov 18, 2008 | Cyberhome Televison & Video
Cyberhome Ch- DVD 300
Your advice was very helpful. After two+ months of tooling around and navigating around the menu blind I was on the brink of trashing it.
At first I tried the stop button with a dvd in the player with no success. After taking the dvd out, turning in off/on then pressing the stop button for 20 seconds the screen turned blue as said.
This help saved me a great amount of fustation.
Thank You!
May 27, 2008 | Cyberhome CH-DVD 300 DVD Player
Changed Video Output Setting
Reset you player by doing the following:
With the player on, hooked properly to your television1.gif, and on the correct station:
Open the tray
Close the tray (with no DVD inserted)
Hold the stop button down for a full 5 seconds
The CyberHome screen should appear. You should be able to play your dvd's now.
Feb 27, 2008 | Cyberhome CH-DVD 300 DVD Player
DVD stopped playing all DVDs
With the player on, hooked properly to your television, and on the correct station:
Open the tray
Feb 20, 2008 | Cyberhome CH-DVD 300 DVD Player
DVD problem
I have a cyberhome CH-300 my player running 50mins and next stuck the move .
Feb 12, 2008 | Cyberhome CH-DVD 300 DVD Player
Cyberhome DVD Player not playing CD
I had a similar problem, and I took the player apart to find that there was a motor that has a snap-in connection to a circuit board and it was just disconnected. It controlled the movement of the reading laser. I could hear it make some noise. I reconnected it and it worked fine. There are quite a few philips head screws to remove to get into the case. It slides off the back. Once inside, it's very simple looking, it is really un-intimidating. You may have 4 more very small screws to remove directly on top of the DVD tray. If you need to take it off to see under the tray that is. I'd like to guess the problem is that the motor that ejects the tray is disconnected.
Mar 02, 2007 | Cyberhome CH-DVD 300 DVD Player
Cyberhome CH-DVD 300 DVD Player Logo
88 people viewed this question
Top Cyberhome Televison & Video Experts
zappal
Demonic-2011
Demonic-2011
Are you a Cyberhome Televison and Video Expert? Answer questions, earn points and help others
