Question about Ovens
The door lowering mechanism is broken. It falls down if not tied up. Is it fixable?
  • 2 more comments
  • Mike Groome
    Mike Groome Sep 06, 2010
    This is a swing down door. Do you mean the spring is in the door? I can pull the door off, but that exposes just a metal arm inside which swings on the hinge. I can't see anywhere on it where a spring would be attached. I suspect the spring is inside the oven. Where the hinge enters the body of the oven, it is surrounded by a small panel held in with a retaining clip. Do I pull that out or do I have to take off the whole front of the oven?
  • Mike Groome
  • Mike Groome
    Chef Regency wall oven
    The door lowering mechanism is broken. It falls down if not tied up. Is it fixable? The door is a swing down one. I've pulled out the door, but the spring isn't in the door
  • Mike Groome
    Does 102G4F12 mean anything on a Chef Regency fan forced wall oven? That's the model number on the plate.
  • Ovens Master
  • 19,396 Answers
Hi.
You need to replice either roller door motor, retaining springs, or hinges assembly. The precise diagnosis requires a technician in site. The oven is surely repairable, parts and repair can be obtained contacting the manufacturer at the number on the owner manual.
Posted on Sep 06, 2010
    President:
  • 1,891 Answers
I could tell you more if i new the brand and model # . some parts may not be avlb . but if so i would think it is repairable we do it every day mm thanks for using fixya .mm
  • dennis dodge Sep 06, 2010
    a chef regence wall oven i have not seen one . but that may be the model and not the brand . like whirlpool (imperial) maytag / majic chef . the hinge should stop the door so ts level and the spring helps to door to stay closed . the spring can only be in two places . either inside the door or in the side of the range . often they use cables to conect the hinge to the spring . see if you can find a model # ________ or the mfg of your range .. **** ..
  • 4,059 Answers
The door is held shut and assist in open and closing by springs connected to the bottom of the door. If it's a slide in you just slide it out till you can see the arm and spring. The hinge can also be worn causing the problem is the spring isn't broken. With the door open in the broil position lift the door out to do the repair.
  • Charles T Nevin
    Charles T Nevin Sep 06, 2010
    Yes the arm is the hinge. The spring is inside where it is. Some are exposed when you slide the oven out from the cabinet. Others you will have to take the cover off.
How do I know if the hinge is broken on the stove door?
the door will fall off when opened if both hinges are broken, if only one hinge is broken the door will drop down on one side.
Apr 20, 2012 | Brown Stove Works Ovens
Got error code F9 while oven cleaning in process. What does this mean?
An F9 error code on a General Electric (GE) oven indicates that the oven's electronic control system has detected a problem with the automatic door lock.
The automatic door lock mechanism prevents the oven door from being opened when the oven is set for "Clean" mode.
The malfunction may be a jammed door lock mechanism, a pinched or broken wire, a faulty lock switch or a fault in the control board itself.
9 out of 10 times the lock switch has failed.
STEP # 1 - Disconnect power to the oven!!
  • Step 2 Open the oven door. Remove three screws from underneath the oven's control panel. Lift the control panel straight up to disengage the mounting pins on the top corners of the panel, then tip the panel toward you.
  • Step 3 Inspect the door lock mechanism. The mechanism is in the lower left area of the space behind the control panel. Rotate the cam on the door lock mechanism to be certain it moves without binding. Replace the mechanism if its mechanical parts do not function properly.
  • Step 4 Inspect the wires that connect the door lock mechanism to the control panel. Check for pinched or broken wires. Check for wires with frayed insulation2_bing.gif. Repair wires as needed if defects are present.
  • Step 5 Locate the six-pin connector on the door lock motor on the right end of the door lock mechanism.
  • Step 6 Rotate the cam on the door lock mechanism to the unlocked position. Test the resistance between Pin 3 and Pin 1 of the door lock connector with the ohmmeter. The resistance should be 0. Replace Lock Switch 2 of the door lock mechanism if the resistance reads other than 0.
  • Step 7 Rotate the cam on the door lock mechanism to the locked position. Test the resistance between Pin 3 and Pin 2 of the door lock connector with the ohmmeter. The resistance should be 0. Replace Lock Switch 1 of the door lock mechanism if the resistance reads other than 0.
  • Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
    Apr 01, 2010 | GE Profile JTP56 Electric Double Oven
    It won't get to temp, then it beeps and it says f9...it continues to beep, and inside light is off
    Disconnect power to the oven.
    Inspect the wires that connect the door lock mechanism to the control panel. Check for pinched or broken wires. Check for wires with frayed insulation. Repair wires as needed if defects are present.
    Contact a certified GE appliance repair facility if the source of the F9 code has not been discovered. Troubleshooting the oven with the electric power turned on is a job for a certified technician.
    Mar 05, 2010 | GE Monogram® ZET3038 Dual Single Oven
    Moffatt double oven 4175 lower oven door springs broken
    My problem was not with an Amana single oven but aMoffatt double oven ! However I have now decided to buy new.
    Oct 31, 2009 | Amana AEW3530DD Electric Single Oven
    My oven door does not close tight
    These hinges are now obsolete and you cannot get them anywhere. The poblem with this type of hinge is not with weak springs or anything like that, it is with the pivot pin in the door hinge. Follow these instructions and it will not cost you anything for the repair.
    It is best to remove the oven from the housing. Remove both sides of the oven panels, you have to remove the top first, then the sides (remove about 20 screws all together). Support the bottom oven door first by tying a bit of string between the bottom and top oven door hand rails. This will stop the door falling down when you remove the springs. unhook the springs and the door will just slide out. (Use a loop of string attached to the back end of the spring to pull it from its holes.)
    Dismantle the door by removing the screws. You will probably find that the the hinge pivot pins have come away from the U shaped hinge bracket. The secret is to make sure that these are fixed firm back into the bracket. What I did was to nip the U hinge bracket in a vice, (or use pliers) so that the pin will now protude slightly each side of the bracket. This allows more surface bearing area so the pin will not pull itself out of the hinge. To further make sure, I glued the ends of the pin with epoxy resin.
    Then reassemble.
    My door now feels like a new one even though it is 15 years old.
    Sep 16, 2009 | Stoves 720EF Electric Double Oven
    Smeg F170-5 door joint broken
    The door is removed by rotating, on both sides of the door, a clip on the lower of the two struts that connect the door. The clip rotates up and then engages a hook on the upper clip so that the two are held together by the spring mechanism to allow the struts to be lifted out when the door is in a 45° angled position. With the door off there are three screws on the bottom of the inside that allow the inside window assembly to slide off, allowing the parts to be replaced.
    Sep 14, 2009 | Smeg S351X/5 Electric Single Oven
    GLASS BROKEN ON MY FRIGIDAIRE PRO
    Inner or outer? you will have to take the door off, done by lowering door to full open postion and youll see a fold down flap at hinge, fold down and close door and lift. this will allow you to access screws easier. remove handle and four bottom screws. that will allow you to take off outer glass....there will be screws on inside to take out inner glass.
    Jun 08, 2009 | Frigidaire FGB24S5A Gas Single Oven
    How do get access to the door hinge of my Maytag CWE4800ACB oven
    In first, excuse my poor english if i make some mistake.
    I hare repair the same problem. part broken in left side and the door fall.
    You have to pull out the oven from the wall, use some objet to support the oven,small table or plastic box if you dont want to put down completely.
    You have to unsecure the electric wire connection in back if you whant to pull out enough for remove the left cover. You have to remove some parts in front for acces to screws on the side cabinet.
    In my case the hinge was broken, i have soldered and fix again.
    If hard to replace the spring in the mecanism, you better to do this on the bench before put all in the side of the oven.
    I think the maytag oven have the same problem.
    Other problem also is the timer alarm sound in the night went you sleeping, prob whit switch sensitif pc board. Now i turn off the breaker in the back of oven all night, and i sleep good.
    Bye..
    Mar 24, 2009 | Maytag CWE4800A Electric Single Oven
    Oven door falling down on the Frigidaire stove
    Try to replace the hinges the locking mechanism is going out
    Feb 08, 2009 | Stoves 720EF Electric Double Oven
    Dacor Gas wall oven
    is there tension on the door at the point where it doesnt seal,is the spring broken/missing,when the door opens and closes is there enough travel from point a to point b inside the cabinet on both sides of the hinge area, is the sping loaded mechanism damaged .
    Dec 30, 2007 | Ovens
    Ovens Logo
    60 people viewed this question
    Top Ovens Experts
    Dan Webster
    Dan Webster
    ashburton
    Are you an Oven Expert? Answer questions, earn points and help others
