Question about HP Officejet 4315 All-in-One Printer
HP Officejet 4315 printer options question
Do I really have to print a whole document to get the one page I want to print?  How can I set to ask me which page I want to print?
  • 79 Answers
Click on File and Print :
select the page range or number here as shown below:-
Hope it ll suffice ur need
Posted on May 30, 2008
OfficeJet 4315. When receiving faxes, why does it print blank pages?
Hi Ljiljana Tubic,
I would be happy to help you with your Officejet 4315. I understand your faxes are printing but there is no ink on the page. I suggest using the following document to troubleshoot the issue:
HP Officejet 4210 4250 and 4300 All in One Printer Series Correcting Print...
If the issue persists, what you can do, is use the following link to create yourself a case number, then call and it may help speed up the call process:
Step 1. Open link: h22207 www2 hp com
Step 2. Enter Product number or select to auto detect
Step 3. Scroll down to "Still need help? Complete the form to select your contact options"
Step 4. Scroll down and click on: HP contact options - click on Get phone number
Case number and phone number appear.
Best of luck.
I work on behalf of HP.
Jul 28, 2015 | HP Office Equipment & Supplies
My HP OfficeJet 4315 All-in-One printer defaults on FAX mode for some reason. How do I change it to print?
To better help you I did the work for you... I copied this from the HP forum which if you google your issues most of the time you find the answer!
Copied from:
There are generally two print devices set up when an all-in-one with a fax is set up - one is the fax device and the other is the printer. Make sure you have the print device set as the default printer and/or that when you want to print that the printer and not the fax is selected.
Setting the proper printer as default would depend on your operating system, but for most versions of Windows you would go to the printers folder, right click on the non-fax version of the Officejet 4315 and select "Set as default".
Jun 17, 2011 | HP Officejet 4315 All-in-One Printer
Printer is not printing Device menu is set at fax. trying to change it to printer function to print, but manual and on line site does give guidance as to how to change. HP 4315 all in one
you can download the utility driver in the website.. the name would be HP Print diagnostic utility follow this steps
  1. Go to
  2. Click on "support and drivers"
  3. On step 1 click on "download drivers and software"
  4. On step 2 type the product number/ name of the printer (ex: officejet 4315 / Q8081A)
  5. (on the next page it will ask you to select your operating system. example: win xp, vista or 7) Select your operating system, then click on next.
  6. Once you click on next, you can scroll down then look for "Utility Diagnostic tools"
  7. Look for HP Print diagnostic tools then, look for the download link then you have to save it so... you don't need to keep on downloading it if you encounter same problem again w/ the printer.
  8. After downloading the driver, run it.
  9. Scan the problems on the printer. (the tool will tells you if you have issues w/ ports, default printer, printer driver and etc.)
  10. If the fix button is available click on it, if its asking to uninstall the driver please do so..
  11. Restart your computer.
  12. Check if you print any document.
if you want to get the exact link for your printer click here
Root cause: fax printer icon was set as default printer under devices and printers. if you are still having issues w/ it. call HP printers support department 1-800-474-6836
NOTE: If you call HP they may ask you to pay first, because this printer is old.
Good Luck :)
Jan 31, 2011 | HP Officejet 4315 All-in-One Printer
I have a new computer w/ Windows 7 -- and my oj 4315 won't connect. Except it did! Long enough to print one page. Now it says can't find the driver. What should I do? I have rebooted unplugged...
You can connect your printer manually. Perform the given below steps to fix the issue:
First of all connect the USB cable between the computer and printer.
1) Click on Start (Windows Icon) and then click on Devices and Printers.
2) Click on Add a Printer option on the top and once you click on it a new window appears,. on the new window, select add a local printer and click next
3) Now select port under Existing ports that says USB001 Virtual Printer Port and click next
4) After that under Manufacturer option select HP and under Printers option select Officejet 4300 and click next.
5) Now name the printer set it as default printer and click next
6) After that select Do not share this printer and click next
7) Select Yes for test page and then click on Finish and check is it printing and I believe it will work.
If your issue gets fixed, please come again to give us a
vote which will really motivate me to help people in
May 10, 2010 | HP OfficeJet 4315 All-In-One InkJet...
My hp officejet 4315 only prints in black
Good day, To print from software application (windows) follow the procedure below.(for hp officejet 4315).
1. Make sure you have paper im the input tray.
2. On the File menu in your software application. click Print.
3. Make sure the HP officejet 2315 all in one is the selected printer.
4. If you need to change settings. click the button that opens the Properties dialog box.
Depending on your software application, this button might be called Properties, Options, Printer Setup, Printer, of Preferences.
5. select the appropriate options for your print job by using the features available in the Advanced, Paper/Quality, Effects, Finishing, and COLOR tabs.
6. Click OK to close the Properties dialog box.
7. Click Print or OK to begin printing.
God Bless.
Oct 19, 2009 | HP Officejet 4315 All-in-One Printer
How do i download the hp officejet 4315 all in one in my new computer when i lost the installation cd?
HP Officejet 4315 printer unplugged from your computer. (Via the USB cable)
Printer off, and unplugged from the surge protector.
Go to HP Support. On this page,
1.Type - Officejet 4315 in the search box, (for product:___________)
2.Click on the double Side Arrow to the right of the search box.
3.On the main page for the HP Officejet 4315 All-In-One Printer, click on Software and Driver Downloads. (Middle column)
4.Now choose your Operating System on the next page. I'm going to choose Windows XP as an example.
5.On the Select software and drivers page, go down to the first heading - Driver
Click on - HP Photosmart Full Feature Software and Drivers
After you click on the above, you will be taken to another page. It may look like it's starting to get complicated, but it's not.
Click on the blue rectangle with Download Only>>
in it.
A small window will pop-up to the top right. Click on - Save File.
The file will now start downloading to your computer. Let it download all the way. (I have a medium speed DSL connection, and the download box indicates 30 minutes! Just have to be patient I guess!)
Where will this file go?
Unless you have your downloads set to save to your My Documents folder, (Documents for Vista), this file will go to your desktop screen.
In either place when you see it, Double-Click on it.
The Installation Wizard will now come up, and guide you with simple instructions.
It will put the file in the proper place, so there is no reason to guess. Just click on I Agree, (If stated), Next, Next again, and Finish.
After you click on Finish you are done installing. If you are asked to Restart your computer, do so.
If not, do so anyway.
After your computer has FULLY restarted, and Windows is running, (Assuming we are referring to Windows here), plug the USB cable from the printer into the computer.
Plug the printer into the surge protector. Turn the printer on.
You should get a pop-up out of your system tray, (Bottom of monitor screen)
"Found New Hardware", and perhaps another pop-up,
"Found Officejet 4315"
Now just go to Start>All Programs>HP>HP Officejet
Sep 24, 2009 | HP Officejet 4315v All-In-One InkJet...
I can't print my documents
You must configure first your printing preferences or download a tool for the printer
Mar 18, 2009 | HP Officejet 4315 All-in-One Printer
Hp officejet 4315 all in one printer spooler
In windows, go to the start menu, then control panel, then printers. When you have that open, double click on your printer. This will bring up the queue of all documents waiting to print. You can then highlight them and delete all of them.
good luck
Jul 22, 2008 | HP OfficeJet 4315 All-In-One InkJet...
Setting HP OfficeJet 4315 print preferences on a MAC OS X
Whenever you send a file to print from a program a small window shows up. If it shows only
Printer: Drop down menu ARROW Presets: Drop down menu Some buttons at the bottom
then click on the ARROW pointing down for more options. That will show more info, including a drop down menu that will allow you to change page settings, printing settings, etc. For example, if you want to change the printing quality, select "Paper Type/Quality" from that drop down menu and new options will show up allowing you to change the settings of the printer.
Jan 10, 2008 | HP OfficeJet 4315 All-In-One InkJet...
48 people viewed this question
Ben Johnson
