Question about PfaFF Sewing Machines
Hobbymatic 917 My pressor foot won't go down all the way. How do I get it resting on the feeddogs?
bargainbox
  • 1388 Answers
SOURCE: Simplicity 4 thread EZLock 880 pressor foot settings
Easiest way to get the tensions right, use 4 different coloured threads
Make sure the tension disks are clean........run a length of fabric in a see saw fashion through each tension unit.
....set all the dials to 3 or 4 then sew test.......take a look at what needs attention, make a small adjustment and test/adjust until the needle threads are firm and the looper threads meet neatly at the edge of the fabric with just the absolutely tiniest hint of being loose.
Posted on Jul 18, 2008
  • 5346 Answers
SOURCE: When I push the pressor foot down my machine flashes E1
Is the presser foot lever up or down? It should be down before you step on the foot controller or use the start/stop button.
For additional information, try this URL: http://welcome.solutions.brother.com/BSC/public/us/us/en/model_top/HomeSewingMachine/hf_cs6000btieus.html?reg=us&c=us&lang=en&prod=hf_cs6000btieus
Posted on Aug 24, 2009
  • 1788 Answers
SOURCE: where to find a not snap-on 1/4" with edge pressor
Go to www.allbrands.com and you can buy a low shank screw on presser foot. I am assuming that it is a low shank. (I looked up your manual on www.singerco.com for free) It is $14.95, I think. Good luck
Posted on Nov 20, 2010
  • 517 Answers
SOURCE: pressor foot will not completely
Good day to you!!!
I am suggesting you to put an oil to that pressor foot and also all parts which you think need to be oiled so that it become soft and easy to use..
If this suggestion does not help please have a comment so that we can make another steps/solution to it...
Thank you and please do not forget to testify and rate me when it helps you...
Good luck...
Posted on Jul 15, 2011
Tally Girl
  • 1133 Answers
SOURCE: have lost the zipper foot for a pfaff hobbymatic
You should be able to buy another foot, but you'll need to know if it is a high shank or a clip on style. Try this link to www.sewingpartsonline.com http://www.sewingpartsonline.com/pfaff-sewing-machine-presser-feet.aspx they have two invisible zipper feet and two clip on ones. Don't mention your model but you should be able to email and ask if you aren't sure. I'd expect that the feet would be interchangeable between the models in the same era as yours. Just ignore the long funny shaped feet, they are for Pfaff sergers.
Posted on Oct 07, 2011
Need. Help getting pressor foot to go all the way down?
have you checked to see if the pressure foot itself has a height adjustment, or even try a different pressure foot.
Aug 04, 2017 | Sewing Machines
How to adjust pressure on presser foot
Depends on your machine brand and model. Some machines have that capability, others do not. Consult your owner's manual.
Aug 25, 2015 | Sewing Machines
Bar that sewng foot is attached to for raising & lowering suddenly will not drop sweing foot all the way down to plate. Any suggestions on how to fix?
Perhaps you accidently moved the switch that enables free hand embroidery? It's up and under next to the pressor foot lever. Slides forward and backward. Forward the pressor foot will go all the way down to the feed dogs. Slid back and it keeps the foot up off the feed dogs but allows the thread tension to work properly. It would be easy to accidently move it when operating the pressor foot raise/lower lever.
Aug 31, 2014 | PfaFF Sewing Machines
6020 off problem
Not sure, but am thinking perhaps the tension disk has gunk or threads stuck in it. Try soaking a length of perl cotton in rubbing alcohol, squeeze out the excess. Raise the presser foot and loosen the tension disk as far as possible and gently pull the perl cotton DOWN through the tension disk a few times.
If that doesn't help, then it's possible a spring in the tension mechanism or something in the presser foot lever is malfunctioning.
Dec 07, 2017 | Sewing Machines
Problem with striaght stitch pressor foot
it's possible that the needle bar is out of alignment and needs to be fixed at a sewing machine shop
Mar 18, 2014 | Kenmore Sewing Machines
Feeddog won't move with pressure foot down. I have a Baby Lock BL4-428. I haven't used it in a while. I cleaned it up and oiled it. The feeddog moves when the pressure foot is up but as so
it sound like the feed dog & the presser foot need to be adjusted
so they work togeather,,it's very possible they need to be timed
a sewing machine repair shop can tell you for sure
Sep 05, 2012 | Baby Lock Sewing Machines
I need a free pfaff hobbymatic 917 instruction manual
For many of the Phaff machines, you can search and find your machine at this link, and download the .pdf file, then print out. This is FREE, no charge, and available to anyone. I searched and found it by luck. Note, your model may be included in other model numbers. My wife's Phaff Hobbymatic 927(Made in West Germany) manual includes the 917 and 947 models. Good luck, hope this helps.
Feb 13, 2012 | Sewing Machines
I can't get the pressor foot on the silver part came off and the actual pressor foot
Place the foot under the arm while arm is in up position. Put arm in down position and foot should snap into place (line it up where it is supposed to go together before lowering the arm).
May 11, 2010 | Brother XR-65t Mechanical Sewing Machine
Hi I have a Husqvarna 1+ when the pressor foot is in the down position a warning indicator states that the pressor foot is not down and the machine will not function.Any sugestions would be greatly...
The problem could be caused by a couple of issues. It is either with the switch that is located above the foot, that tells the circuit board when the foot is up or down, or with the circuit board itself. It could also be the lever you lift the foot up and down with. Inside the machine that lever has a plastic "fin" on it that touches the switch. It is possible that the lever is broken. Either way, you need to take it in for service.
Dec 29, 2009 | Husqvarna Sewing Machines
Zigzag not working
Download the users manual here if you don't have one. PFAFF users manual.
Nov 17, 2009 | PfaFF Hobby 4260
Sewing Machines Logo
83 people viewed this question
Top PfaFF Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a PfaFF Sewing Machine Expert? Answer questions, earn points and help others
